Volume Key Unknown For This Disc
leosantare
Post by leosantare »
My first time ever running into this issue. I understand to send the dump file to svq@makemkv.com, is this correct?
If so, I have done so more than once and never got a response. I'm not trying to rush anyone, I'm just want to make sure I have notified whoever in with the correct information. This way I'm not waiting for nothing.
Below is the dump file I sent along with the error message. Can you please confirm I provided the correct file to the correct email address?
https://imgur.com/a/gfa34bE
Thank you,
Re: Volume Key Unknown For This Disc
Yes, that's the correct address. And the .tgz file is the one to send.
I don't think you'll ever get a response from that email address. But your dump will eventually be turned into a hashed key and then when you try to rip the disc again later, if the hashed key is available MakeMKV will download it automatically.
leosantare
It's been three weeks and still not working?
leosantare
Nevermind, I tried again today and it worked. I'm all set.
Thank you,
