So I just downloaded makeMKV and got one of the recommended drives, from reading the flashing guide I thought I flashed properly. From reading these forums I know that the firmware needs to have a K at the end. I think I need to cross flash, but there isn't a command that I am seeing for cross flashing. I did download the hybrid firmware, but I don't want to brick anything so I just wanted to confirm how I should cross flash. I am under the assumption I need do the same step as I did for flashing the first time but use the hybrid firmware. I know I could just try it but I would rather ask and look dumb than mess up my drive permanently. I included my drive and libre drive info.
./makemkvcon f -d '/IOBDServices/insert_drive_type' -f /tmp/sdf.bin rawflash enc -i /tmp/DE_LG_BP50NB40-NB50_1.01_MK_HBD
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: SIM2221R23316
Highest AACS version: 81
Firmware version: 1.03
Cross Flashing Firmware on Mac OS
gtijo
Re: Cross Flashing Firmware on Mac OS
I ended up fixing through a reddit thread, youtube video and just using the SDF flasher gui for windows on a spare windows machine I have. Also if anyone is reading this the SVC code means there will be different steps. I was trying to follow the nb40 and I needed to follow the steps for NB-52.
With that being said I did also find a thread searching for cross flashing and or my model BP50NB40
Subprime4829
I'm on macOS 26 and don't have access to a Windows machine at all. I need to flash a BP50NB40 so it can read UHD discs. Trying to follow the terminal commands from the Ultimate UHD Drives Flashing Guide Updated 2025 thread does nothing.
