PIONEER BDR-209 change the Firmware ?
Re: PIONEER BDR-209 change the Firmware ?
Post by Coopervid » Mon Sep 15, 2025 9:44 am
graffitiMSX wrote: Fri Sep 12, 2025 9:39 pm Hello, I have a Pioneer BDR-209MBK drive. I'm looking for help to make it UHD friendly with LibreDrive.
OS device name: E:
Current profile: BD-R SRM
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.54
Serial number:
Firmware date: 2022-05-31
Firmware version: ID04
Thank you.
PM sent.
Mauldäsch
Post by Mauldäsch » Sat Sep 27, 2025 9:52 am
Is it possible for this drive? I can't find anything.
Thank you for aassistance.
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E115
Serial number:
Firmware date: 2019-03-07
Drive platform: RS8F00
Firmware version: E115/ID71
Post by Coopervid » Sun Sep 28, 2025 9:28 am
Mauldäsch wrote: Sat Sep 27, 2025 9:52 am Is it possible for this drive? I can't find anything.
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E115
Serial number:
PM sent.
tt1270
Post by tt1270 » Mon Sep 29, 2025 5:58 pm
hye, i've this pioneer drive, can someone help me to flash the firmware for 4K-UHD?
I wish that Coopervid will help me, one more time
Thanks a lot
Best regards
Informations lecteur
Nom du lecteur SE : D:
Fabricant : PIONEER
Produit : BD-RW BDR-209D
Révision : 1.34
Numéro de série :
Date micrologiciel : 2016-04-25
Marqueurs d'encryptage bus : 13
Version AACS la plus haute : 68
Drive platform: RS8600
Firmware version: 1.34/ID61
Aucun disque
wildchild77
Post by wildchild77 » Sat Oct 18, 2025 6:00 pm
Looking to see if an older Pioneer drive I had can be upgraded fro UHD
MKV Drive Info Below
OS device name: E:
Product: BD-RW BDR-209D
Revision: 1.10
Serial number: xxxxxxxx
Firmware date: 2013-09-10
Bus encryption flags: 13
Highest AACS version: 77
Firmware version: 1.10/ID61
Post by Coopervid » Sun Oct 19, 2025 9:33 am
tt1270 wrote: Mon Sep 29, 2025 5:58 pm hye, i've this pioneer drive, can someone help me to flash the firmware for 4K-UHD?
Thanks a lot
Best regards
Fabricant : PIONEER
Révision : 1.34
Numéro de série :
Aucun disque
PM sent.
Post by Coopervid » Sun Oct 19, 2025 9:35 am
wildchild77 wrote: Sat Oct 18, 2025 6:00 pm Looking to see if an older Pioneer drive I had can be upgraded fro UHD
OS device name: E:
Revision: 1.10
PM sent.
ulvac-mkv
Post by ulvac-mkv » Sun Oct 19, 2025 10:50 pm
I have three models that need more recent firmware:
BDR-209M_1.51
BDR-212V_1.02
BDR-UD03_1.14
Thanks in advance.
Post by Coopervid » Mon Oct 20, 2025 9:04 am
ulvac-mkv wrote: Sun Oct 19, 2025 10:50 pm I have three models that need more recent firmware:
BDR-209M_1.51
BDR-212V_1.02
BDR-UD03_1.14
Thanks in advance.
Post the Makemkv info for each drive.
ulvac-mkv
Post by ulvac-mkv » Tue Oct 21, 2025 2:43 pm
Apologies, here you go:
OS device name: T:
Revision: 1.51
Serial number: QEDL022380WL
Highest AACS version: 81
_________________________
OS device name: Z:
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: DADL025005WL
Firmware version: ID06
OS device name: F:
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: DADL518199WL
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
Post by Coopervid » Tue Oct 21, 2025 4:23 pm
ulvac-mkv wrote: Tue Oct 21, 2025 2:43 pm Apologies, here you go:
OS device name: T:
Revision: 1.51
OS device name: Z:
Revision: 1.02
OS device name: F:
Revision: 1.14
The drive platform for the 209 is missing (crucial!). Add this information and I will send the packages for all three.
ulvac-mkv
Post by ulvac-mkv » Tue Oct 21, 2025 5:35 pm
The 209's don't provide any LibreDrive platform info within MakeMKV. This was copied verbatim. Is there another way to retrieve it?
Post by Coopervid » Tue Oct 21, 2025 6:27 pm
ulvac-mkv wrote: Tue Oct 21, 2025 5:35 pm The 209's don't provide any LibreDrive platform info within MakeMKV. This was copied verbatim. Is there another way to retrieve it?
That's weird. I am going to send you the packages for the other 2 drives and instructions how to check the 209. It's crucial since there are 3 versions / possibilities and you need the right version to flasht the 209.
sounds
Post by sounds » Thu Oct 23, 2025 7:55 pm
one more please, if you'd be so kind :-)
Revision: 1.51
Serial number: SGDL0****6WL
Firmware date: 2018-05-08
Drive platform: RS8601
Firmware version: 1.51/ID61
Post by Billycar11 » Thu Oct 23, 2025 8:06 pm
sounds wrote: Thu Oct 23, 2025 7:55 pm one more please, if you'd be so kind :-)
Revision: 1.51
sure email me that drive info see email below
