Twilight Breaking Dawn Part 1
AndroidXS
#1 Post by AndroidXS » Sun Feb 12, 2012 4:09 am
It looks like Breaking Dawn Part 1 has some serious copy protection on it. When I scan the disc, it shows that there are over 30 versions of the movie, all the same size, which is impossible.
Has anyone figured out which is the correct title yet?
Screenshot:
http://i.imgur.com/u3uKt.png
AndroidXS
Re: Twilight Breaking Dawn Part 1
#2 Post by AndroidXS » Sun Feb 12, 2012 5:29 am
I believe I have figured out the correct sequence of segments..
None of the titles have numbers, but you can click on each one until you see "Source file name: 00689.mpls" (it's the 15'th from the bottom).
Title information
Name: Twilight Saga: Breaking Dawn - Part 1 Blu-ray™ (English)
Duration: 1:57:08
Chapters count: 17
Segment count: 14
Segment map: 509,505,511,501,507,503,512,508,504,514,502,513,510,506
File name: t60_Twilight_Saga_Breaking_Dawn_-_Part_1_Blu-ray.mkv
http://i.imgur.com/yQ75K.png
Good Luck!
crowfax
#3 Post by crowfax » Sun Feb 12, 2012 6:47 am
Thanks for taking the time to post.
Movie studios making a bunch of different playlists is a minor annoyance at best.
crazyn15
#4 Post by crazyn15 » Tue Feb 14, 2012 12:27 am
I was wondering why with this movie, it deosnt have any DTS AUDIO?? Is there a way i can extract the DTS AUDIO?
NutFlush920
#5 Post by NutFlush920 » Tue Feb 14, 2012 8:13 pm
I just selected the first one in the list and it worked fine.
What is the difference if you select the first or 15th one?
crowfax
#6 Post by crowfax » Tue Feb 14, 2012 9:28 pm
NutFlush920 wrote:What is the difference if you select the first or 15th one?
The disc manufacturer has put multiple versions of the movie on the disc. Only one of them will have the scenes in the right order, the rest will be out of sequence.
It's a (rubbish) form of copy protection.
I've read reports saying 504.mpls is the right playlist as well. Make sure you check your rips!
NutFlush920
#7 Post by NutFlush920 » Tue Feb 14, 2012 10:22 pm
Not even sure which one I ripped other then knowing it was the first one on the list. LOL
I'll have to check again tonight after work.
crazyn15
#8 Post by crazyn15 » Tue Feb 14, 2012 10:50 pm
WHERE CAN I FIND THE DTS AUDIO?
NutFlush920
#9 Post by NutFlush920 » Tue Feb 14, 2012 11:24 pm
crazyn15 wrote:WHERE CAN I FIND THE DTS AUDIO?
Looks like it only has Dolby Digital 5.1 no DTS unless I'm missing something. Not at home to check my disc so just going off screen shots above.
crazyn15
#10 Post by crazyn15 » Wed Feb 15, 2012 6:02 pm
anything??
NutFlush920
#11 Post by NutFlush920 » Wed Feb 15, 2012 8:56 pm
crazyn15 wrote:anything??
I didn't have time last night. I'll check right away when I get home tonight to see what I have.
crowfax
#12 Post by crowfax » Wed Feb 15, 2012 10:18 pm
It seems from reading other forums that the rental edition does not have the DTS-HD audio track.
fuzzybee
#13 Post by fuzzybee » Wed Feb 15, 2012 11:07 pm
I can't seem to get to the point of looking at the playlists - every time I try to rip it, it gives me a "backup failed" when it started to copy the first .jar file.
bweston1
#14 Post by bweston1 » Wed Feb 15, 2012 11:19 pm
AndroidXS wrote:I believe I have figured out the correct sequence of segments..
Title information
Duration: 1:57:08
Chapters count: 17
Segment count: 14
Good Luck!
Has anyone confirmed that this has to correct sequence of segments?
deanhatescoffee
#15 Post by deanhatescoffee » Thu Feb 16, 2012 7:34 am
bweston1 wrote: Has anyone confirmed that this has to correct sequence of segments?
I can confirm that 00689.mpls / t60 is indeed the correct file.
FWIW, I couldn't even watch this via the Bluray disc. It wouldn't work in CyberLink PowerDVD 9 or DAPlayer. It's pretty sad when the disc makers actually create reasons for people to rip their discs when their goal is the exact opposite.
