unclecuddles
Post by unclecuddles »
Hi there. My drive is failing to read discs, so suspect it is wearing out (if that's possible). I have a Pioneer BDR-XD05TB with a manufacturing date of August 2017 - do you know if this is flashable? Thanks.
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: QHDL015093WL
Firmware date: 2017-06-22
Highest AACS version: 82
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
unclecuddles wrote:
Thu Oct 23, 2025 7:26 pm
Revision: 3.10
clean the lasers very easy on that drive just open it and use lint free cloths and some water and or alcohol
unclecuddles
Sorry if I was not clear, my other drive is failing. The Pioneer is an old drive that I have which has never been flashed, and I don't know if it can be (to read UHD discs).
unclecuddles wrote:
Thu Oct 23, 2025 7:37 pm
email me the drive info for the pioneer see below
unclecuddles
My current drive is
Product: BD-RE WH16NS60
Revision: 1.02
Bought a few years ago from someone on here (can't remember who). It works for a bit then starts to make grinding noises. I'm wondering if it is overheating.
unclecuddles wrote:
Thu Oct 23, 2025 7:43 pm
My current drive is
Revision: 1.02
see email below i can flash your pioneer to do UHD email the pioneer info below the lg is junk
Mark Alexis
Post by Mark Alexis »
Hey guys,
Forgive me if this question has been answered elsewhere, but I can't seem to find any documentation on it. Relative n00b here... I'm trying to flash a (supposedly) new ASUS BW-16D1HT, but the tool tells me the drive is not on the MT-1959 platform. This is a new one to me. I actually successfully flashed another one of these about six weeks ago. The present copy was built December '23 and ordered off Amazon (delivered unsealed, by the way). Windows Explorer recognizes the drive, but MakeMKV won't. I'm using a Vantec USB enclosure, if that makes any difference.
Any thoughts? Is the drive faulty, or the enclosure perhaps?
Thanks.
Mark Alexis wrote:
Thu Oct 23, 2025 8:11 pm
Hey guys,
Thanks.
Can you post what MakeMKV shows for the drive?
Mark Alexis
dcoke22 wrote:
Thu Oct 23, 2025 11:53 pm
Hey guys,
Thanks.
It’s not even recognizing it. I can only see it in Explorer.
Mark Alexis
Mark Alexis wrote:
Fri Oct 24, 2025 12:31 am
Hey guys,
Thanks.
FWIW: A YouTuber I communicate with on the topic thinks the drive might be counterfeit and urged me to return it ASAP, which I will do. It's a shame, because I was hoping for some future proofing. It looks like they're running out of stock fast now.
Subprime4829
Post by Subprime4829 »
Trying to flash a BP50NB40. Firmware HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917 was successfully flashed but trying to flash HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin, even though it says "done successfully" in the terminal does nothing. It will still show the BP50NB40-NB50-1.03 firmware in MakeMKV. I'm on macOS 26.
Tried using both
./makemkvcon f -d '/IOBDServices/identifier' -f /tmp/sdf.bin rawflash enc -i /tmp/HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
and
./makemkvcon f -d '/IOBDServices/identifier' -f /tmp/sdf.bin rawflash main -i /tmp/HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
Subprime4829 wrote:
Sun Oct 26, 2025 5:10 am
Tried using both
and
Stop posting the same thing in multiple threads!!!!!
You have been answered in other posts.
finnishrider
Post by finnishrider »
is this possible to flash with a working firmware for UHD discs?
Station information
Operativsystemets stasjons navn: E:
Produsent: PIONEER
Produkt: BD-RW BDR-UD03
Revisjon: 1.14
Serienummer:
Firmware dato: 2020-06-15
Krypteringsflagg for databus: 1B
Høyeste AACS versjon: 81
Drive platform: RS8511
Firmware version: 1.14
Post by d00zah »
striven1981 wrote:
Thu Oct 23, 2025 2:38 pm
If you notice, the START & EXIT buttons have enlarged fonts & the word START is cut off.
When I click the Start button, nothing happens.
Anyone experience this? Any advice would greatly be appreciated!
I don't see any responses, yet, so... is MakeMKV installed (in the default location)?
d00zah wrote:
Thu Oct 30, 2025 1:08 am
If this drive is an Archgon, it cannot be flashed in the enclosure. You must remove the drive from the enclosure to flash it.
