Verbatim 43888 no longer reads any discs
MashBasher69
Post by MashBasher69 »
about 2 months ago I got into ripping movies for my plex server. It's been going fine until about a week ago when I tried to rip Regular Show The Complete Series. I got through season1-4 fine but then it wouldn't recognise discs 1 and 3 for season 5. After that my drive seemed to stop reading all discs, whether it be ones that worked before or some new ones I got. Does anyone know a fix or is my drive defective?
Wldulikesometoast
Re: Verbatim 43888 no longer reads any discs
Post by Wldulikesometoast »
This has happened to me too, in six weeks rather than eight...must be trash drives I guess bud ...I'm trying to get a refund and pivot to a different drive
MashBasher69 wrote: Sun Nov 02, 2025 12:56 pm about 2 months ago I got into ripping movies for my plex server. It's been going fine until about a week ago when I tried to rip Regular Show The Complete Series. I got through season1-4 fine but then it wouldn't recognise discs 1 and 3 for season 5. After that my drive seemed to stop reading all discs, whether it be ones that worked before or some new ones I got. Does anyone know a fix or is my drive defective?
You could try cleaning the lasers. Very easy to do on the those. Also, sometimes they get themselves confused and need a complete power down for a few minutes and then restart to get them back to normal.
MashBasher69
Hi, thanks for the reply. What is your recommended way of cleaning the laser? I've left the drive completely unplugged over night and that doesn't seem to have done anything.
MashBasher69 wrote: Mon Nov 03, 2025 10:03 am Hi, thanks for the reply. What is your recommended way of cleaning the laser? I've left the drive completely unplugged over night and that doesn't seem to have done anything.
Usually a q-tip with some alcohol. There's a couple of threads mentioning how to clean them if you do a search.
MashBasher69
hi, sorry this reply has took sooo long. cleaning it didn't seem to work. I've returned it and got a refund. I'm not sure what drive to replace it with?
