PSA: New Archgon UHD drives do not allow flashing
blind-s33r
Re: PSA: New Archgon UHD drives do not allow flashing
Post by blind-s33r »
Coopervid wrote:
Tue Oct 21, 2025 8:43 pm
blind-s33r wrote:
Tue Oct 21, 2025 8:41 pm
Coopervid wrote:
Tue Oct 21, 2025 8:31 pm
Post the Makemkv info. Make sure it's a MT1959 drive. You know that you have to switch enclosures for flashing?
I already swapped and flashed it do bu40n 1.00 as Im running linux, my other bu40ns work perfectly fine... well one is dying which is I grabbed the new archgon.
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: 1.00
Serial number: MO2P56B1549
Firmware date: 2116-12-20 15:28
Highest AACS version: 76
Firmware version: 1.00
Disc Information
Label: ALITA_BATTLE_ANGEL
Timestamp: 2019-05-28 16:01:22
Protection: AACS2.0/C v68
Data capacity: 59.20 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Return it.
Eh, the drive itself works perfectly fine in the old enclosure for 4k ripping, Ill hold off as I needed the drive either way and hope in the future the enclosure will be supported...
Your decision. A SATA>USB adapter will work. But that's cumbersome.
blind-s33r
Coopervid wrote:
Tue Oct 21, 2025 8:52 pm
I did notice that it never says Using libredrive mode when trying to start a rip so I have to assume that thats the issue, it wont even use libredrive mode on dvd's or blurays either...
Post your Makemkv info. I guess it's not flashed successfully.
blind-s33r
Coopervid wrote:
Tue Oct 21, 2025 9:09 pm
I already did, as I said the drive itself works in the old enclosure. Its just the new enclosure that's the issue. Maybe mike can bypass the restriction in a future version of makemkv if that is the root issue.
Now. If you are on Linux go back to a 17.x version of Makemkv since 18.x versions don't work OK:
blind-s33r
Coopervid wrote:
Tue Oct 21, 2025 9:14 pm
18.x works fine for me, I've never had the issues most other people have as I build it from source... its the enclosure.
A.RABID.BUFFALO
Post by A.RABID.BUFFALO »
It’s the enclosure and not the drives. The drive can be flashed and will rip 4K outside of the enclosure. When putting a second known working drive in the enclosure it will behave the same way. The Amazon listing also explicitly says “Do not use Illegal firmware to circumvent DRM”. When the enclosure is taken apart the PCB that functions to convert the data from the drive to USB C looks nothing like any of my previous working enclosure PCBs. That’s not super telling, however it has an extra chip on most likely either stopping the drive when it notices a disc being ripped or preventing it from communicating with MakeMkV. I have a pioneer slim drive on the way to throw in and test for shits and giggles. To see if this is strictly recognizing modded LG firmware or if it’s preventing any drive regardless of manufacturer to communicate with MakeMKV.
starkiller
Post by starkiller »
As pointed out in the beginning of this topic the new enclosure has a different USB to SATA III controller:
larhaus wrote:
Thu Sep 25, 2025 10:42 pm
initio INIC-3639PN
It is most likely the INIC3639PN-FL; the QFN48 pin package variant supporting Type-C, from the 3639F family. I suspect that Archgon has programmed this IC to disable vendor command passthrough. Which prevents certain low-level operations such as LibreDrive, direct drive programming, and ripping.
I have ordered the drive and am waiting to receive it to do further testing. If anyone is able to obtain a copy of the MPTools for this chip, it may be more than possible to reprogram the IC and restore passthrough functionality, unlocking full programming and ripping capabilities through the enclosure.
This Chinese webpage gives some information but unfortunately no datasheet: https://www.szlvdu.com/show-9-12.html
Reveille
Post by Reveille »
I purchased two new USB-C Archgon drives as my old USB 3.1 drives I have accidently busted over past 2 years. I took them apart switched the new drive to the old USB 3.1 case. I can confirm that the new drive flashes completely the same as the old one. I ripped a 4K UHD movie with no issues at all. The only apparent difference is the card that plugs into the back of the drive to make it USB-C. Please note that you must use SDF Tool Flasher v1.3.5 I couldn't get the new flasher to work with this drive. I have pictures of the two different cards taken out of the cases but unsure how to upload them here.
For those interested in taking the drive out of the case there is two small screws underneath the back rubber feet. Then there is a small screw in the side of the plastic case to remove it. After this the board will easily slip off. If you don't have an old case you can simply install it a slim drive slot on a desktop PC. I plan to do this with the second drive I have.
douglascannon
Post by douglascannon »
I can also confirm the new archgon drive cannot be flashed in the new enclosure. I purchased an archgon drive this week from Amazon. ( https://www.amazon.com/dp/B07BC9F98J ). Using Marty's tool did nothing -- the start button ignored me. It is the enclosure that is preventing this. I had a Verbatim slimline drive, and I opened both enclosures, putting the archgon into the verbatim enclosure, and that worked! It flashed perfectly, and I am now ripping a 4K disc as we speak. It sounds like it would also work if I plug the archgon (without enclosure) directly into a esata port, plus power. I didn't have a cable for that.
Thanks for all the help with your posts -- it got me there. Also, thanks to Marty McNuts for the tools and the firmware pack and the posts with info.
tommik128
Post by tommik128 »
Reveille wrote:
Wed Oct 29, 2025 9:06 pm
If it is a BU40N that is not true. I was using the latest 1.3.6 version and BU40N was connected to SATA in my laptop. No problem at all.
starkiller
I have found the MPTools for the usb to sata ic in the enclosure (Initio 3639). No amount of my fiddling has changed the command passthrough issue. Someone with more familiar with embedded software may be able to modify the firmware as the usb communications run on a internal 8051-CPU but I will leave it from here. The link to the tool is below.
https://www.usbdev.ru/files/initio/initio3639smptool/
*IMPORTANT*
If you try them yourself you must make sure to set the usb power values correctly the field (they are in hex). Not doing so will not damage the drive but it will just prevent it from receiving the amount of power it needs.
Also, I have found the included firmware version to be fine to flash over not changing the current (limited) functionality.
I am not the creator of this software, or have any affiliations, use it at your own risk.
