MakeMKV 1.7.2 and 1.7.1 failed BluRay Rip
TheOneAndOnly
Post by TheOneAndOnly »
The Conspirator (Robert Redford Directed-2011 release with AACS v21) BluRay gives the following error messages under Make MKV 1.7.2 (purchased) running on Dual quad core 2.8GHz Intel Xeon Mac Pro with .MacOS 10.6.8 despite disk cleaning, permission repair, and restart. I also had the same experience with v 1.7.1 Despite earlier flawless function (years) the most current 2 versions of MakeMKV will not successfully rip this BluRay ...... I tried both titles that were 23.6G each.
MakeMKV v1.7.2 darwin(x86-release) started
Optical drive "DVD+R-DL PIONEER DVD-RW DVR-112D BC14" opened in DASPI v1.3 mode.
Optical drive "HD-DVD-ROM HL-DT-ST BD-RE GGW-H20L YL04" opened in DASPI v1.3 mode.
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00031.m2ts' at offset '0'
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00031.m2ts' at offset '6144'
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00031.m2ts' at offset '12288'
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00031.m2ts' at offset '18432'
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00031.m2ts' at offset '24576'
File 00015.mpls was added as title #0
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00032.m2ts' at offset '0'
Title #00030.mpls was skipped
File 00004.mpls was added as title #1
Title #00003.mpls has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '0'
Title #00016.mpls was skipped
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00014.m2ts' at offset '0'
Title #00018.mpls was skipped
Title #00000.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.mpls has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00033.m2ts was added as title #2
Title #00021.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00015.m2ts was added as title #3
File 00014.m2ts was added as title #4
Title #00012.m2ts has length of 107 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00011.m2ts was added as title #5
Title #00032.m2ts was skipped
Title #00020.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00037.m2ts was added as title #6
Title #00025.m2ts has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00028.m2ts was added as title #7
Title #00008.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00000.m2ts was added as title #8
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00016.m2ts' at offset '0'
Title #00016.m2ts was skipped
Title #00006.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00030.m2ts was added as title #9
File 00029.m2ts was added as title #10
Title #00010.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00027.m2ts was added as title #11
File 00026.m2ts was added as title #12
File 00018.m2ts was added as title #13
File 00024.m2ts was added as title #14
File 00017.m2ts was added as title #15
File 00022.m2ts was added as title #16
Title #00007.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00002.m2ts was added as title #17
Saving 1 titles into directory /Users/knot2bfound/Movies/The_Conspirator
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '13910667264'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '13913290752'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '13913303040'
Failed to save title 1 to file /Users/knot2bfound/Movies/The_Conspirator/t01_The_Conspirator.mkv
0 titles saved, 1 failed
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '13914077184'
Failed to save title 8 to file /Users/knot2bfound/Movies/The_Conspirator/t08_The_Conspirator.mkv
Re: MakeMKV 1.7.2 and 1.7.1 failed BluRay Rip
Post by mike admin »
TheOneAndOnly wrote: Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '13914077184'
This is a physically damaged disc.
Viking
Post by Viking »
I'm getting the same message. The disc plays just fine on my PS3.
TheOneAndOnly
Viking.... I must agree with Mike's advice to me. I have been able to obtain different version, sometimes same version on different disc and they work fine. Sometimes it is a malformed format. The disks I can't rip always play on my Sony BR player. Hope this helps
Viking
Post by Viking »
TheOneAndOnly wrote:Viking.... I must agree with Mike's advice to me. I have been able to obtain different version, sometimes same version on different disc and they work fine. Sometimes it is a malformed format. The disks I can't rip always play on my Sony BR player. Hope this helps
I've got this message on about 3 of the last 7 discs I've tried. All play perfectly on my PS3. I'm wondering if there is some copy protection on these discs that are throwing MakeMKV for a loop? Perhaps there is an issue with the drive? It is a external portable LG drive "Slim Portable Blu-ray Writer" model BP40NS20.
If you can suggest a trial version of some software that does a function similar to MakeMKV then that might tells us if the issue is the drive, the disc, or MakeMKV.
TheOneAndOnly
Hate to quote you any names on this forum.... Google can find you a bunch. Honestly there are several, but none as good as Makemkv. I do know that not every BR drive is compatible with Makemakv. Also make sure you use DASPI 1.3
Viking
Post by Viking »
TheOneAndOnly wrote:Hate to quote you any names on this forum.... Google can find you a bunch. Honestly there are several, but none as good as Makemkv. I do know that not every BR drive is compatible with Makemakv. Also make sure you use DASPI 1.3
How do I know if I'm using DASPI 1.3? My drive came with an old version of Cyberlink PowerDVD (version 10). I don't if that installed it? Does installing MakeMKV also install DASPI?
Even when makeMKV works it takes 5-10 minutes to start. I don't know what it is doing in these 5-10 minutes.
Romansh
Post by Romansh »
Viking wrote:How do I know if I'm using DASPI 1.3? My drive came with an old version of Cyberlink PowerDVD (version 10). I don't if that installed it?
This is the MakeMKV for Mac OS X subforum. You can't install PowerDVD under OS X. You can't install the DASPI kext under non-OSX OSes.
Limey
Post by Limey »
Viking wrote:I've got this message on about 3 of the last 7 discs I've tried. All play perfectly on my PS3. I'm wondering if there is some copy protection on these discs that are throwing MakeMKV for a loop? Perhaps there is an issue with the drive? It is a external portable LG drive "Slim Portable Blu-ray Writer" model BP40NS20.
I am getting the same error on multiple discs. For one - LOTR extended editions - it ripped FOTR and ROTK just fine, but spit out TTT. Can't be a new type of encryption, therefore, it must be something else.
There hasn't been an update to MakeMKV lately, so I am at a loss to know why it has suddenly started having problems.
MPAlbright
Post by MPAlbright »
I have only had this problem with one disc, and it is Despicable Me that I bought from the UK (Most all of my blu rays are from the US). I have the LG BP06LU10. I'm thinking that it doesn't read the format.
Vilago
Post by Vilago »
I am getting this problem too. This is the second time it's happened in between only 3 out of the last 3 rips. What is going on here?
It's not makemkv's fault, because it won't mount to the desktop right away either. it just makes a lot of repetitive whirring noises, one of them clearly sounds like a "nah-uh" like it's telling me to forgettaboutit...
this is the first i've had problems since i started ripping in august this year. drive is only 6 months old. it's also the LG slim blu ray drive, maybe it's the drive starting to conk out?
Vilago
Post by Vilago »
Also, for the record the error mine keeps giving is:
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading 'BD-RE HL-DT-ST BD-RE BP40NS20 ML01' at offset '24977078272'
maybe that "offset" code somehow can tell us what its having trouble with? Like I said though, it doesn't seem to be makemkv's fault, it seems to either be a bus problem or hardware/media problem.
