trueblood 2 seasons, multiple disks, multiple drives same failures
icbm1
#1 Post by icbm1 » Thu Oct 30, 2025 8:35 pm
I am trying to rip 2 seasons of Trueblood on Bluray, a total of 10 disks. I have 2 different LG drives, and all the disks fail in the same way with SCSI errors and offset errors. The documentation would lead to think the disks are damaged and some are kinda rough but most are in good condition. I tried two different LG drives, BP60NB10 (USB Slim) and BU40N (SATA Slim).
It just feels unlikely that all the disks would be bad that they won't rip but play in our sony player fine. I went and tried some disks we ripped earlier and they worked fine to test the drives.
All the disks fail in the same way with errors similar to:
The source file '/BDMV/STREAM/00056.m2ts' is corrupt or invalid at offset 2153072640, attempting to work around
Too many AV synchronization issues in file '/BDMV/STREAM/00056.m2ts' (title #-) , future messages will be printed only to log file
Failed to save title 0 to file /Volumes/scans/staging/True Blood Season 3 Disc 4_t00.mkv
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00027.m2ts' at offset '389677056'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00027.m2ts' at offset '389935104'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk6' at offset '389935104'
Failed to save title 1 to file /Volumes/scans/staging/True Blood Season 3 Disc 4_t01.mkv
Failed to save title 2 to file /Volumes/scans/staging/True Blood Season 3 Disc 4_t02.mkv
Encountered 17 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Encountered 19 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
Is this some sort of manufacturing shenanigans? They are older disks just statistically for all 10 disks in 2 drives to fail the same way but still playing prompted me to post.
Re: trueblood 2 seasons, multiple disks, multiple drives same failures
#2 Post by dcoke22 » Sun Nov 02, 2025 5:06 pm
Errors like this:
mean that the drive was unable to correctly read a spot on the disc. The standard advice is to gently clean the disc and try again.
A regular disc player, like your Sony, is designed to ignore read errors and hope that you don't notice the visual or audio glitch that results.
icbm1
#3 Post by icbm1 » Mon Nov 03, 2025 12:11 am
Yeah that is why I posted everything I found said that also.
But to have the same behavior on 10 disks (and I did wipe them but didn't go as far as soap & water), on 2 different drives, same behavior other blu rays don't have the same issue.
It just felt statistically odd. I didn't know if this was done intentionally as some sort of extra copy protection. When I tried it on my linux machine I see all the teltail read issues in dmesg,
It just statistically feels unlikely,
These are older disks, I don't recall know exactly when, but they are probably 10 years old. Is diskrot a thin with HBO BluRays?
icbm1
#4 Post by icbm1 » Tue Nov 25, 2025 4:31 pm
Went out and bought the same season brand new, and it ripped just fine. So they must just be bad disks as everyone pointed out. Just crazy that all the disks would be bad.
