kfoster1979
Post by kfoster1979 »
Thanks for the guide..
My old drive died last week, and I picked up a LG WP50NB40. Amazon delivered at noon, and I was ripping again by 12:30.
drkoontz
Post by drkoontz »
You guys/girls Rock, Thank you for the guides!!!
Spycrowsoft
Post by Spycrowsoft »
Billycar11 wrote:
Thu Oct 16, 2025 6:09 pm
Spycrowsoft wrote:
Thu Oct 16, 2025 5:11 pm
Since @Billycar11 offers to check...
I have a Verbatim 43888 slim drive with the following MakeMKV drive information:
OS device name: G:
Product: BD-RE BU40N
Revision: 1.05
Serial number: <redacted>
Highest AACS version: 68
Disc Information
Label: DR_STRANGELOVE
Timestamp: 2020-01-17 11:00:31
Protection: AACS2.0/C v68
Data capacity: 58.69 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
So if I understood the video correctly this is the command I need:
makemkvcon64.exe f --all-yes -d <drive letter> rawflash enc -i <path to LG slim BU40N folder>\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Is that correct for this drive?
yeah looks fine
Thanks for your faster than expected reply.
Unfortunately I did not get around to flashing this drive because it failed to burn BD-RE-DL and BD-RE-TL discs in my initial sanity test, so the drive is being returned as DOA. I'll check back in later when I have a replacement, but at least now I know what to do.
Spycrowsoft wrote:
Mon Oct 20, 2025 8:39 am
OS device name: G:
Revision: 1.05
Disc Information
Number of layers: 2
yeah looks fine
You should read this posted by kitahoshi:
https://forum.doom9.org/showthread.php?t=185539&page=19
Spycrowsoft
Coopervid wrote:
Tue Oct 21, 2025 11:04 am
yeah looks fine
Isn't this analogous to the -ssa -option of dvd+rw-format?
In that case the burner was most certainly faulty because I ran it with -ssa=default.
But that thread contained a lot of other useful information as well.
No. Only BD-Rs can be burned with spare areas. DVDs can not. However with DVDs you could define where the layer break happens for double-layer discs. Same issue that the quality at the outer edge before switching to the next layer was often bad. With BDs the buner MUST burn to the outer edge but if the burn there is bad this information can be burned to the spare area.
Spycrowsoft
Coopervid wrote:
Tue Oct 21, 2025 4:14 pm
Despite the name, dvd+rw-format also handles BlueRay formatting for the RE discs. :wink:
See: https://web.archive.org/web/20250512175 ... W/Blu-ray/
You are talking about the software, I was talking about the media.
McQueen216
Post by McQueen216 »
I think I've gotten it to flash alright. Drive information below. Windows 11 machine, connected internally, powering down between flashed. Drive shipped with v1.0, I've flashed it to this, that, and every other thing, to include with ASUS_BW-16D1HT_3.10_MK which I am pretty sure it didn't need. Drive manufactured in 2013.
The issue? Doesn't read any discs. I've deleted drivers, and had Win reinstall them fresh. I'm sure it's something small & insignificant & stupid that I've missed, but I've poured through here looking, applying diligence. Goal is to read & rip 4k. Help me, Obi-wan...
OS device name: F:
Product: BD-RE WH16NS60
Revision: 1.03
Serial number: SIK83D1TE232
Firmware date: 2120-05-08 10:10
Highest AACS version: 16
Firmware version: 1.03
McQueen216 wrote:
Tue Oct 21, 2025 6:35 pm
OS device name: F:
Revision: 1.03
Return it.
Spycrowsoft
Coopervid wrote:
Tue Oct 21, 2025 6:06 pm
Yes I understood that.
Thank you for your time though. I really appreciate it!
OS device name: F:
Revision: 1.03
If you flashed it to the Asus 3.10 on a 2013 drive you killed it the guide clearly states 2016+
striven1981
Post by striven1981 »
If you notice, the START & EXIT buttons have enlarged fonts & the word START is cut off.
When I click the Start button, nothing happens.
Anyone experience this? Any advice would greatly be appreciated!
ben79968
Post by ben79968 »
Successfully cross-flashed my 16D1H-U with A201 firmware to WH16NS58.
I flashed it to "A204," then "WH16NS60-1.03," and finally "WH16NS58-1.V5".
This will be the disc quality check driver.
I'm trying to find a Pioneer driver for burning discs.
unclecuddles
Post by unclecuddles »
Hi there. My drive is failing to read discs, so suspect it is wearing out (if that's possible). I have a Pioneer BDR-XD05TB with a manufacturing date of August 2017 - do you know if this is flashable? Thanks.
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: QHDL015093WL
Firmware date: 2017-06-22
Highest AACS version: 82
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
