MakeMKV above v1.17.7 still broken on Linux
16442496
Re: MakeMKV above v1.17.7 still broken on Linux
Post by 16442496 » Fri Sep 26, 2025 6:27 pm
MakeMKV 1.18.2 works. I use MakeMKV 1.17.6 Appimage to get firmware dump.
shonenbat
Post by shonenbat » Sat Sep 27, 2025 3:51 pm
1.18.2 fixed the problem for me
enigma_0z
Post by enigma_0z » Mon Sep 29, 2025 2:18 am
Pretty sure I'm getting bitten by the same thing. I'm building a headless server, ... but I don't have the sources / binaries at my disposal to try to build 1.17.6 or a "known working" version.
Drive is a Pioneer BD-XD07, and when I run from the CLI this happens (debug log). This is outputted and then it just hangs forever.
Debug log started at Mon Sep 29 01:56:28 2025 , written by MakeMKV v1.18.2 linux(x64-release)
001005:0000 MakeMKV v1.18.2 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///home/enigma/MakeMKV_log.txt
005074:0000 Automatic checking for updates is enabled, you may disable it in preferences if you don't want MakeMKV to contact web server.
001003:0020 DEBUG: Code 0 at [$&!cPHsNoNC,vJT%<05$ :29393631
001003:0020 DEBUG: Code 0 at J9nz|TUj[9tsqH);:121276424
No  SDF v097: PIONEER_BD-RW__BDR-XD08U_1.02_DGDL302452UC
SDF auto v097: PIONEER_BD-RW__BDR-XD08U_1.02_DGDL302452UC
16442496
Post by 16442496 » Mon Sep 29, 2025 4:14 am
enigma_0z wrote: Mon Sep 29, 2025 2:18 am Pretty sure I'm getting bitten by the same thing. I'm building a headless server, ... but I don't have the sources / binaries at my disposal to try to build 1.17.6 or a "known working" version.
Old versions are here:
https://makemkv.com/download/old/
enigma_0z
Post by enigma_0z » Sat Oct 04, 2025 12:36 am
16442496 wrote: Mon Sep 29, 2025 4:14 am Old versions are here:
You are a freakin lifesaver tysm!!
Retromovieman
Post by Retromovieman » Fri Oct 10, 2025 7:13 pm
To the Dev's, Can you please roll back the current release back to 1.17.1 for linux specifically for Ubuntu and the Ubuntu store. Or drop a dot Deb file of the 1.17.1 .The current version 1.18.1 and 1.18.2 absolutely does not work no matter what is changed. I have done fresh installs of Ubuntu 24.04 and 25.10 over and over and added CD-Rom groups ect. I have Installed 1.17.1-1.18.2 via the terminal with apt install and snap install. I have installed via the Ubuntu store and even compiled from source.
I went as far back as 1.17.1 and nothing is working any more. Installing an older version always shoots erros that the version I am using is too old. current versions just hang and do nothing like I am just looking at a freeze frame picture of the program. On one of the releases it never gets passed downloading sdk?
I even attempted terminal commands such as -
"sudo snap connect makemkv:optical-write" and
"sudo snap connect makemkv:removable-media" to no avail.
The craziest thing is it work beautifully in Windows so I know the drive works. Any help would be amazing and thanks for your consideration.
Post by dcoke22 » Sat Oct 11, 2025 7:22 pm
Retromovieman wrote: Fri Oct 10, 2025 7:13 pm I went as far back as 1.17.1 and nothing is working any more. Installing an older version always shoots erros that the version I am using is too old. current versions just hang and do nothing like I am just looking at a freeze frame picture of the program. On one of the releases it never gets passed downloading sdk?
I know you're not likely to buy a key since you're having trouble with it, but if you use a paid-for key for MakeMKV, you can use any old version of the program you want without an error about using an old version.
Retromovieman
Post by Retromovieman » Tue Oct 14, 2025 6:06 pm
Thanks, but I already purchased a paid for version years ago. The problem is that when I install anything prior to 1.17.7 it complains about the version being to old then app crashes out and pops up with that message so I am unable to even enter any keys.
Crazy enough I was able to get 1.18.2 working on Ubuntu 24.04 LTS but only following every single step from top to bottom including the extra steps towards the bottom of the page just to be safe on the "How to install on Linux" main page. I copy and pasted every line into the terminal and compiled the latest version and went into apps settings and changed the makemkv setting to allow both read and write from CDROM/DVD and SSD. For some reason there were 2 of those identically named settings but one was turned off.
Now all is working perfectly well again knock on wood. Hopefully my experience can help others that are unable to get this app working to actually work too.
SMAAK
Post by SMAAK » Sun Oct 19, 2025 1:51 pm
MakeMKV for Linux stopped working for me about a year ago, too. I experimented a lot, without success, and—near despair—finally swapped the Thunderbolt 4 port, which the Blu-ray drive had always used to connect to the PC, for a regular USB-A 3.0 port. Suddenly, everything worked fine again. Apparently, MakeMKV sometimes has trouble correctly recognizing the drive via USB 4, or Thunderbolt ports in newer Linux versions.
However, the drive worked fine with MakeMKV under Windows and Mac during this time, including USB4 and Thunderbolt.
wyzxvnv
Post by wyzxvnv » Mon Oct 27, 2025 11:07 am
shonenbat wrote: Sat Sep 27, 2025 3:51 pm 1.18.2 fixed the problem for me
Hi
I still fixed for you? After more tries/running MakeMKV?
Because in my case, even newer versions above 1.17.7 occasionally work, but only from time to time. For me, still even 1.18.2 is not fixed.
Originally I tought the "current working path" could be that issue, but its not. I am not using snap or similar, I did build it from sources according to instructions.
Using Debian 13 Trixie. I can also confirm that issues are not related to some blu-ray drive models or one brand.
rumplestilzken
Post by rumplestilzken » Tue Oct 28, 2025 12:57 am
Can confirm installing 1.17.7 from the archives, starting with a DVD and then using a BR works.
Updated to 1.18.2, this continues to work - I did not have to load the DVD the second time.
I did get a message to send my fw dump to the support email address, which i did.
noobinitas
Post by noobinitas » Fri Dec 19, 2025 11:19 pm
I have the tar.gz files for 1-17.7 to try and install the older version, is there a guide to do this right, I usually install everything straight from aur but the older version is no longer listed there, found a couple videos doing it but I think they are on a different distro since the commands don't work. I'm running CachyOS so the Arch methods would work as well. I'm still fairly new to Linux as well.
BuffaloSlack
Post by BuffaloSlack » Mon Dec 22, 2025 8:26 am
noobinitas wrote: Fri Dec 19, 2025 11:19 pm I have the tar.gz files for 1-17.7 to try and install the older version, is there a guide to do this right, I usually install everything straight from aur but the older version is no longer listed there, found a couple videos doing it but I think they are on a different distro since the commands don't work. I'm running CachyOS so the Arch methods would work as well. I'm still fairly new to Linux as well.
The compile and install instructions will work on any distro, all you have to do is make sure you have the right packages installed before hand... that is the only distro specific part. ./configure; make; make install - that's all there is to it.
You probably already have most, if not all the required dependencies already installed.
Try and if you get stuck post the error and it'll be easier to help you out that way.
SamSpeexy
Post by SamSpeexy » Wed Apr 29, 2026 2:22 am
I was able to successfully flash libredrive firmware to one of my new drives using the 1.18.3 Linux ARM version of MakeMKV on my Raspberry Pi using Raspberry Pi OS (64-bit).
So it looks like the the issues with Linux are specifically related to the x64/x86 version.
keithhelms
Post by keithhelms » Mon May 04, 2026 5:27 pm
Did anyone ever figure out what this problem is?
I just got an LG WH16NS58DUP drive, put it in an external enclosure that attaches with USB and I ran into this problem. MakeMKV says scanning drive and that never completes. I had MakeMKV 1.17.8 installed when trying the new drive. I upgraded to the latest 1.18.3 version and still had the same problem. I then tried the older 1.17.7 version and that solved the issue. I had the problem under both Linux Mint using the 6.17 kernel and Debian 13 using the 6.12 kernel.
I saw several posts talking about a firmware tar file. Do you need to download that manually? If you get it downloaded using 1.17.7 does that mean you can then install a later version and it will work?
