Public KeyDB Disc Submissions
Tariphor
Post by Tariphor »
Disc type: UHD
Disc dump filename: MKB20_v82_Pearl_A208.tgz
Drive: LG BU40N
Drive firmware: BU40N 1.03
Did you sync the public keydb within the last 15 minutes?: Yes
Have you verified that all submission links are accessible in incognito/private browsing?: Yes
Disk dump link: https://drive.google.com/file/d/1WpFo11 ... sp=sharing
Thank you!
nyva95
Post by nyva95 »
Hi!
Thanks for all your hard work <3 Hope you can help me with this :)
https://drive.google.com/file/d/1W5GWYK ... sp=sharing
koberulz
Post by koberulz »
koberulz wrote: Fri Oct 31, 2025 5:36 pm The Pleasure Garden: https://drive.google.com/file/d/166KgvT ... sp=sharing
This now opens in MakeMKV, but not in VLC. I don't get an error in VLC, it just loads infinitely. Is that because MakeMKV is using the public KeyDB, but VLC isn't?
tommik128
Post by tommik128 »
keydb_helper wrote: Sat Nov 01, 2025 10:29 pm AACS1.0 discs can still be processed and submitted to the keydb when the disc dump is in the 50-150KB range but this is only possible because the full AACS1.0 MKB_RO.inf file is present within the disc dump.
The main reason I asked because I can see people posting separate MKB_RO.inf files on AACS1.0 blu-rays here and apparently that is not needed at all!
Or should I compare the files between a dump and a disc if they are the same size? Is there any reason at all?
ictbydesign
MKB20_v82_Den_of_Thieves_Pantera_0FBC.tgz
Post by ictbydesign »
emailed dump file to Mr Penguin
99gagamel
Post by 99gagamel »
Nicht in DB:
Woodoo - Die Schreckensinsel der Zombies UHD (.tgz)
99gagamel
Post by 99gagamel »
Nicht in DB
Manta Manta Teil 1 UHD (nur 2 ist drin)
chucky527c
Post by chucky527c »
Cheech & Chong's Last Movie 4K UHD (US) (Steelbook)
MKB20_v82_Cheech_and_Chong's_Last_Movie_80E8
https://drive.google.com/file/d/1zKVrfX ... drive_link
chucky527c
Hard Boiled 4K UHD (US) - Bonus Disc
MKB_v82_Hard_Boiled_Bonus_Disc_D08E
https://drive.google.com/file/d/1vYjIVX ... drive_link
user76419
Post by user76419 »
Disc type: UHD
Disc dump filename: MKB20_v77_DD_HONOR_AMONG_THIEVES_6E45.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.02
Disc dump link: https://www.mediafire.com/file/xxwvyqlh ... 5.tgz/file
Thank you!
SFD136
Post by SFD136 »
Disc type: BD-ROM
Disc dump filename: MKB_v82_FEAR_AND_DREAMS_EASON_CHAN_D1_0C72.tgz
Drive: BUFFALO Optical Drive (Marketing Model Name: BDXL-PTV6U3-BKB / Drive Platform: MT1959)
Drive firmware: BN14
Disc dump / MKB_RO.inf link: https://www.mediafire.com/file/69ewk61uwv43ofa/
Disc type: BD-ROM
Disc dump filename: MKB_v82_FEAR_AND_DREAMS_EASON_CHAN_D2_4DEE.tgz
Disc dump / MKB_RO.inf link: https://www.mediafire.com/file/1r31p7xk3rpe5ke/
The drive I used is quite rare in this forum, and I am not so sure whether the dump is valid for submission. Thanks in advance.
chucky527c
Shin Godzilla 4K UHD (Limited Edition) (US)
Color Blu-Ray: MKB_v82_SHIN_GODZILLA_D670
https://drive.google.com/file/d/1KaKQ5o ... sp=sharing
Orthochromatic Blu-Ray: MKB_v82_SHIN_GODZILLA_D84E
https://drive.google.com/file/d/1yBpGBg ... sp=sharing
SFD136 wrote: Mon Nov 03, 2025 3:20 pm Disc type: BD-ROM
Disc type: BD-ROM
There is a high chance that your drive is not libredrive enabled if you have this firmware. Check your Makemkv info if it says libredrive enabled. If not your links are useless since bus encrypted. Then flash your drive with LG BU40N firmware. Afterwards post new dumps.
defaultjovi
Post by defaultjovi »
Hello! I tried ripping these two discs, they still seem unsupported
Avengers 4k UHD (FR)
Avengers Age of Ultron 4k UHD (FR)
MKVDUDE
Post by MKVDUDE »
Disc type: BD-ROM
Disc dump filename: MKB_v82_JIM_HENSONS_THE_STORYTELLER_1600.tgz & MKB_v82_THE_STORYTELLER_GREEK_MYTHS_125C.tgz
Drive: BD-RE HL-DT-ST BD-RE BU40N 1.03 MO9L5U82152d/ Drive Platform: MT1959)
Drive firmware: 1.03
Disc dumps link: https://we.tl/t-N088o8r3kO
Many thanks!
