BDR-XS07S UHD Flash
nilsman
Re: BDR-XS07S UHD Flash
Post by nilsman » Thu Oct 23, 2025 8:56 pm
How to enable LibreDrive?
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.00
Serial number: ***
Firmware date: 2019-01-07
Highest AACS version: 76
Firmware version: ID69
Post by Coopervid » Thu Oct 23, 2025 8:58 pm
nilsman wrote: Thu Oct 23, 2025 8:56 pm How to enable LibreDrive?
Revision: 1.00
Serial number: ***
PM sent.
Voxelium
Post by Voxelium » Thu Oct 23, 2025 10:31 pm
I have one of these, but the firmware is post-patch. I am aware of the recent news regarding pioneer drives though.
I was just wondering, when the new fix rolls out and 4k UHD support is restored to post-patch Pioneer drives, will this model be one of the supported drives?
I bought it intentionally while they were still readily available for MSRP, knowing the firmware was post-patch, because I know a fix will come eventually, and I would rather get it while they are still available.
TL;DR Will this drive with post-patch firmware work with the upcoming fix for pioneer drives, whenever it releases?
Much appreciated! :-)
• LG WH16NS60 (x2)
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• PANASONIC SW-9576-C
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
Post by MartyMcNuts » Thu Oct 23, 2025 11:06 pm
Voxelium wrote: Thu Oct 23, 2025 10:31 pm Hello,
Mike has said that the newer Pioneer drives will be libredrive supported but that does not mean UHD supported. I'm not sure if there will be any flashing required or if libredrive will just be enabled, so, if it's the latter, unless your drive is an actual UHD model (XS07UHD) then it more than likely won't support UHD discs.
The XS07S would need to be cross-flashed to enable UHD support and we just don't know at this stage if firmware flashing will be enabled or not with the newer, post 11/2022 firmware.
Galactic23
Post by Galactic23 » Fri Oct 24, 2025 11:38 pm
How do i get UHD disc to work on my XS07?
OS device name: I:
Revision: 1.01
Serial number:
Firmware date: 2020-09-03
Bus encryption flags: 13
Highest AACS version: 68
Drive platform: RS8E20
Firmware version: 1.01
Post by Billycar11 » Sat Oct 25, 2025 12:30 am
Galactic23 wrote: Fri Oct 24, 2025 11:38 pm How do i get UHD disc to work on my XS07?
OS device name: I:
Revision: 1.01
Serial number:
email me that drive info to the email below
Voxelium
Post by Voxelium » Sat Oct 25, 2025 5:28 am
MartyMcNuts wrote: Thu Oct 23, 2025 11:06 pm
Thank you for explaining this with such clarity. This is vital information to know. I will keep my XS07 for now and look for a UHD enabled drive in the meantime.
With that being said, do you think firmware cross-flashing might be possible at a later stage somewhere down the line? I have no problem waiting, as long as there is a possibility that it can be done at some point.
Cheers!
• LG WH16NS60 (x2)
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
Post by MartyMcNuts » Sat Oct 25, 2025 5:49 am
Voxelium wrote: Sat Oct 25, 2025 5:28 am
Cheers!
Honestly, nobody can say. We all just have to wait and see what method Mike ends up using.
uptou2
Post by uptou2 » Sat Oct 25, 2025 5:26 pm
How can I flash my optical drive to enable UHD/ripping support?
Revision: 1.01
MicroFilm
Post by MicroFilm » Sun Oct 26, 2025 1:32 am
Hello. It looks like this one should be doable?
Please and thank you!
Revision: 1.01
Serial number:
Highest AACS version: 82
Post by Coopervid » Sun Oct 26, 2025 6:39 pm
uptou2 wrote: Sat Oct 25, 2025 5:26 pm How can I flash my optical drive to enable UHD/ripping support?
Revision: 1.01
PM sent.
Post by Coopervid » Sun Oct 26, 2025 6:40 pm
MicroFilm wrote: Sun Oct 26, 2025 1:32 am Hello. It looks like this one should be doable?
Revision: 1.01
Serial number:
PM sent.
ducdalsace
Post by ducdalsace » Sun Oct 26, 2025 6:57 pm
Hello!
How can i flash the drive to UHD ripping support ?
Thanks.
Revision: 1.01
Serial number: REMOVED
MicroFilm
Post by MicroFilm » Sun Oct 26, 2025 8:15 pm
Coopervid wrote: Sun Oct 26, 2025 6:40 pm
Revision: 1.01
Serial number:
PM sent.
This seemed to work.
I have two identical drives. One works perfectly now. The second drive does find a UHD disc, but MakeMKV fails to open it.
Did I mess something up? Or should to share the current drive information for the one that's stuck?
Thanks again.
Edit: I found another USB port and they both work. Thanks!
Post by Coopervid » Tue Oct 28, 2025 10:47 am
ducdalsace wrote: Sun Oct 26, 2025 6:57 pm Hello!
Thanks.
Revision: 1.01
PM sent.
