Mr_Orange
Re: SDFtool Flasher
Post by Mr_Orange » Wed Oct 15, 2025 6:24 am
I think my drive has had it. It read the cleaning disc and it will read CDs but nothing else, even after cleaning.
Re: SDFtool Flasher
Post by Coopervid » Wed Oct 15, 2025 9:13 am
Yes, these drives tend to die early. One of mine already after 1 year.
Mr_Orange
Re: SDFtool Flasher
Post by Mr_Orange » Wed Oct 15, 2025 10:09 am
Mine has lasted over 6 years, so I'm pretty happy with that. During that time, there were probably less than 5 UHDs that it couldn't rip.
smileyguy
Re: SDFtool Flasher
Post by smileyguy » Thu Oct 23, 2025 1:23 pm
When reading firmware from a LG WH16NS60 v1.00 I get a .bin file but when reading the firmware from my second WH16NS60 v1.03 I get a .tar file. Is the .tar file a good valid backup file and can it be used to flash the drive back to factory?
Re: SDFtool Flasher
Post by Coopervid » Thu Oct 23, 2025 2:40 pm
You can't dump LG firmware. What you get is just the calibration data. Therefore you can't flash a drive with what is dumped.
smileyguy
Re: SDFtool Flasher
Post by smileyguy » Thu Oct 23, 2025 4:42 pm
Thanks good to know that .tar is ony calibration data and not a firmware backup.
Another odd thing is that WH16NS60 with v1.03 firmware is Libre drive enabled as received. I did not flash the drive with 1.02MK as needed to enable Libre drive. My WH16NS60 with v1.00 say original unpatched but the v1.03 drive says microcode re-enabled. I haven't flashed either drive as it is not required. Backed up my 4k Superman 2025 without issue. Does microcode re-enabled mean encrypted or previously flashed? Does 1.02MK report as v1.03?
Re: SDFtool Flasher
Post by MartyMcNuts » Thu Oct 23, 2025 11:09 pm
Yeah, someone has flashed WH16NS60 1.03-MK to it.
smileyguy
Re: SDFtool Flasher
Post by smileyguy » Fri Oct 24, 2025 12:10 am
Thanks good to know that .tar is only calibration data and not a firmware backup.
Ok, I did not know there was a 1.03MK. When I got home I checked the firmware with SDFTool and neither are encrypted. Read function gives a .bin file for v1.00 and a .tar for v1.03.
Re: SDFtool Flasher
Post by MartyMcNuts » Fri Oct 24, 2025 1:13 am
Yeah, there is a 1.03-MK but it's still not as good as 1.02-MK. Just leave it alone until you start having read issues.
Subprime4829
Re: SDFtool Flasher
Post by Subprime4829 » Sun Oct 26, 2025 5:26 am
How do I flash my BP50NB40 SVC:NB52 on macOS 26? I don't have access to a Windows machine at all so I can't use the GUI tool.
Re: SDFtool Flasher
Post by MartyMcNuts » Sun Oct 26, 2025 5:55 am
Terminal or a good VM.
