PSA: New Archgon UHD drives do not allow flashing
larhaus
Post by larhaus » Thu Sep 25, 2025 10:42 pm
FYI for anyone considering buying a new Archgon UHD drive from Amazon, the controller chip in that enclosure of late does not allow flashing. (H/T Billycar11 - https://www.reddit.com/r/makemkv/commen ... _archgons/ )
This drive: archgon Premium Aluminum External USB 3.0 UHD 4K Blu-Ray Writer Super Drive for PC and Mac
I've acquired both old and new for kicks and grins to do some analysis.
Comparisons:
Package label:
"MD-8107S-U3YC-UHD unit - USB Y cable - USB C cable - User Manual - Protective Case" (old) vs. "MD-8107S-U3YC-UHD unit - USB C + A cable - User Manual - Protective Case" (new)
UPC code and all other text are identical
Enclosure interface:
Micro USB Type B SuperSpeed (old) vs. USB-C (new)
Controller chip:
initio INIC-3619PN (old) vs. initio INIC-3639PN (new)
Serial number (less deterministic than the above 3 characteristics, but might be good info):
00070xxx (old) vs. 00093xxx (new)
So if your Archgon enclosure has the above new characteristics, then you won't be able to flash. When running Marty McNuts SDF Flasher, clicking on Start doesn't do anything. You'll have to remove the drive and use some other means of flashing it (another enclosure with a different controller chip or a computer with a slimline SATA slot). To remove the drive, just take a small screwdriver and carefully remove the two back feet, which will reveal two screws, unscrew and slide out the drive in its mounting bracket and then the rest is simple..
Anyway, I made a detection program (Windows) if you want to use it to check: ArchgonUHDDetector.7z
Or you can check which chip your Archgon is by going to Device Manager in Windows: Universal Serial Bus controllers > USB Mass Storage Device > Right-click for Properties > Details > Property dropdown - Hardware Ids
USB\VID_13FD&PID_3910&REV_0217 (old) vs. USB\VID_13FD&PID_5910&REV_0157 (new)
Hopefully this will help those who have purchased from Amazon so you can check it without opening the package or going too far and then you can just return it if you don't want it.
Re: PSA: New Archgon UHD drives do not allow flashing
Post by Billycar11 » Fri Sep 26, 2025 12:32 pm
very good post thank you i will use the new chipset info for when i contact mike as i did not know the new ones part number this may help him support it
also did not know they swapped to usb c on the drive side thats good as the other connector was very fragile i dealt with alot of rma's for broken ports on the micro b 3.0.
fyi for anyone here i did not confirm the safety of the checker program
the other provided info should be enough to know on your own
but again they keep doing this where they change stuff without notice the page still shows the usb 3 micro b connector and as we now know a new chipset
they should have made a new model for this not this stealth change nonsense its probably better for sure the port is but we just need to now know if the chipset can be worked around
larhaus
Post by larhaus » Fri Sep 26, 2025 5:11 pm
Thanks Billy, glad to help, and thank you for all your hard work!
I agree about those USB 3.0 Micro USB connectors; they're quite fragile. Hopefully the USB-C connection will prove better in the long run and at least the cables are easier to get and use. But I am guessing that's why they had to use a different chip for the product. I was also a bit disappointed that the UPC code and model numbers were exactly the same. I tried to post pictures of all of this inline in my post but phpBB didn't let me attach anything for some reason.
Regarding the program I wrote, it was just something fun I wanted to write and help others save time because I have a lot of USB devices connected to my computer and it's a pain to go through all of them in Device Manager lol :lol: , no malicious intent of course and it's coming from my own cloud storage. I figured some people might have trust issues so I put the hardware IDs to look for anyway. :)
Samus_Aran
Post by Samus_Aran » Sat Sep 27, 2025 10:27 pm
It too bad is was a nice drive. But saw this and sided to return
A.RABID.BUFFALO
Post by A.RABID.BUFFALO » Mon Sep 29, 2025 10:12 pm
I was able to get it flashed with a third party enclosure. However when it was reassembled I found that even though MakeMKV was able to see it as patched. When it tried to rip a UHD of a known good disc it would say aacs unknown and create a dump of the disc. Not sure if the chip has something to do with it.
Casper2209
Post by Casper2209 » Fri Oct 17, 2025 6:33 pm
I got one of the new models is it possible to flash it from a sata port from my motherboard by connecting it with a slimline sata to sata cable
im really new to this
Post by Coopervid » Fri Oct 17, 2025 7:31 pm
Casper2209 wrote: Fri Oct 17, 2025 6:33 pm I got one of the new models is it possible to flash it from a sata port from my motherboard by connecting it with a slimline sata to sata cable
Yes.
blind-s33r
Post by blind-s33r » Tue Oct 21, 2025 7:46 pm
A.RABID.BUFFALO wrote: Mon Sep 29, 2025 10:12 pm I was able to get it flashed with a third party enclosure. However when it was reassembled I found that even though MakeMKV was able to see it as patched. When it tried to rip a UHD of a known good disc it would say aacs unknown and create a dump of the disc. Not sure if the chip has something to do with it.
Same problem here, just flashed mine and when trying to dump a 4k disc it gives tons of scsi errors as such: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SG:dev_21:1'
and ends with saying libre drive isn't enabled even though it is.
Post by Coopervid » Tue Oct 21, 2025 7:53 pm
blind-s33r wrote: Tue Oct 21, 2025 7:46 pm
You have a power problem. Connect to USB-C on mainboard. Or the disc is not supported. Then you need to install KEYDB.cfg.
viewtopic.php?f=12&t=38293
blind-s33r
Post by blind-s33r » Tue Oct 21, 2025 8:13 pm
Coopervid wrote: Tue Oct 21, 2025 7:53 pm
Swapping the drive to my old vantec enclosure and it works fine, the archgon enclosure just wont work with 4k it seems...
Its plugged in to a powered dell thunderbolt 4 dock usb c port and it still give the errors, I have to assume the enclosure is blocking the commands.
Post by Coopervid » Tue Oct 21, 2025 8:19 pm
I guess it's a power problem. Use a powered USB hub. Your ports don't seem to provide enough power and these enclosures might be not be power efficient. We have seen that with the Verbatim enclosures.
blind-s33r
Post by blind-s33r » Tue Oct 21, 2025 8:28 pm
Coopervid wrote: Tue Oct 21, 2025 8:19 pm I guess it's a power problem. Use a powered USB hub. Your ports don't seem to provide enough power and these enclosures might be not be power efficient. We have seen that with the Verbatim enclosures.
The port works fine with the old archgon, the old vantec, but not the new archgon... we already know we cant flash the new archgon, so Im assuming that there are block on the instructions for 4k ripping in the enclosures firmware...
Ive tried using a powered 2.1 amp usb 3.0 hub and it doesn't work either btw...
the keydb file also does nothing.
Post by Coopervid » Tue Oct 21, 2025 8:31 pm
blind-s33r wrote: Tue Oct 21, 2025 8:28 pm
Post the Makemkv info. Make sure it's a MT1959 drive. You know that you have to switch enclosures for flashing?
blind-s33r
Post by blind-s33r » Tue Oct 21, 2025 8:41 pm
Coopervid wrote: Tue Oct 21, 2025 8:31 pm
I already swapped and flashed it do bu40n 1.00 as Im running linux, my other bu40ns work perfectly fine... well one is dying which is I grabbed the new archgon.
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: 1.00
Serial number: MO2P56B1549
Firmware date: 2116-12-20 15:28
Highest AACS version: 76
Firmware version: 1.00
Disc Information
Label: ALITA_BATTLE_ANGEL
Timestamp: 2019-05-28 16:01:22
Protection: AACS2.0/C v68
Data capacity: 59.20 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Post by Coopervid » Tue Oct 21, 2025 8:43 pm
blind-s33r wrote: Tue Oct 21, 2025 8:41 pm
Revision: 1.00
Disc Information
Number of layers: 2
Return it.
