Backup is grayed out for Psycho 50th Anniversary Blu-ray
mattmann
Post by mattmann »
I'm am using the evaluation version on Ubuntu Linux. When I open my Psycho 50th Anniversary Blu-ray disc, the Backup icon is grayed out. Is that only available with a registration code?
crowfax
Re: Backup is grayed out for Psycho 50th Anniversary Blu-ray
Post by crowfax »
The backup option is available to everyone while MakeMKV is in beta. It only works on blu-ray discs however, and is only lit-up before you press the "big" button.
Can you post a screenshot of the disc in the drive with the button greyed out?
mrdrummond
Post by mrdrummond »
Here you go
This one is from me.
This disk crashes makemkv (total graceless crash)
One suggestion elsewhere was to do a full disk backup but that doesn't appear to be an option.
can't attach the screenshot (board attachment quota has been reached error).
But its showing a bluray disk in the center box and the button is greyed out.
Do you have debug logging turned on? If so, what does the log show? (you can copy/paste the information into a reply, rather than bothering with an attachment)
mrdrummond
I was trying to put a screenshot showing the full disk backup doesn't work.
But the graceless crash output is below.
Its complaining the disk has errors but it plays fine.
However, irrelevant of that the program shouldn't just crash it should report an error and abort.
Is there a way of getting it to keep the file after it fails. Its clearly getting most of the way through the file.
Output of crash below
Debug log started at Sat May 28 02:00:32 2016 , written by MakeMKV v1.9.10 darwin(x86-release)
001005:0000 MakeMKV v1.9.10 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/gsa/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL HL-DT-ST DVDRW GA32N KE06d" opened in OS access mode.
002010:0000 Optical drive "BD-RE TSSTcorp BDDVDW SE-506CB TS00d" opened in OS access mode.
DEBUG: Code 2147483648 at \@%sryo|/N:Wmp?4:121265315
DAFD=PAAAADAAAAEABDQkEHwECAQ==
DCE=Co4whtRMbX78OAvuizm70nn6c6g9ERWNRGkJ5eW1j+ZiDaVQc3ZpItC/4eoet20wJNCF1DpjXYLkadFwCQ5vDky0zamxM1Xnzmd5GKVbgnluCYFpuJ8EyZQt+Nn3LVzSRPuJ7Khq3NrdqlPb7wKbfG1udKJyenS3zQ==
DCE=bO7FfISzyVCpgyYcWkd/bFu6owRtmGDn79YnGm3ZIJ2YsqNS1czM9x/KBwC7bP9PZBd/O+HRL5jyo/wVPQlah2KJvt5MyMHsd80rDKcia7pq+0/e6fl/YLj1zGDHPbZW9iXSbdFBMZ34bBeCazDF+cSlsbcKYSSkjQ==
003317:0000 Loaded 112 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/00000.svq
SVQ: generic005 builtin/00000.svq
003328:0000 BD+ code processed, got 1 FUT(s) for 1 clip(s)
DISCID=6FE64C6332B8B45977FC400F71D1410013066C12
003307:0000 File 00013.mpls was added as title #0
003025:0000 Title #00012.mpls has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00054.mpls was added as title #1
003307:0000 File 00055.mpls was added as title #2
003307:0000 File 00056.mpls was added as title #3
003307:0000 File 00057.mpls was added as title #4
003025:0000 Title #00014.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00018.m2ts was added as title #5
003307:0000 File 00040.m2ts was added as title #6
003307:0000 File 00041.m2ts was added as title #7
003025:0000 Title #00042.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00043.m2ts has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00044.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00045.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00046.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00047.m2ts has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00048.m2ts has length of 58 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00049.m2ts was added as title #8
003307:0000 File 00050.m2ts was added as title #9
003307:0000 File 00051.m2ts was added as title #10
003307:0000 File 00052.m2ts was added as title #11
003307:0000 File 00053.m2ts was added as title #12
003025:0000 Title #00012.m2ts has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00208.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /Volumes/Lacie01-12/RippingMedia/mkv
tp=ZeNpjYBgYwNEpxEKpfgAuQgFP
001003:0020 DEBUG: Code 0 at :Etg}tshH7JYI{stw<}i:121262647
tp=ZeNpjYBg4wNEpxEKpfgAuRgFP
004004:0000 The source file '/BDMV/STREAM/00013.m2ts' is corrupt or invalid at offset 27950505984, attempting to work around
tp=ZeNpjYCAPcHQKsTBQAKihHwCDpQH2
tp=ZeNpjYCAfcHQKsTAMsH4Ag6kB9g==
... repeated error messages removed to save the reader.
004004:0000 The source file '/BDMV/STREAM/00013.m2ts' is corrupt or invalid at offset 27950585856, attempting to work around
tp=ZeNpjYCAP/P//n4GNw4CBgcOPgUOTgSELKMZcAhTk2B6EpIyJg5GBQQZZ4wMGhudOZ8M4OoVYGCgAIP0AtKAMVA==
tp=ZeNpjYCAf/P//n4GNw4CBgcOPgUOTgSELKMZcAhTk2B6EpIyJg5GBQQZZ4wMGhudOZ8M4OoVYKLCeAaQfALSkDFQ=
tp=ZeNpjYCAPcHQKsTBQACjV////fwYAirkETA==
tp=ZeNpjYCAfcHQKsTAMoP7///8zAACKvQRM
tp=ZeNpj4PBj4NBkYMhmYGBgLvv/n4FjezADAjBJMQgwyDCgABmlgvU7OTqFWBgoANTQDwDV3QjP
tp=ZeNpj4zBgYODwY+DQZGDIZmBgYC77/5+BY3swAwIwSTEIMMgwoAAZpYL1Ozk6hVgYKADU0A8ABAgJDQ==
004004:0000 The source file '/BDMV/STREAM/00013.m2ts' is corrupt or invalid at offset 27950635008, attempting to work around
tp=ZeNpjYCAPcHQKsTBQAP7//8/AxmEANMiPgUOTgWENUIx5H1CQY/tsJGVMHIwMDDLIGh8wMNiy+wuC7AcAOHcLgQ==
tp=ZeNpjYCAfcHQKsVCgneH///8MbBwGQIP8GDg0GRjWAMWY9wEFObbPRlLGxMHIwCCDrPEBA4Mtu78gyH4AOHsLgQ==
tp=ZeNpjYCAP/P//n4GNw4CBgcOPgUOTgWEtUIx5P1CQY/scJGVMUgwCDDKoWmU0vWfOJmR+A5jkAFoEpBixqwEAtcoMHw==
tp=ZeNpjYCAf/P//n4GNw4CBgcOPgUOTgWEtUIx5P1CQY/scJGVMUgwCDDKoWmU0vWfOJmR+A5jkAFoEpBixqwEAtc4MHw==
tp=ZeNpjYIAAy8+7VjGQADg6hVgYKADU0A8ATJ4Ehg==
tp=ZeNpjYEAAy8+7VjGQADg6hVgYKADU0A8ATKIEhg==
tp=ZeNpj4PBj4JBkAAPm/dWzQPS2rLeTISIMTByMDAwyDEjgAQND85aV8zk6hVgYKADU0A8Ar+0Kag==
tp=ZeNpj5jBgYODwY+CQZAAD5v3Vs0D0tqy3kyEiDEwcjAwMMgxI4AEDQ/OWlfM5OoVYGCgA1NAPANvJCqU=
tp=ZeNpjYCAPcHQKsTBQAP7//8/AxmEANMiPgUOTgWEdUIz5AFCQY/tcJGVMHIwMDDLIGh8wMPQarOUB2Q8AP0kMWQ==
tp=ZeNpjYCAfcHQKsVCgneH///8MbBwGQIP8GDg0GRjWAcWYDwAFObbPRVLGxMHIwCCDrPEBA0OvwVoekP0AP00MWQ==
tp=ZeNpjYCAP/P//n4GNw4CBgcOPgUOTgWE9UIz5IFCQY/s8JGVMUgwCDDKoWmVC7TfGcnQKsTBQAED6AbbiC+U=
tp=ZeNpjYCAf/P//n4GNw4CBgcOPgUOTgWE9UIz5IFCQY/s8JGVMUgwCDDKoWmVC7TfGcnQKsVBgPQNIPwC25gvl
tp=ZeNpj4PBj4JBkAAPmg9VzQHSCya8FEBEGJg5GBgYeBiSQwMAQ1cP0jKNTiIWBAkAN/QC7VAi7
tp=ZeNpj5jBgYODwY+CQZAAD5oPVc0B0gsmvBRARBiYORgYGHgYkkMDAENXD9IyjU4iFgQJADf0A5zAI9g==
004004:0000 The source file '/BDMV/STREAM/00013.m2ts' is corrupt or invalid at offset 27950641152, attempting to work around
tp=ZeNpjYCAPcHQKsTBQAP7//8/AxmEANMiPgUOTgWEDUIz5EFCQY/t8JGVMHIwMDDLIGh8wMBy/1+UKsh8ARz4NXQ==
tp=ZeNpjYCAfcHQKsVCgneH///8MbBwGQIP8GDg0GRg2AMWYDwEFObbPR1LGxMHIwCCDrPEBA8Pxe12uIPsBR0INXQ==
tp=ZeNpjYCAP/P//n4GNw4CBgcOPgUOTgWEjUIz5MFCQY/sCJGVMUgwCDDKoWmXmCk4V4ugUYmGgAID0AwClGQue
tp=ZeNpjYCAf/P//n4GNw4CBgcOPgUOTgWEjUIz5MFCQY/sCJGVMUgwCDDKoWmXmCk4V4ugUYqHAegaQfgClHQue
tp=ZeNpj4PBj4JBkAAPmw9XzQLRm2VJfiAgDEwcjA4MMAxJ4wMCgqDvjE0enEAsDBYAa+gGrxAi8
tp=ZeNpj5jBgYODwY+CQZAAD5sPV80C0ZtlSX4gIAxMHIwODDAMSeMDAoKg74xNHpxALAwWAGvoB16AI9w==
tp=ZeNpjYCAPcHQKsTBQAP7//8/AxmEANMiPgUOTgWETUIz5CFCQY/tCJGVMHIwMDDzIGhMYGM6FZjKC7AcAO7UL7A==
tp=ZeNpjYCAfcHQKsVCgneH///8MbBwGQIP8GDg0GRg2AcWYjwAFObYvRFLGxMHIwMCDrDGBgeFcaCYjyH4AO7kL7A==
tp=ZeNpjYCAP/P//n4GNw4CBgcOPgUOTgWEzUIz5KFCQY/siJGVMUgwCDDKoWmU46tPDOTqFWBgoACD9AKJQC5Q=
tp=ZeNpjYCAf/P//n4GNw4CBgcOPgUOTgWEzUIz5KFCQY/siJGVMUgwCDDKoWmU46tPDOTqFWCiwngGkHwCiVAuU
tp=ZeNpj4PBj4JBkAAPmo9ULQPQX1xQDiAgDEwcjA4MMAxJ4wMBgs+iUPEenEAsDBYAa+gHPfgjr
tp=ZeNpj5jBgYODwY+CQZAAD5qPVC0D0F9cUA4gIAxMHIwODDAMSeMDAYLPolDxHpxALAwWAGvoB+1oJJg==
tp=ZeNpjYCAPcHQKsTBQAP7//8/AxmEANMiPgUOTgWELUIz5GFCQY/tiJGVMHIwMDDLIGh8wMGhcr+EC2Q8AQsoMeg==
tp=ZeNpjYCAfcHQKsVCgneH///8MbBwGQIP8GDg0GRi2AMWYjwEFObYvRlLGxMHIwCCDrPEBA4PG9RoukP0AQs4Meg==
tp=ZeNpjYCAP/P//n0Fv8wGPJbPXFleqV39RX33jzJd7e+bYcc9JYheapmJimTBh04XzspvP9m4uXcYxNWFeaHJzZMttjjeB+zyOJjYFp8nfq7rjEn1udrZUHteSi1oTbxj+OrjmtIvpr+in51sXWFxb+MjZgLPg68GlMsGqJ4s4Tj13ePxupsqKDvHj6x9ePuBgI/ISAPeQRTE=
tp=ZeNpjYCAf/P//n0Fv8wGPJbPXFleqV39RX33jzJd7e+bYcc9JYheapmJimTBh04XzspvP9m4uXcYxNWFeaHJzZMttjjeB+zyOJjYFp8nfq7rjEn1udrZUHteSi1oTbxj+OrjmtIvpr+in51sXWFxb+MjZgLPg68GlMsGqJ4s4Tj13ePxupsqKDvHj6x9ePuBgI/ISAPeURTE=
tp=PoSIaynoRbbMKuI43bo6qO2GtGMngfIGkkEmjg80z81DpM7OZAt75WuOfIiAarvP+SE+c2bnE+BD+LOhQfFJVXaxlWDs/V3ybKEsAunSH21IwPsy+duy56RtWOTVfwu0F9jVLx8rAnF9JrXNWnko2Yu3tJl8qFHJr0GpyBS11MpVxEJh9XJ8Lypxu8PYKAFYJbf2vPnA5uxy7ZS8ittK8782vSTDY5k/Q2fDMrQy+ALhRyKSK8nplStPuN+Y=
tp=Pi7mByKEiGsp6EW2zCriON26OqjthrRjJ4HyBpJBJo4PNM/NQ6TOzmQLe+VrjnyIgGq7z/khPnNm5xPgQ/izoUHxSVV2sZVg7P1d8myhLALp0h9tSMD7MvnbsuekbVjk1X8LtBfY1S8fKwJxfSa1zVp5KNmLt7SZfKhRya9BqcgUtdTKVcRCYfVyfC8qcbvD2CgBWCW39rz5wObscu2UvIrbSvO/Nr0kw2OZP0NnwzK0MvgC4UcikivJ6ZUrT7jfm
tp=PX5ff3z+9a6pVjIrnY0XkgeLqB3rDYpPOxxjMXwnvPvA18JxG0AYmGOl50dA3j243/UIYOscSS8AxD9jRmUTi3nra8PVqXvftalAssY0avTOdQ+bAZg+7CEVDJKzIHRze2vnBaw2WG3Wl7G/C7SIC11YhdEtb5n2YJ1JKr5BA5dp0MkbfSLnA45dHx6tAhAUTV15webHZidGj+QHP9BrixWH3XR/4ad29UE6vbjpA0gJlRfgx4TXyb1S+Mz0=
tp=PtBUJMV+X398/vWuqVYyK52NF5IHi6gd6w2KTzscYzF8J7z7wNfCcRtAGJhjpedHQN49uN/1CGDrHEkvAMQ/Y0ZlE4t562vD1al737WpQLLGNGr0znUPmwGYPuwhFQySsyB0c3tr5wWsNlht1pexvwu0iAtdWIXRLW+Z9mCdSSq+QQOXadDJG30i5wOOXR8erQIQFE1decHmx2YnRo/kBz/Qa4sVh910f+GndvVBOr246QNICZUX4MeE18m9UvjM9
tp=P2Y5kYg6nfferLdGBc9LoN/z3Pi0TKy+LpbVrPwReGHQk78lwPB7iAfn4xC28Ml3eSBk0gBhkjSK94PW/8/rsN1Z8Z23Y9W6MzXMFLuMuP4o6JpWZaXt25VKq7rhWpZwtuuphUSRU5Ro0h/jyPRkUJukKTaCuz1DCWA5GHGnfMwdkEnRiF12rWRpluEqadgcYU5QZtqeItZhvq2Nk3t9ZZ3XlXrO4wT+0cmMI2gsxFXQtkHYT9o4vVq8vZp8=
tp=P+6a7LdmOZGIOp333qy3RgXPS6Df89z4tEysvi6W1az8EXhh0JO/JcDwe4gH5+MQtvDJd3kgZNIAYZI0iveD1v/P67DdWfGdt2PVujM1zBS7jLj+KOiaVmWl7duVSqu64VqWcLbrqYVEkVOUaNIf48j0ZFCbpCk2grs9QwlgORhxp3zMHZBJ0Yhddq1kaZbhKmnYHGFOUGbaniLWYb6tjZN7fWWd15V6zuME/tHJjCNoLMRV0LZB2E/aOL1avL2af
tp=PgTlZb20/ktYaunH0MScMyvYQ6Y7jPDA43sbFEQxv+b5IRXBwWhiHFJKpzO/gWqu6UvXGiYPYnSXHJHKyAY7kEHOqRZtPI2tq1VldYs+jZN2AVPk4McSa/6AYoCQkV7x07Lrf6I8udhQfdpaDyN3DuZuB7KnxmhLLdbW7QON1uJNim5qXV+igYd0UN+W/TB9QVD659EzS55bkwfCmmHCCdnFVis9UgYun/iP38yacXeWIpAfaKi7D6yBNTY4=
tp=PdkNdEYE5WW9tP5LWGrpx9DEnDMr2EOmO4zwwON7GxREMb/m+SEVwcFoYhxSSqczv4FqrulL1xomD2J0lxyRysgGO5BBzqkWbTyNratVZXWLPo2TdgFT5ODHEmv+gGKAkJFe8dOy63+iPLnYUH3aWg8jdw7mbgeyp8ZoSy3W1u0DjdbiTYpual1fooGHdFDflv0wfUFQ+ufRM0ueW5MHwpphwgnZxVYrPVIGLp/4j9/MmnF3liKQH2iouw+sgTU2O
tp=PZGgyqbehp2DbQvvXWim1qfvHuW5EfCXJoNtK9Q1XdRRpFmMFBZ9PtfIFoJReHbNxmw+IHusgDWVWJ8lbcV6jtPZR5Dq5hogfXeP0OBG+JpDXhIoOjSxuukJpNt+4a3jObDoYKUa2SGhVJxNP8G7AWlrtxX+/MkNYgRoRM5JlQLcSAKgUmlRQY5NDa65O7j5tApgsgdtzO3XoIW+GVHDoHDzUiUBj7jDXmZZDJDIdrpZntqLdNMlbh8WAMog=
tp=PG0PgIGRoMqm3oadg20L711optan7x7luRHwlyaDbSvUNV3UUaRZjBQWfT7XyBaCUXh2zcZsPiB7rIA1lVifJW3Feo7T2UeQ6uYaIH13j9DgRviaQ14SKDo0sbrpCaTbfuGt4zmw6GClGtkhoVScTT/BuwFpa7cV/vzJDWIEaETOSZUC3EgCoFJpUUGOTQ2uuTu4+bQKYLIHbczt16CFvhlRw6Bw81IlAY+4w15mWQyQyHa6WZ7ai3TTJW4fFgDKI
tp=PXpRbdu65k+Lq4MfaftzB8NI6XK8i8aPgY/TOtVXMJrpr2CfVkp2pxhdOKCylikTkKlwJKCtHRx4R/CTXRxdch0sunr0t/vX0as9BILKrStTIDTXKmwUoq3V16xPnqXxOBbtFkcS07cdGMR24GwLaYau3qkqpU23m/EfwD/8VYN8ydPzrb/5rbzKugPQXko8bRD+xWPma2nYxbk8vt0yYRRzQttkprJ8Ocyc0rx9TVYHYqd23HACMS0Q3ZcA=
tp=PT2rKrV6UW3buuZPi6uDH2n7cwfDSOlyvIvGj4GP0zrVVzCa6a9gn1ZKdqcYXTigspYpE5CpcCSgrR0ceEfwk10cXXIdLLp69Lf719GrPQSCyq0rUyA01ypsFKKt1desT56l8TgW7RZHEtO3HRjEduBsC2mGrt6pKqVNt5vxH8A//FWDfMnT862/+a28yroD0F5KPG0Q/sVj5mtp2MW5PL7dMmEUc0LbZKayfDnMnNK8fU1WB2KndtxwAjEtEN2XA
tp=PHRSwQSDNfG7zmh57q7gP3VQlNxV/WuKs6OYa61w+SlD2wHHC2PiM8N7ED9BYg1SWniMkILeetnnWsbHsQ9fXEXgzCpd/8cnRCo+rw/Cp3374iZhHPYj9JWbWXZY6o8cZ3kmwJfIq4eCvfcYDOV9IGWWADmcvLOGK2vAhFCjzTJJtakaFWDsyCAyyXtEOV0SIRshVYwu7Ra+LI0IpgGvcyhvzK83/f7f4mSzzZ245lgku+JVvJytmpcxUuBA=
tp=PpOmYOB0UsEEgzXxu85oee6u4D91UJTcVf1rirOjmGutcPkpQ9sBxwtj4jPDexA/QWINUlp4jJCC3nrZ51rGx7EPX1xF4MwqXf/HJ0QqPq8Pwqd9++ImYRz2I/SVm1l2WOqPHGd5JsCXyKuHgr33GAzlfSBllgA5nLyzhitrwIRQo80ySbWpGhVg7MggMsl7RDldEiEbIVWMLu0WviyNCKYBr3Mob8yvN/3+3+Jks82duOZYJLviVbycrZqXMVLgQ
tp=PgUduZeotA/tj8vC8Z3nwtMcBA75BeONUCWpyDlcH6a8XroAo08GvfUqnoC0KiJORoEVInw0SV+9lNiWSU6QzRoU6D7i0MD1mR4gAfSzm4EHZ1YmryWz2t69xwYxcEsOtze5Rr5HhohxfFO1b3He9hZNGTEZheGcJyxzBBj0Min/4wjzJdc1W4LhWyvAdhh22dlCDlYv/U0nZUEUIktJD7GlwwBpRudETEprDdnWWSLymJz14OWN07kQXzkw=
tp=P2i6794FHbmXqLQP7Y/LwvGd58LTHAQO+QXjjVAlqcg5XB+mvF66AKNPBr31Kp6AtCoiTkaBFSJ8NElfvZTYlklOkM0aFOg+4tDA9ZkeIAH0s5uBB2dWJq8ls9revccGMXBLDrc3uUa+R4aIcXxTtW9x3vYWTRkxGYXhnCcscwQY9DIp/+MI8yXXNVuC4VsrwHYYdtnZQg5WL/1NJ2VBFCJLSQ+xpcMAaUbnRExKaw3Z1lki8pic9eDljdO5EF85M
tp=PZfQmOHIowrawWbtqTFuhNuspzkCAFQ6coIX0AUDCcybqlMjyl6OJ+tFtnUydHYqt6ylheiMiYv3rWciE9FUSZztMDnZVUneE+10ngFMBJZ8rCo96QVnvG/YQWF8d+pr9VWbpBJ9RSYLAgT27fyMmaz0KwtazLBJgPyE7fZaG4XFjbfQEQimnbMDAgGU/dUMOqm7By27OPnAp+nxMYePX4CWuZaU8QdKpoFCTqV22dQpI1kpKiL0Jz8sEkZI=
tp=P7k6b6GX0JjhyKMK2sFm7akxboTbrKc5AgBUOnKCF9AFAwnMm6pTI8pejifrRbZ1MnR2KrespYXojImL961nIhPRVEmc7TA52VVJ3hPtdJ4BTASWfKwqPekFZ7xv2EFhfHfqa/VVm6QSfUUmCwIE9u38jJms9CsLWsywSYD8hO32WhuFxY230BEIpp2zAwIBlP3VDDqpuwctuzj5wKfp8TGHj1+AlrmWlPEHSqaBQk6ldtnUKSNZKSoi9Cc/LBJGS
tp=PdhK8Mmw0LgPIlYSr8cPQtpIzFfmobkn16WBsVyciILyEGZCJDeltNaawrE91ogDG0PnPXn9OvJecHuijps3jAX38ZObRDs+ZxuSJMACi8vM5C1hJJ1RfAiaXKbVSrJiAsuGjcmO77+dk9yiYttkI+sfzvT8lCoDAiMddACvi9uniMvuSvXonILyyl+pUk+klFrGj9wHD8CLK6XAxH6Hv/NIByan/zJ30YL4MTHvM9weiVrAZCSnk0O2o9DU=
tp=PETyuZXYSvDJsNC4DyJWEq/HD0LaSMxX5qG5J9elgbFcnIiC8hBmQiQ3pbTWmsKxPdaIAxtD5z15/TryXnB7oo6bN4wF9/GTm0Q7PmcbkiTAAovLzOQtYSSdUXwImlym1UqyYgLLho3Jju+/nZPcomLbZCPrH870/JQqAwIjHXQAr4vbp4jL7kr16JyC8spfqVJPpJRaxo/cBw/AiyulwMR+h7/zSAcmp/8yd9GC+DEx7zPcHolawGQkp5NDtqPQ1
001003:0020 DEBUG: Code 0 at g/>>m:Vzl/$+*U=='upDy:29398967
001003:0020 DEBUG: Code 117506160 at }ia|\Er`>$.zD?Ow:121274584
001003:0020 DEBUG: Code 0 at .P=R9v ~CRB2I4%)GO:121262325
005003:0000 Failed to save title 0 to file /Volumes/Lacie01-12/RippingMedia/mkv/title00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Sat May 28 03:29:14 2016
The log indicates that there are several areas in file 00013.m2ts that the system is having trouble reading. Most apparently can be read with retries; the offset pointer moves between some of the error messages, first at offset 27950585856, then 27950635008, and so on until it reaches 27950641152, where MakeMKV runs out of things to try to get a valid sector read.
Have you cleaned the disk? The error progression is very much like a disk with a few fingerprints on it.
mrdrummond
Yeah cleaned it a few times. This disk is annoying ive tried it so many times and also cleaned/different drives.
I can live with a perhaps dodgy disk but its interesting that makemkv crashes
(even though it says it shut down its actually a crash. I come back to the machine and the software has aborted and closed).
mrdrummond
Interestingly i updated to El Capitan on that machine and MakeMKV no longer crashes at the end of the failed rip.
Didn't fix the failed rip but the failure is now graceful.
