Pioneer BDR-UD03 UHD possibility
WonderMage
Re: Pioneer BDR-UD03 UHD possibility
Post by WonderMage »
Coopervid wrote:
Wed Oct 15, 2025 8:55 am
WonderMage wrote:
Wed Oct 15, 2025 5:15 am
Hi Coopervid, I have a Pioneer BDR-UD03 from a Verbatim 43890 and would love to flash it for UHD rips. Thank you and the crew here that helps us out. Here are the specs ...
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: ...
Firmware date: 2020-06-15
Highest AACS version: 68
Drive platform: RS8511
Firmware version: 1.14
PM sent.
Thank You very much for that. I'll flash it in the morning. Do you or anyone else know if its best to connect the power brick for wall power and both usb plugs simultaneously, for flashing the firmware? I have the two usb plugs connected to two red usb 3.1 gen 2 ports on the back of my pc currently and it's ripping normal blu rays without issue. Thanks again for the help and this website
jburzynski9009
Post by jburzynski9009 »
Jumping into this as well, any possibility mine can be flashed for ripping 4k/UHD discs?
OS device name: K:
Revision: 1.14
Serial number: CIDLXXXXXXXX
Highest AACS version: 81
DarkMetatron
Post by DarkMetatron »
I would be very happy if I could get help flashing my drive too.
Laufwerksinformation
OS-Gerätename: /dev/sr0
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer: AEDL----------
Firmware-Datum: 2020-06-15
BroadwayBra
Post by BroadwayBra »
Hello looking to flash mine as well
Revision: 1.14
Serial number:
jburzynski9009 wrote:
Thu Oct 16, 2025 12:26 am
OS device name: K:
Revision: 1.14
PM sent.
DarkMetatron wrote:
Thu Oct 16, 2025 8:28 pm
Produzent: PIONEER
Revision: 1.14
PM sent.
BroadwayBra wrote:
Thu Oct 16, 2025 9:41 pm
Revision: 1.14
Serial number:
PM sent.
jogger15
Post by jogger15 »
Hi Coopervid, here ist my drive information. Thank you!
Produzent: PIONEER
Revision: 1.14
Serienummer: ...
jogger15 wrote:
Fri Oct 17, 2025 1:17 pm
Produzent: PIONEER
Revision: 1.14
Serienummer: ...
PM sent.
Chivs
Post by Chivs »
I also have the UD03 with firmware 1.14. Would appreciate flashing instructions.
Thanks.
Chivs wrote:
Fri Oct 17, 2025 6:51 pm
Thanks.
Post your Makemkv info.
Chivs
Post by Chivs »
Coopervid wrote:
Fri Oct 17, 2025 7:30 pm
Thanks.
OS device name: F:
Revision: 1.14
Serial number: BHDL497970WL
Highest AACS version: 77
Chivs wrote:
Fri Oct 17, 2025 8:09 pm
Thanks.
OS device name: F:
Revision: 1.14
PM is coming. Forum is terribly slow at the moment.
Chivs
Post by Chivs »
Coopervid wrote:
Sat Oct 18, 2025 10:02 am
OS device name: F:
Revision: 1.14
Much appreciated! Thanks.
tigyi
Post by tigyi »
If assistance is still available, I'd greatly appreciate it. Thank you!
Product: BD-RW BDR-XU03
Revision: 1.03
Serial number:
Firmware date: 2015-06-29
Bus encryption flags: 13
Highest AACS version: 76
Drive platform: RS8520
Firmware version: 1.03
