Knight Rider Complete Series 4K UHD S3D3 & S4D2 Ripping Errors
ShatteredGlass
Re: Knight Rider Complete Series 4K UHD S3D3 & S4D2 Ripping Errors
#16 Post by ShatteredGlass » Tue Oct 21, 2025 9:37 pm
Krawk wrote: Tue Oct 21, 2025 7:33 pm Actually, any time Universal has BD100s produced, there are issues with certain drives.
I tried ripping the two discs that I had issues with in 10 different drives (4 different models) and not one of them could rip the discs. So the issue definitely isn't limited to "certain drives".
Sword7
#17 Post by Sword7 » Tue Oct 21, 2025 10:21 pm
Sword7 wrote: Tue Oct 21, 2025 8:43 pm
I tried different drives and cleaned discs but still got same errors. With S4D4, it tried to access AACS files but got invalid field in CDB errors and aborted immediately. That turns out bad discs. I checked my order but return window already closed. I can't return it for replacement.
Tim
That was power supply issue. I tried different power supply (different USB port) and made through S4D4 disc dumping!! I am now trying S2D3...
Tim
#18 Post by SamuriHL » Mon Oct 27, 2025 5:40 pm
Finally getting around to finishing ripping these. S4D4 is giving me fits at the moment. I know all the usual advice. Currently trying one of my other Pio drives but this one might be a badly mfg'd disc. Not really worried about it, just reporting my findings so far.
Sword7
#19 Post by Sword7 » Mon Oct 27, 2025 6:45 pm
SamuriHL wrote: Mon Oct 27, 2025 5:40 pm Finally getting around to finishing ripping these. S4D4 is giving me fits at the moment. I know all the usual advice. Currently trying one of my other Pio drives but this one might be a badly mfg'd disc. Not really worried about it, just reporting my findings so far.
Yeah. That might be bad S2D3 disc. I tried many drives but got the same errors (same offset locations).
Tim
#20 Post by SamuriHL » Mon Oct 27, 2025 6:51 pm
No issue with any discs in S2. Just this one is problematic. It failed in my other drive, as well. I'll take more drastic measure if needed. As I said, not really worried but just reporting that this set seems to have all kinds of quality issues.
#21 Post by SamuriHL » Mon Oct 27, 2025 9:26 pm
Hash check failed for file 00007.m2ts at offset 7453009920, file is corrupt.
DEBUG: Code 1 at h97u/P'k6LzLo#gYp;Jg:29394758
DEBUG: Code 2 at h97u/P'k6LzLo#gYp;Jg:29394758
The source file '/BDMV/STREAM/00007.m2ts' is corrupt or invalid at offset 7452948480, attempting to work around
DEBUG: Code 3 at h97u/P'k6LzLo#gYp;Jg:29394758
DEBUG: Code 4 at h97u/P'k6LzLo#gYp;Jg:29394758
DEBUG: Code 5 at h97u/P'k6LzLo#gYp;Jg:29394758
DEBUG: Code 6 at h97u/P'k6LzLo#gYp;Jg:29394758
DEBUG: Code 7 at h97u/P'k6LzLo#gYp;Jg:29394758
DEBUG: Code 8 at h97u/P'k6LzLo#gYp;Jg:29394758
DEBUG: Code 9 at h97u/P'k6LzLo#gYp;Jg:29394758
DEBUG: Code 10 at h97u/P'k6LzLo#gYp;Jg:29394758
DEBUG: Code 11 at h97u/P'k6LzLo#gYp;Jg:29394758
DEBUG: Code 12 at h97u/P'k6LzLo#gYp;Jg:29394758
DEBUG: Code 13 at h97u/P'k6LzLo#gYp;Jg:29394758
DEBUG: Code 14 at h97u/P'k6LzLo#gYp;Jg:29394758
DEBUG: Code 15 at h97u/P'k6LzLo#gYp;Jg:29394758
DEBUG: Code 16 at h97u/P'k6LzLo#gYp;Jg:29394758
DEBUG: Code 17 at h97u/P'k6LzLo#gYp;Jg:29394758
DEBUG: Code 18 at h97u/P'k6LzLo#gYp;Jg:29394758
DEBUG: Code 19 at h97u/P'k6LzLo#gYp;Jg:29394758
DEBUG: Code 20 at h97u/P'k6LzLo#gYp;Jg:29394758
DEBUG: Code 21 at h97u/P'k6LzLo#gYp;Jg:29394758
And if you force an ISO creation ignoring the read errors, as many propose MakeMKV do, this is the problem you face. So yea, don't do that.
CE6AT
#22 Post by CE6AT » Thu Jan 01, 2026 3:46 pm
have similiar issues with S4D2, i use an asus internal uhd drive.
Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
File 00011.mpls was added as title #0
File 00002.mpls was added as title #1
File 00005.mpls was added as title #2
File 00010.mpls was added as title #3
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '20840448'
DEBUG: Code 100864261 at _worNE:(,lg'T'0g]I:213131502
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '21233664'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '24705024'
File 00007.mpls was added as title #4
Title #00009.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Encountered 48 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
