Aacs v82 help.
Aacs v82 help.
So I was trying to rip a brand new just released Blu-ray disc of Naruto Shippuden set eight. It turns out it uses the copyright protection thing whatever. It's called aacsv82 so it won't do it because I guess it doesn't support it or it can't decrypt it or something so I emailed the svq@makemkv.com with a file attached because I was told through the form that that was the file but I just want to double-check and confirm this because if I send them the wrong file then that's a problem. I sent them the .tgz file or more accurately MKB_v82_Naruto_Shippuden_193_-_199_3880.tgz so I don't know if I sent them the right file and if not I would really like to be informed please. Thanks to anyone who can help
Re: Aacs v82 help.
Emailing the .tgz file to svq@makemkv.com is the right thing to do.
Re: Aacs v82 help.
Okay thank you! I appreciate the help
