Profiles settings discussion
Re: Profiles settings discussion
+1 on the subtitle token.
- Contact:
The N syntax is unfortunately brokenNodNarb012 wrote:I think that -sel:2 should match second (and third, forth, and so on) instance of my favlang subtitle tracks and de-select it, but instead I get the error: Profile parsing error: Invalid token '-sel:2'Code: Select all
-sel:all, +sel:(favlang|nolang), -sel:(havemulti|havelossless), +sel:(core*(favlang|nolang)), -sel:2, =100:all, -10:favlang
Do I have the syntax wrong or is this broken?
Nice. Please remember adding compression for PGS subs too.
How do we select a different type of input? For example, I'd like to apply different selection logics for audio (favlang only) and subtitles (favlang + French is available).
Your examples only show 3 types of input: default, LPCM-stereo, LPCM-multi - but nothing for e.g. all subtitles (or at least each subtitle type)…
- Contact:
Input/output settings are not relevant for selection/ordering, just ignore them for now.Romansh wrote:How do we select a different type of input? For example, I'd like to apply different selection logics for audio (favlang only) and subtitles (favlang + French is available).
So what I'm trying to do is not possible for now?
- Contact:
No, it's absolutely possible. However unless "subtitle" token is introduced in 1.7.3 , you'll have to make a lot of duplications. Attached is an XSD file for profile, it shows all possible input types. Output settings are presently ignored, but you can assign any selection settings per input type. All input types are:Romansh wrote:So what I'm trying to do is not possible for now?
<xs:enumeration value="default"/>
<xs:enumeration value="Mpeg1"/>
<xs:enumeration value="Mpeg2"/>
<xs:enumeration value="Mpeg4"/>
<xs:enumeration value="VC1"/>
<xs:enumeration value="MP2"/>
<xs:enumeration value="MP3"/>
<xs:enumeration value="AC3-stereo"/>
<xs:enumeration value="AC3-multi"/>
<xs:enumeration value="DTS-stereo"/>
<xs:enumeration value="DTS-multi"/>
<xs:enumeration value="EAC3-stereo"/>
<xs:enumeration value="EAC3-multi"/>
<xs:enumeration value="MLP-stereo"/>
<xs:enumeration value="MLP-multi"/>
<xs:enumeration value="MLP-core-stereo"/>
<xs:enumeration value="MLP-core-multi"/>
<xs:enumeration value="DTSHD-stereo"/>
<xs:enumeration value="DTSHD-multi"/>
<xs:enumeration value="DTSHD-core-stereo"/>
<xs:enumeration value="DTSHD-core-multi"/>
<xs:enumeration value="DTSHDLBR-stereo"/>
<xs:enumeration value="DTSHDLBR-multi"/>
<xs:enumeration value="LPCM-stereo"/>
<xs:enumeration value="LPCM-multi"/>
<xs:enumeration value="VOBSUB"/>
<xs:enumeration value="VOBSUB-forced"/>
<xs:enumeration value="VOBSUBHD"/>
<xs:enumeration value="VOBSUBHD-forced"/>
<xs:enumeration value="PGS"/>
<xs:enumeration value="PGS-forced"/>
- profile.xsd.txt
- (5.88 KiB) Downloaded 1225 times
One thing I've noticed: if favlang is not set in preferences, MakeMKV seems to ignore the whole rule. Example:
Since I hadn't set favlang, MakeMKV seemed to ignore both rules and picked PGS and PGS-forced subtitles in all languages. Once I set favlang, MakeMKV honored both rules.
Another question: is it possible to set my new profile as the default profile used by the GUI?
<!-- Include English and French PGS subtitles -->
<trackSettings input="PGS">
<output outputSettingsName="copy"
defaultSelection="-all,+favlang,+nolang,+fre">
</output>
</trackSettings>
<!-- Include English PGS-forced subtitles -->
<trackSettings input="PGS-forced">
defaultSelection="-all,+favlang,+nolang">
</output>
</trackSettings>Another question: is it possible to set my new profile as the default profile used by the GUI?
Rename the original profile to default.mmcp.xml.org and copy yours over to default.mmcp.xml.
- Contact:
That's how it works - if no favorite language is set in preferences then favlang matches ANY language.Romansh wrote:Since I hadn't set favlang, MakeMKV seemed to ignore both rules and picked PGS and PGS-forced subtitles in all languages. Once I set favlang, MakeMKV honored both rules.
OK. Thanks for the clarification.
- Contact:
It's done in 1.7.3flogger123 wrote:Got my vote on the subtitle token.
Would a chapters token be possible? I'd like to limit the track selections to only the Title with the most chapters (usually the main content).
Sorry if I a missing something, I am just starting to wrap my head around the capabilities of Advanced mode.
Not AFAIK.
All titles are selected by default. This feature controls track selection logic, not title selection logic.
