Enabling LibreDrive on ASUS BW-16D1HT
ianmck
#1 Post by ianmck » Sun Oct 26, 2025 11:07 am
Hi
I have an ASUS BW-16D1HT Bluray drive which is LibreDrive capable but not enabled. I would appreciate if someone could identify the the correct method to enable LibreDrive.
The drive details are:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: KLZPxxxxxxx
Firmware date: 2120-12-01 17:59
Bus encryption flags: 1F
Highest AACS version: 81
Many thanks
Ian Mck
Re: Enabling LibreDrive on ASUS BW-16D1HT
#2 Post by dcoke22 » Sun Oct 26, 2025 2:14 pm
Flashing your drive for LibreDrive support should be pretty straight forward. Just follow the instructions in the Ultimate UHD Drives Flashing Guide.
There are links in there to the firmware you need and, if you're on Windows, to the SDF tool to flash the drive.
ianmck
#3 Post by ianmck » Wed Oct 29, 2025 10:16 am
Hi
Read through the instructions and was a bit confused at first but utimately very straight forward. LibreDrive is now enabled.
Many thanks for the information I really appreciate it.
Kind regards
Ian McK
