ASUS BW-16D1X-U - Flashable?
killintime78
Re: ASUS BW-16D1X-U - Flashable?
I've had this Asus Drive for awhile now. but just started to rip my Physical Media to build a plex server. but it wont read 4K discs. any help would be appreciated.
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Serial number:
Firmware date: 2119-01-04 10:47
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 0.A104W
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Serial number:
Follow the guide:killintime78 wrote: Sun Oct 19, 2025 10:00 am I've had this Asus Drive for awhile now. but just started to rip my Physical Media to build a plex server. but it wont read 4K discs. any help would be appreciated.
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Serial number:
viewtopic.php?f=16&t=19634
killintime78
Forgive my ignorance, im a complete noob to all this. From what i gathered, seems i need to flash my drive to Asus BW-16D1HT 3.10MK
Is that correct? and if so how do i go about this? any help will be appreciated. thanks
The link to the Guide Coopervid posted includes links to the firmware you need and the GUI SDF tool that you can use on Windows to flash your drive. If you're on Mac or Linux, the Guide includes examples of the commands you need to run to flash your drive.killintime78 wrote: Tue Oct 21, 2025 9:43 pm Forgive my ignorance, im a complete noob to all this. From what i gathered, seems i need to flash my drive to Asus BW-16D1HT 3.10MK
mitsukid82
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Firmware date: 2020-07-21
Highest AACS version: 81
Firmware version: ID76
Billy I sent an email also need a flasher Thank you
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
Highest AACS version: 71
not_a_sandwhich
Just flashed my BW-16D1X-U with success, as of 10/22/2025 and I can now read UHD Blu-rays.
I'm not a crazy hardware guy either so thought I'd post what I learned while following different threads on this fourm.
Again I'm sort of a noob at this but got it working.
1. In the videos or forms, when they talk about Asus drives, I don't think it really matters what model of Asus drive you have as long as the drive platform is MT1959
2. Use the link to the SDFtool Flasher and the "All You Need Firmware Pack" at this link viewtopic.php?f=16&t=22896 Again there's only one Asus firmware found in the firmware pack.
3. The SDF flasher tool "READ" function didn't really yield me anything that I could use for the "RECOVER" function. I guess this is for something else. If the firmware didn't work, at the bottom of this page viewtopic.php?f=16&t=22896 there's a "p.s." section that has the old firmware. I never ended up trying it as I got it to work with the "firmware pack" files and I'm gonna call it good there.
4. Read all the forms that people link around to if you're not familiar with this kind of stuff like I am. This stuff is developing all the time and you're bound to run into dead threads
Useful links:
https://www.youtube.com/watch?v=jyQV1aPlbow This one is old but I found it helpful. This seems to have been made before the SDFtool Flasher was created
The all you need firmware pack: https://drive.google.com/file/d/1HRnbXi ... sp=sharing
Again just posting this here as it worked for me. I'd definitely follow the main threads about flashing drives over what I'm saying
Below was my BW-16D1X-U info from MakeMKV
Useful links:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Serial number: KLCKB7D2448
Highest AACS version: 63
Unrestricted read speed: Possible (with patched firmware)-
NapoleonSaint
May i get a Pm as well for instructions?
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
killintime78
Thanks, I was able to flash it successfully using the GUI SDF tool & the firmware for the Asus Drive. appreciate the help everyone has given me.dcoke22 wrote: Wed Oct 22, 2025 2:28 amThe link to the Guide Coopervid posted includes links to the firmware you need and the GUI SDF tool that you can use on Windows to flash your drive. If you're on Mac or Linux, the Guide includes examples of the commands you need to run to flash your drive.killintime78 wrote: Tue Oct 21, 2025 9:43 pm Forgive my ignorance, im a complete noob to all this. From what i gathered, seems i need to flash my drive to Asus BW-16D1HT 3.10MK
PM sent.dhop65 wrote: Thu Oct 23, 2025 12:30 amAny help with this one?Code: Select all
Drive Information OS device name: \Device\CdRom0 Current profile: BD-ROM Manufacturer: ASUS Product: BW-16D1X-U Revision: E113 Serial number: ... Firmware date: 2020-07-21 Bus encryption flags: 1B Highest AACS version: 71 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID76 No disc inserted
PM sent.NapoleonSaint wrote: Sat Oct 25, 2025 4:33 am May i get a Pm as well for instructions?
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
ignignokt126
Is this drive flashable?
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DJDL129030WL
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
PM is coming.ignignokt126 wrote: Mon Oct 27, 2025 5:30 pm Hi,
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Would this be possible? I am new to all of this so I am unsure about anything
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Highest AACS version: 68
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
NapoleonSaint
Thank you for your help, process was very streamlineCoopervid wrote: Mon Oct 27, 2025 10:45 amPM sent.NapoleonSaint wrote: Sat Oct 25, 2025 4:33 am May i get a Pm as well for instructions?
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
