sephirothkefka
#1
Post
by sephirothkefka » Sat Oct 25, 2025 6:28 am
Recently I acquired Evangelion 1.11 and 2.22 rereleases from GKIDS and ripped them. After ripping (and also submitting the dumps by clicking the link as MakeMKV recommended) I noticed what appeared to be corruption for my rip while playing in MadVR and MPC-HC while skipping around at random spots which I never noticed before. Both ripped with no errors reported by MakeMKV.
The corruption only lasts for about a frame and then continues on as if nothing happened (it appears that the I-frames are not being properly decoded). It doesn't happen in all spots just very specific areas of the disc. It also doesn't happen if you skip slightly farther back and let it play normally as is. I thought it was maybe because it was something in regards to AACS 82 so i got the KeyDB.cfg and used MakeMKV in tandem with Xreveal yet still shows the same error. Any ideas if this is a MakeMKV bug or a genuine issue with my discs?
#2
Post
by dcoke22 » Sat Oct 25, 2025 4:13 pm
I don't think it is either a bug in MakeMKV or an issue with your discs. If it only happens when you're skipping around and it only lasts a frame or two, it is probably an artifact of the player trying to display an image before the buffers fully fill and there are enough frames in the pipeline to properly decode the next frame.
You can read about
AVC which is most likely the encoding used on the blu-rays you mentioned.
sephirothkefka
#3
Post
by sephirothkefka » Sat Oct 25, 2025 8:09 pm
dcoke22 wrote: Sat Oct 25, 2025 4:13 pm
You can read about
Thats the thing I did the same thing on other discs and got basically the same result and now I'm kind of just confused.
sephirothkefka
#4
Post
by sephirothkefka » Sat Oct 25, 2025 10:08 pm
I also just ran debug mode and other than a Code 2147483648 (which i think is AACS related) it ripped with no issues. Increasing the splitter cache in MPC-HC also had no effect.
sephirothkefka
#5
Post
by sephirothkefka » Sun Oct 26, 2025 8:02 am
Okay i think i might know whats going on
According to by UB9000 the bitrate is going unusually high in spots where it otherwise shouldn't (isn't the max bitrate for video on Blu-ray 40mbps?) I don't know how makemkv can appropriately cope with this assuming it *can* cope with this. The only other time I've seen bitrates that high is with an episode of Better Call Saul (the episode where Saul impersonates Howard and that was a mere 61mbps).
ryley
#6
Post
by ryley » Sun Oct 26, 2025 8:34 am
sephirothkefka wrote: Sat Oct 25, 2025 10:08 pm
Which video decoder are you using? It might be worth trying out software decoding via LAVFilters to see if it handles seeking more gracefully than whichever hardware decoder you are currently utilising.
sephirothkefka wrote: Sun Oct 26, 2025 8:02 am
There is nothing more for MakeMKV to do here. It has done its job of decrypting, verifying and repackaging the content from your disc into a Matroska file. The visual corruption you are seeing is a shortcoming of your playback configuration. It is in no way indicative of corruption within the actual Matroska file.
Remember, MakeMKV isn't acting like an analogue video capture card frantically trying to grab every ephemeral frame on the wire. It is completely indifferent to the bitrate used to encode the content. The bitrate obviously matters for hardware players trying to playback content in real time but MakeMKV would happily rip a disc mastered at 400Mbps if you gave it one. It wouldn't happen in real time but that doesn't matter for its intended use case.
sephirothkefka
#7
Post
by sephirothkefka » Tue Oct 28, 2025 12:01 am
ryley wrote: Sun Oct 26, 2025 8:34 am
I forgot to reply to this but I'm using MadVR.
sephirothkefka
#8
Post
by sephirothkefka » Tue Oct 28, 2025 11:33 pm
After further experiments MakeMKV is most definitely fault at least during the MKV muxing process. Rolled back a version to make sure it wasnt a faulty update and it still had errors. Did another raw M2TS dump with MKVToolnix (after decrypting with Xreveal) and lo and behold its fixed!
OddOttAllen
#9
Post
by OddOttAllen » Tue Nov 04, 2025 8:43 am
i'm also getting something like this! i'm just skipping around the videos ripped from the discs on MPC-HC on my PC, and i get that weird visual artifacting for a frame or so. also using madVR.
sephirothkefka
#10
Post
by sephirothkefka » Mon Nov 10, 2025 6:22 am
I'm experiencing this issue with another Bluray this time Looney Tunes Platinum Collection Vol 1. Seems like "Duck Dodgers" is one of the affected shorts as it also has issues while skipping. Using another program to make the MKV works fine. Some shorts are affected others aren't. It seems to affect stuff that are 2 ref frames for the video as Eva is also 2 ref frames.
OddOttAllen wrote: Tue Nov 04, 2025 8:43 am
Do a decrypted backup with MakeMKV and make the MKV with something like MKVToolnixGUI.
