BDR-XS07S UHD Flash
Re: BDR-XS07S UHD Flash
How to enable LibreDrive?
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.00
Serial number: ***
Firmware date: 2019-01-07
Highest AACS version: 76
Firmware version: ID69
Revision: 1.00
Serial number: ***
PM sent.nilsman wrote: Thu Oct 23, 2025 8:56 pm How to enable LibreDrive?
Revision: 1.00
Serial number: ***
I have one of these, but the firmware is post-patch. I am aware of the recent news regarding pioneer drives though.
I was just wondering, when the new fix rolls out and 4k UHD support is restored to post-patch Pioneer drives, will this model be one of the supported drives?
I bought it intentionally while they were still readily available for MSRP, knowing the firmware was post-patch, because I know a fix will come eventually, and I would rather get it while they are still available.
TL;DR Will this drive with post-patch firmware work with the upcoming fix for pioneer drives, whenever it releases?
Much appreciated!
Much appreciated!
• LG WH16NS60 (x2)
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• PANASONIC SW-9576-C
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
Mike has said that the newer Pioneer drives will be libredrive supported but that does not mean UHD supported. I'm not sure if there will be any flashing required or if libredrive will just be enabled, so, if it's the latter, unless your drive is an actual UHD model (XS07UHD) then it more than likely won't support UHD discs.Voxelium wrote: Thu Oct 23, 2025 10:31 pm Hello,
Much appreciated!![]()
The XS07S would need to be cross-flashed to enable UHD support and we just don't know at this stage if firmware flashing will be enabled or not with the newer, post 11/2022 firmware.
Galactic23
How do i get UHD disc to work on my XS07?
OS device name: I:
Revision: 1.01
Serial number:
Firmware date: 2020-09-03
Bus encryption flags: 13
Highest AACS version: 68
Drive platform: RS8E20
Firmware version: 1.01
OS device name: I:
Revision: 1.01
Serial number:
email me that drive info to the email belowGalactic23 wrote: Fri Oct 24, 2025 11:38 pm How do i get UHD disc to work on my XS07?
OS device name: I:
Revision: 1.01
Serial number:
Thank you for explaining this with such clarity. This is vital information to know. I will keep my XS07 for now and look for a UHD enabled drive in the meantime.MartyMcNuts wrote: Thu Oct 23, 2025 11:06 pmMike has said that the newer Pioneer drives will be libredrive supported but that does not mean UHD supported. I'm not sure if there will be any flashing required or if libredrive will just be enabled, so, if it's the latter, unless your drive is an actual UHD model (XS07UHD) then it more than likely won't support UHD discs.Voxelium wrote: Thu Oct 23, 2025 10:31 pm Hello,
With that being said, do you think firmware cross-flashing might be possible at a later stage somewhere down the line? I have no problem waiting, as long as there is a possibility that it can be done at some point.
Cheers!
• LG WH16NS60 (x2)
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
Honestly, nobody can say. We all just have to wait and see what method Mike ends up using.Voxelium wrote: Sat Oct 25, 2025 5:28 amThank you for explaining this with such clarity. This is vital information to know. I will keep my XS07 for now and look for a UHD enabled drive in the meantime.MartyMcNuts wrote: Thu Oct 23, 2025 11:06 pmMike has said that the newer Pioneer drives will be libredrive supported but that does not mean UHD supported. I'm not sure if there will be any flashing required or if libredrive will just be enabled, so, if it's the latter, unless your drive is an actual UHD model (XS07UHD) then it more than likely won't support UHD discs.Voxelium wrote: Thu Oct 23, 2025 10:31 pm Hello,
Cheers!
How can I flash my optical drive to enable UHD/ripping support?
Revision: 1.01
Revision: 1.01
Hello. It looks like this one should be doable?
Please and thank you!
Revision: 1.01
Serial number:
Highest AACS version: 82
Revision: 1.01
Serial number:
PM sent.uptou2 wrote: Sat Oct 25, 2025 5:26 pm How can I flash my optical drive to enable UHD/ripping support?
Revision: 1.01
PM sent.MicroFilm wrote: Sun Oct 26, 2025 1:32 am Hello. It looks like this one should be doable?
Revision: 1.01
Serial number:
ducdalsace
Hello!
How can i flash the drive to UHD ripping support ?
Thanks.
Revision: 1.01
Serial number: REMOVED
Thanks.
Revision: 1.01
This seemed to work.Coopervid wrote: Sun Oct 26, 2025 6:40 pmPM sent.MicroFilm wrote: Sun Oct 26, 2025 1:32 am Hello. It looks like this one should be doable?
Revision: 1.01
Serial number:
I have two identical drives. One works perfectly now. The second drive does find a UHD disc, but MakeMKV fails to open it.
Did I mess something up? Or should to share the current drive information for the one that's stuck?
Thanks again.
Edit: I found another USB port and they both work. Thanks!
PM sent.ducdalsace wrote: Sun Oct 26, 2025 6:57 pm Hello!
Thanks.
Revision: 1.01
