Post by Billycar11 » Thu Oct 30, 2025 10:49 am
finnishrider wrote: Wed Oct 29, 2025 10:25 pm is this possible to flash with a working firmware for UHD discs?
Station information
Operativsystemets stasjons navn: E:
Produsent: PIONEER
Produkt: BD-RW BDR-UD03
Revisjon: 1.14
Serienummer:
Firmware dato: 2020-06-15
Krypteringsflagg for databus: 1B
Høyeste AACS versjon: 81
Drive platform: RS8511
Firmware version: 1.14
Sure email me that drive info section see below for email
Spycrowsoft
Post by Spycrowsoft » Fri Oct 31, 2025 10:48 am
Spycrowsoft wrote: Mon Oct 20, 2025 8:39 am
Billycar11 wrote: Thu Oct 16, 2025 6:09 pm
Spycrowsoft wrote: Thu Oct 16, 2025 5:11 pm Since @Billycar11 offers to check...
I have a Verbatim 43888 slim drive with the following MakeMKV drive information:
OS device name: G:
Product: BD-RE BU40N
Revision: 1.05
Serial number: <redacted>
Highest AACS version: 68
Disc Information
Label: DR_STRANGELOVE
Timestamp: 2020-01-17 11:00:31
Protection: AACS2.0/C v68
Data capacity: 58.69 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
So if I understood the video correctly this is the command I need:
makemkvcon64.exe f --all-yes -d <drive letter> rawflash enc -i <path to LG slim BU40N folder>\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Is that correct for this drive?
yeah looks fine
Thanks for your faster than expected reply.
Unfortunately I did not get around to flashing this drive because it failed to burn BD-RE-DL and BD-RE-TL discs in my initial sanity test, so the drive is being returned as DOA. I'll check back in later when I have a replacement, but at least now I know what to do.
Got a replacement drive of the exact same type and it passed all my burning and reading tests.
Flashing went off without any problems and it's now backing up Dr. Strangelove in glorious 4KUHD just fine.
oranje
Post by oranje » Fri Oct 31, 2025 1:18 pm
This is a great resource. Will Pioneer models ever be added to this?
Post by Woodstock » Fri Oct 31, 2025 2:59 pm
Considering that half the post that starts this topic refers to Pioneer drives, what is your question?
oranje
Post by oranje » Fri Oct 31, 2025 4:17 pm
Woodstock wrote: Fri Oct 31, 2025 2:59 pm
Sorry, still learning the terminology. I mean cross-flashing Pioneer models that weren't originally UHD drives (e.g., XS05).
nicholfd
Post by nicholfd » Fri Oct 31, 2025 4:25 pm
It's unfortunate, but way to many people come to forums like this & start on the last page/post...
Post by dcoke22 » Fri Oct 31, 2025 9:14 pm
oranje wrote: Fri Oct 31, 2025 4:17 pm Sorry, still learning the terminology. I mean cross-flashing Pioneer models that weren't originally UHD drives (e.g., XS05).
As I understand it currently, the tools to cross flash a Pioneer drive are not currently public. I don't know if they'll ever be made public.
MakeMKV's author, Mike, has stated that eventually LibreDrive will be supported on most Pioneer drives. https://forum.makemkv.com/forum/viewtopic.php?p=174108#p174108
Having LibreDrive support doesn't necessarily mean cross flashing support.
walk2k
Post by walk2k » Fri Oct 31, 2025 10:27 pm
Hi all. new to all this, just wanted to report success. I recently purchased an external LG drive (LG BP50NB40 purchased from Best Buy on 10/27/25 for about $91). it has a manuf'd date of May 2025 and came with (if I remember) firmware version 1.04.
I followed the directions here, first flashed it to version "BP50NB40-NB50-1.03MK" then to > "BP60NB10 1.02MK"
the drive in makemkv says it's on version "1.03" but it does report LibreDrive "Patched (microcode access re-enabled)" and "Yes" for all the options.
I haven't tried any UHD discs yet (because I don't have any) but it does work fine with 1080p Blu-ray, as well as DVD and CD. Oh, and if anyone knows how to rip SA-CD (yes those) let me know.. I tried a few different programs but none work..
I've recently installed a NAS, the UGreen 4300, and it's great. The HDMI out unfortunately doesn't support some BD formats (VC-1) so those won't play, but using Jellyfin works great. I actually love Jellyfin right now, and I've never used a NAS or done anything like that before..
On a side note, since I intend to rip all of my old DVDs (about 200) and my music CDs (almost 1000) again, this time in FLAC.. I figured I would dig out an old DVD drive (internal SATA) from storage and hook it up for burning those. I only have about 20 BDs so the LG drive will be ok for those, but ~1200 discs is a lot of usage on what seems like a pretty flimsy thing..
WELL you know how they tell you if you have a modular power supply in your PC, ONLY use the power cables that came with the unit, and not any other brand, or unknown cables? I mean, it's a Molex/SATA cable, how different can they be? OOPS. I apparently let the magic smoke out, totally fried the SATA interface board on this old Asus drive (crispy noises and flashes of light).. so I guess I won't be using that... :shock:
goestoeleven
Post by goestoeleven » Fri Oct 31, 2025 10:34 pm
Hi gang. Newb here and very late to the party. There are hundreds of pages here, so I hope you'll forgive the question and help a brother out:
Just picked up an LG drive from OWC. It's not currently reading UHD disks, even though the techs there said it could.
Here's what MakeMKV is reporting:
Product: BD-RE BH16NS40
Revision: 1.05
Firmware date: 2120-05-06 13:31
Highest AACS version: 81
Harware support: Yes
Firmware support: No
Firmware version: 1.05
Out of the box it can read BD Audio disks, but it can't see UHD disks. It also seems to not be able to read the MLP tracks on DVD-Audio disks (just the DD content). Is there a firmware I can use to make both UHD and DVD-A ripping possible?
I'm reasonably technical and can follow a procedure if I've got the right tools.
Thanks in advance for your help!
Post by MartyMcNuts » Fri Oct 31, 2025 10:52 pm
walk2k wrote: Fri Oct 31, 2025 10:27 pm Hi all. new to all this, just wanted to report success. I recently purchased an external LG drive (LG BP50NB40 purchased from Best Buy on 10/27/25 for about $91). it has a manuf'd date of May 2025 and came with (if I remember) firmware version 1.04.
If ist still shows in MakeMKV as BP50NB40 1.03 firmware, then you haven't done the cross-flash correctly. It should say BP60NB10 1.02. As is, it will not work with UHD discs as the BP50NB40 firmware is not UHD compatible. Libredrive does not mean UHD compatible.
Post by Billycar11 » Fri Oct 31, 2025 11:58 pm
goestoeleven wrote: Fri Oct 31, 2025 10:34 pm Hi gang. Newb here and very late to the party. There are hundreds of pages here, so I hope you'll forgive the question and help a brother out:
Revision: 1.05
see post 1
or email me or marty for an auto flasher
goestoeleven
Post by goestoeleven » Sat Nov 01, 2025 12:19 am
email sent. thank you!
oranje
Post by oranje » Sat Nov 01, 2025 1:29 pm
dcoke22 wrote: Fri Oct 31, 2025 9:14 pm
I see. Thanks for the info.
Th3Color
Post by Th3Color » Sat Nov 01, 2025 2:36 pm
Hello all,
I have a problem in that my drive simply won't work with 4K discs. It reads all other types, but not 4K discs.
It also disconnects from the PC briefly every time it tries to read the disc. Could this be another problem? However, this only happens with 4K discs.
Here is the mkv information:
OS device name: E:
Revision: 1.03
Serial number: MO9P6390032
Highest AACS version: 18
Firmware version: 1.03
walk2k
Post by walk2k » Sun Nov 02, 2025 1:17 am
MartyMcNuts wrote: Fri Oct 31, 2025 10:52 pm
THANKS for your reply! I tried flashing it 2 more times, with 1.02 and 1.00. The drive light doesn't blink when doing it, though the flasher tool says everything's normal.. After power cycling the drive it still reports 1.03.. What could this mean?
