Death Race 2008 - Garbled Decrypted Backup
mtx00
Post by mtx00 »
Hi All,
So far I have successfully made decrypted backups of around 40 discs. Whenever I create a backup, I always "spot check" a few of the mt2s files, and so far everything has been good. Until today.
I "successfully" backed up a disc, and upon checking two of the m2ts files, the video is breaking up & there is a thick green horizontal line:
Makemkv did not display any errors:
Using LibreDrive mode
Backing up disc into folder
Backup done
I am using a Verbatim 43888 (Pioneer BDR-UD04).
I tried playing the m2ts files in both Potplayer and VLC Media Player, and both show the same garbled mess.
I checked the physical disc through my Blu-ray player (Panasonic UB820), and playback is flawless (no errors of any kind).
Does anyone know why this is happening?
Thankyou
Re: Death Race 2008 - Garbled Decrypted Backup
I've never experienced what you describe, so I'm just guessing out loud here.
Do the visual glitches persist if you make a second decrypted backup?
If you use MakeMKV to create a .mkv file from your decrypted backup, does it contain the glitches?
mtx00
Post by mtx00 »
I completely forgot about this...
I ended up creating an MKV of the film in MakeMKV, and it played without any problems from a USB drive plugged straight into my TV with Kodi Player.
However, I must state I played the film through uninterrupted (never paused/fast forwarded/skipped through it). I never tried the MKV file on my computer, though.
Since it played flawlessly on my TV/Kodi, it must be Potplayer/VLC not being able to handle jumping/seeking with these particular m2ts files of this specific disc. Still seems strange that two completely different media players would create the same artifacts. :?
Problem (kind of) solved.
Thanks again
