Cross-flashed LG BP50NB40 (NB52) – UHD not reading, Blu-rays are fine
Re: Cross-flashed LG BP50NB40 (NB52) – UHD not reading, Blu-rays are fine
I've also noticed this across multiple new 4K discs. New Blu-Rays are fine. My drive has been cross-flashed for over two years, just cleaned, discs are spotless and were cleaned with micro-fiber cloth when failing. Perhaps this is a new software bug?
Also to note: both new 4Ks were Disney discs, TSOM and Rocky Horror.
Subprime4829
Having the same issue on my BP50NB40 except I'm on macOS so I can't use the SDFtool flasher.
Firmware HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917 was successfully flashed but trying to flash HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin, even though it says "done successfully" in the terminal does nothing. It will still show the BP50NB40-NB50-1.03 firmware in MakeMKV. I'm on macOS 26.
Tried using both
./makemkvcon f -d '/IOBDServices/identifier' -f /tmp/sdf.bin rawflash enc -i /tmp/HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
and
./makemkvcon f -d '/IOBDServices/identifier' -f /tmp/sdf.bin rawflash main -i /tmp/HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
Tried using both
and
Read the instructions in the first post of the Ultimate UHD drive Guide 2025.Subprime4829 wrote: Sun Oct 26, 2025 5:13 am Having the same issue on my BP50NB40 except I'm on macOS so I can't use the SDFtool flasher.
Tried using both
and
Subprime4829
I did. Am I missing something?MartyMcNuts wrote: Sun Oct 26, 2025 5:56 am Read the instructions in the first post of the Ultimate UHD drive Guide 2025.
You have the NB52 version of the BP50NB40, right? The Ultimate UHD Drives Flashing Guide says after you flash BP50NB40-NB50-1.03MK onto it then you need to flash BP50NB40-NB50-1.03MK with bootloader/full flash. In order to do that on the command line, you have to use 'rawflash full' in your command.Subprime4829 wrote: Sun Oct 26, 2025 6:03 amI did. Am I missing something?MartyMcNuts wrote: Sun Oct 26, 2025 5:56 am Read the instructions in the first post of the Ultimate UHD drive Guide 2025.
Ultimate UHD Drives Flashing Guide wrote:NB52 to > BP50NB40-NB50-1.03MK with enc > BP50NB40-NB50-1.03MK with bootloader/full flash > BP60NB10 1.00_HBD from Marty download/file.php?id=2143
if using command line add "full" after rawflash
Subprime4829
Thanks a lot!!! Yeah, I missed the part where I had to type rawflash full. It's working now and ripping a 4K as I'm typing this with the BP60NB10 1.02 firmware!
