Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
If assistance is still available - will this drive work?
Manufacturer: PIONEER
Product: BD-RW BDR-XU03
Revision: 1.03
Serial number: ODDL002559UC
Firmware date: 2015-06-29
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8520
Firmware version: 1.03
Revision: 1.03
No known firmware I have.michaelb7 wrote: Tue Oct 21, 2025 8:33 pm If assistance is still available - will this drive work?
Revision: 1.03
What drive model is this??michaelb7 wrote: Tue Oct 21, 2025 8:33 pm If assistance is still available - will this drive work?
Revision: 1.03
BDR-XU03 It is a slot loading portable. Seems to have the same firmware as other models, so I was hopeful...
Whitebeard96
Got a new drive, really like to allow READING uhd with this one as well. Can I use same FW as with BDR-UD03?
New drive:
Laufwerksinformation
OS-Gerätename: O:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer:
Firmware-Datum: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
New drive:
OS-Gerätename: O:
Produzent: PIONEER
Revision: 1.14
Serienummer:
Whitebeard96
is there no possible way to get it done
, might have to buy the 4k model then
Yes it can be done. PM sent.Whitebeard96 wrote: Sun Oct 26, 2025 7:37 pm is there no possible way to get it done, might have to buy the 4k model then
Could I get help with this one? Thanks
OS device name: /dev/sr0
Current profile: DVD-ROM
Product: BD-RW BDR-UD03
Revision: 1.10
Serial number:
Firmware date: 2017-04-18
Highest AACS version: 77
Firmware version: 1.10
Hi, can some one help me with this drive? Thanks
OS-Gerätename: H:
Produzent: PIONEER
Revision: 1.11
Seriennummer: XXXXXXXXXXXX
Firmware-Datum: 2018-11-28
Makierungen der Bus-Verschlüsselung: 1B
Firmware version: 1.11
OS-Gerätename: H:
Produzent: PIONEER
Revision: 1.11
PM sent.Bubble221 wrote: Wed Oct 29, 2025 4:57 pm Hi, can some one help me with this drive? Thanks
OS-Gerätename: H:
Produzent: PIONEER
Revision: 1.11
Helllo there. I got a bit nervous when I heard, that production of uhd devices stopped and wanted to look, which one I could buy. Now I am happy to see that the drive I already own could maybe upgraded. Can you help me too?
Revision: 1.11
Serial number:
Firmware date: 2018-11-28
Revision: 1.11
Serial number:
Hi!
I recently bought a Pioneer BDR-UD03 drive (for $15), and I’d really appreciate some help with patching or flashing it so that it can read UHD Blu-rays and work in LibreDrive mode (for MakeMKV).
I’ve read a bit about the different firmware versions and patches, but I’m not sure which tools or steps are safe to use for this specific model. If anyone has experience with this drive or can point me to a reliable guide or firmware, that would be great.
Thanks in advance for any help or advice!
OS device name: H:
Revision: 1.03
Serial number:
Firmware date: 2015-05-14
Drive platform: RS8510
Firmware version: 1.03/ID19
Unrestricted read speed: YesRe: Pioneer BDR-UD03 UHD possibility
PM sent.scav666 wrote: Sun Nov 02, 2025 7:00 pm Hi!
Drive Information OS device name: H: Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.03 Serial number: Firmware date: 2015-05-14 Bus encryption flags: 1B Highest AACS version: 77 LibreDrive Information Status: Enabled Drive platform: RS8510 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.03/ID19 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
push?mango7972 wrote: Wed Oct 29, 2025 8:07 am Could I get help with this one? Thanks![]()
Drive Information OS device name: /dev/sr0 Current profile: DVD-ROM Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.10 Serial number: Firmware date: 2017-04-18 Bus encryption flags: 1B Highest AACS version: 77 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.10 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
PM sent.mango7972 wrote: Mon Nov 03, 2025 11:47 ampush?mango7972 wrote: Wed Oct 29, 2025 8:07 am Could I get help with this one? Thanks![]()
