Validating disc...
21:28:24 - ----------- FindVUK 1.82 -----------
To close FindVUK simply press the ESC key
21:28:24 - MODE: ValidateDisc
21:28:24 - DriveLetter : E
21:28:24 - SettingsFile: >C:\Users\ehar8\OneDrive\Desktop\FindVUK\config\FindVUK.ini<
21:28:24 - Logfile >C:\Users\ehar8\OneDrive\Desktop\FindVUK\log\2025-10-23_FindVUK.txt< Default Loglevel >2<
21:28:24 - Update enabled - check for update
21:28:25 - No update required
21:28:25 - Open Main-KEYDB file: >C:\Users\ehar8\AppData\Roaming\aacs\KEYDB.cfg<
21:28:29 - Open Backup-KEYDB file: >C:\Users\ehar8\OneDrive\Desktop\FindVUK\VUKbackup\KEYDB.cfg<
21:28:29 - Get basic AACS data
21:28:29 - AACS folder on disc is reachable - Validate is possible
21:28:30 - VolumeName >88542934_SAW3_BLURAY<
21:28:30 - DiscId >E852417A86E9C8E3B5B8F2B7D2B1DDA0681AFD34< (2006-12-11)
21:28:30 - DiscType >BD<
21:28:30 - MKB Revision >3<
21:28:30 - Disc-BusEncEnabled >0<
21:28:30 - Drve-BusEncCapable >1<
21:28:30 - UnitKeyCount >1<
21:28:30 - >>> UnitKeyENC (1) >73581A4A4E1A5DF1802C73D883E3E93F<
21:28:30 - No entry for discid >E852417A86E9C8E3B5B8F2B7D2B1DDA0681AFD34< available in keydb >C:\Users\ehar8\AppData\Roaming\aacs\KEYDB.cfg< - no validation possible!
21:28:30 - Eject the disc now from drive >E:\<
21:28:34 - Successfully ejected the media in drive E!
Saw III Failed
eric_harrison
Saw III Failed
Re: Saw III Failed
Your validation may not have worked properly but the main thing is that a record for this disc id: E852417A86E9C8E3B5B8F2B7D2B1DDA0681AFD34 is in the KeyDB.eric_harrison wrote: ↑Fri Oct 24, 2025 2:29 amValidating disc...
