Second copy of same Blu-ray hangs during ripping
Re: Second copy of same Blu-ray hangs during ripping
I wonder if there is some sort of authoring error with 00015.m2ts on that disc?
Did you use MakeMKV to make a decrypted backup?
What happens if you try to make a .mkv of 00015.m2ts using MKVToolNix?
squash1621
Post by squash1621 »
new update
when trying to make a mkv file direct with makemkv i hangs, and timer just increse time to done
but when i make a unencryted backup, and then make a mkv file i MKVtoolnix it works just fine
squash1621
Tried one more time and just wait and se what happened and it worked. just have to wait 2 hours. it hangs and stand stil for 1 hour and then just finish.
video works fine.
but i got this log.
MakeMKV v1.17.6 win(x64-release) started
Using LibreDrive mode (v01.0 id=489CDFD6D392)
Title #00017.mpls has length of 9 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00016.mpls has length of 9 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00024.mpls has length of 66 seconds which is less than minimum title length of 100 seconds and was therefore skipped
File 00000.mpls (angle 1) was added as title #0
File 00000.mpls (angle 2) was added as title #1
Title #00025.mpls has length of 5 seconds which is less than minimum title length of 100 seconds and was therefore skipped
File 00007.mpls was added as title #2
Title #00026.mpls has length of 5 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00001.m2ts has length of 0 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00008.m2ts has length of 0 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00034.m2ts has length of 71 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00033.m2ts has length of 9 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00019.m2ts has length of 66 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00032.m2ts has length of 9 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00017.m2ts has length of 0 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00020.m2ts has length of 30 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00021.m2ts has length of 71 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00030.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00029.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00013.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00028.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00012.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00027.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00037.m2ts has length of 5 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00011.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00026.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00010.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00025.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00024.m2ts has length of 9 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00023.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00007.m2ts has length of 13 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00016.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00018.m2ts has length of 5 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00006.m2ts has length of 28 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00002.m2ts has length of 30 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Saving 2 titles into directory T:/Flåklypa Grand Prix
Error 'OS error - {Dataoverkjøring} Det oppstod en dataoverkjøringsfeil' occurred while reading '\Device\CdRom0' at offset '1282725888'
Error 'OS error - {Dataoverkjøring} Det oppstod en dataoverkjøringsfeil' occurred while reading '\Device\CdRom0' at offset '2436771840'
Error 'OS error - {Dataoverkjøring} Det oppstod en dataoverkjøringsfeil' occurred while reading '\Device\CdRom0' at offset '3647250432'
Error 'OS error - {Dataoverkjøring} Det oppstod en dataoverkjøringsfeil' occurred while reading '\Device\CdRom0' at offset '4850356224'
Error 'OS error - {Dataoverkjøring} Det oppstod en dataoverkjøringsfeil' occurred while reading '\Device\CdRom0' at offset '5824505856'
Error 'OS error - {Dataoverkjøring} Det oppstod en dataoverkjøringsfeil' occurred while reading '\Device\CdRom0' at offset '6254843904'
Error 'OS error - {Dataoverkjøring} Det oppstod en dataoverkjøringsfeil' occurred while reading '\Device\CdRom0' at offset '6436694016'
Error 'OS error - {Dataoverkjøring} Det oppstod en dataoverkjøringsfeil' occurred while reading '\Device\CdRom0' at offset '981891072'
Error 'OS error - {Dataoverkjøring} Det oppstod en dataoverkjøringsfeil' occurred while reading '\Device\CdRom0' at offset '1329162240'
Error 'OS error - {Dataoverkjøring} Det oppstod en dataoverkjøringsfeil' occurred while reading '\Device\CdRom0' at offset '2638823424'
Error 'OS error - {Dataoverkjøring} Det oppstod en dataoverkjøringsfeil' occurred while reading '\Device\CdRom0' at offset '4219871232'
Error 'OS error - {Dataoverkjøring} Det oppstod en dataoverkjøringsfeil' occurred while reading '\Device\CdRom0' at offset '5670500352'
Error 'OS error - {Dataoverkjøring} Det oppstod en dataoverkjøringsfeil' occurred while reading '\Device\CdRom0' at offset '6051176448'
Error 'OS error - {Dataoverkjøring} Det oppstod en dataoverkjøringsfeil' occurred while reading '\Device\CdRom0' at offset '1162610688'
Error 'OS error - {Dataoverkjøring} Det oppstod en dataoverkjøringsfeil' occurred while reading '\Device\CdRom0' at offset '1314963456'
Error 'OS error - {Dataoverkjøring} Det oppstod en dataoverkjøringsfeil' occurred while reading '\Device\CdRom0' at offset '3338956800'
Error 'OS error - {Dataoverkjøring} Det oppstod en dataoverkjøringsfeil' occurred while reading '\Device\CdRom0' at offset '6990950400'
Error 'OS error - {Dataoverkjøring} Det oppstod en dataoverkjøringsfeil' occurred while reading '\Device\CdRom0' at offset '7570679808'
AV sync issue in stream 3 at 1:28:05.504 with duration of 2123.328s : 66354 frame(s) dropped to reduce audio skew to +9.333ms
AV sync issue in stream 1,2 at 1:28:06.005 with duration of 2123.829s : 199109 frame(s) dropped to reduce audio skew to +9.333ms
AV sync issue in stream 5 at 0:00:00 : Forced subtitles track #5 turned out to be empty and was removed from output file
AV sync issue in stream 7 at 0:00:00 : Forced subtitles track #7 turned out to be empty and was removed from output file
2 titles saved
Niggi Biggi
Post by Niggi Biggi »
Years later, I have an update, along with a solution to my problem which I hope will help others!
Trying a different Blu-ray drive, in this case the ASUS BW-16D1HT over the LG BH16NS55, made no difference when ripping.
Making an unencrypted backup helped, and although I couldn't simply rip to an MKV from here as I encountered many problems, I eventually found this workaround:
  • In MakeMKV, make an unencrypted backup of the whole disc
  • In ImgBurn, make an ISO from the unencrypted backup
  • In MakeMKV, open up the ISO-file, select the 19.6 GB file (angle 1 in this example) and rip with ONLY video and subtitles:
    Solution for MakeMKV.png (90.92 KiB) Viewed 15714 times
  • In MKVToolNix GUI, drag and drop the ripped file, as well as "00000.mpls" into the "Multiplexer tab".
    You'll find "00000.mpls" inside of the folders you've used to make the ISO-file from, in my case in this destination:
    C:\Users\Username\Videos\Blu-ray rips\backup\FLAKLYPA GRAND PRIX\BDMV\PLAYLIST
  • Now, deselect all video, subtitles and chapters included in "00000.mpls":
    Solution for MKVToolNix GUI.png (133.45 KiB) Viewed 15714 times
  • Lastly, press "Start multiplexing" - you should now have all of the audio included on the Blu-ray in your new MKV-file
When I initially ripped to an MKV from the ISO, the MKV would crash right before the "race" chapter from the movie, and MakeMKV would also stall trying to rip the MKV containing audio, but without the audio it ripped just fine.
I think there's either some sort of a mastering error or possibly obscure copy protection involved on this disc, because I've never had this problem before.
normann
Post by normann »
This disc has also really been annoying to work with for me.
About half way through ripping the main title (in 00015.m2ts, my guess was when the laser changed layer), the read speed slowly heads towards zero. 75% through the disc (many hours later), the reading effectively stops. I cancelled the rip the next day. I notice that the read rate says "SAFE" in parenthesis, but I'm not sure that it did that when the rip started.
Thinking that my disc was defective, I bought another copy with the same issue.
Yesterday, I tried DVDFab 13. Ripped both angles of the movie in less than 15 minutes each. Wow.
Should this issue be looked into?
Niggi Biggi
normann wrote: Thu Feb 19, 2026 8:21 pm This disc has also really been annoying to work with for me.
If it is a software issue with MakeMKV, then it would be great if this could be looked into.
Otherwise, you may be able to solve the problem using my solution.
