The Rebound (Fox) U.S. Ripping Errors
BlueManGroup
Post by BlueManGroup »
The Rebound U.S. release from Fox won't decrypt the BD+ encryption and rip to disc. I'm using a Sony BDX-500U BD burner and Max OS X Lion 10.7.3 and MakeMKV 1.7.2.
Here's the entire readout:
MakeMKV v1.7.2 darwin(x86-release) started
Optical drive "BD-RE SONY BD RW BDX-S500U 1.D1" opened in DASPI v1.3 mode.
Loaded 9 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00003.svq
Failed to process BD+ code using generic SVQ from builtin/00003.svq
Processing BD+ code using generic SVQ from builtin/00002.svq
Saved BD+ dump file as /Volumes/OpenShare-1/dump_The_Rebound_FA5177E5A8BB6ACB.tgz
BD+ code processed but no FUTs were obtained, errors may follow
File 00538.mpls was added as title #0
Title #00532.mpls has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #1
File 00500.mpls was added as title #2
Title #00535.mpls has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00524.mpls was added as title #3
Title #00520.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00511.mpls was added as title #4
Title #00002.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00720.mpls has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00850.mpls is equal to title 00800.mpls and was skipped
Title #00300.mpls has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00231.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00230.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00390.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00215.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00720.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00170.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00220.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00194.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00750.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00193.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00192.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00191.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00190.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00210.m2ts was added as title #5
File 00211.m2ts was added as title #6
Title #00301.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00300.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/OpenShare-1/BD Rips/Rebound
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 47738880, attempting to work around
Failed to save title 1 to file /Volumes/OpenShare-1/BD Rips/Rebound/t01_The_Rebound.mkv
0 titles saved, 1 failed
Re: The Rebound (Fox) U.S. Ripping Errors
Post by mike admin »
This is a new protection, you need to submit BD+ dump, please see http://www.makemkv.com/svq/
