Asus BW-16D1X-U
Midea
Re: Asus BW-16D1X-U
#271 Post by Midea » Sun Oct 19, 2025 12:59 pm
Hi
I purchased this drive a week ago and MakeMKV is showing me the following information:
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Firmware date: 2020-07-21
Highest AACS version: 82
Firmware version: ID76
I would like to flash this drive for UHD.
XxluccioxX44
Re: Asus BW-16D1X-U
#272 Post by XxluccioxX44 » Sun Oct 19, 2025 1:56 pm
Below are my information regarding my AsUs BW-16D1H-u. Right now, I cant read the UHD disc. Is there a possibility to read them ?
"Informations lecteur
Nom du lecteur SE : H:
Fabricant : ASUS
Produit : BW-16D1H-U
Révision : E116
Numéro de série : DEDL113932WL
Date micrologiciel : 2020-07-21
Marqueurs d'encryptage bus : 1B
Version AACS la plus haute : 81
Drive platform: RS8F00
Firmware version: E116/ID71
Unrestricted read speed: Yes"
Thanks a lot for your help.
Re: Asus BW-16D1X-U
#273 Post by Coopervid » Sun Oct 19, 2025 8:57 pm
Midea wrote: Sun Oct 19, 2025 12:59 pm Hi
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
PM is coming. The forum is unbearable slow.
cat_herder
Re: Asus BW-16D1X-U
#274 Post by cat_herder » Sun Nov 09, 2025 1:21 am
Coopervid would you mind sending me the information I need for flashing this drive as well?
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: -
Highest AACS version: 64
hyperform
Re: Asus BW-16D1X-U
#275 Post by hyperform » Sun Nov 09, 2025 5:24 pm
Any help would be appreciated
Current profile: DVD-ROM
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Highest AACS version: 46
Re: Asus BW-16D1X-U
#276 Post by Coopervid » Sun Nov 09, 2025 5:39 pm
XxluccioxX44 wrote: Sun Oct 19, 2025 1:56 pm Hi,
Fabricant : ASUS
Révision : E116
PM sent.
Re: Asus BW-16D1X-U
#277 Post by Coopervid » Sun Nov 09, 2025 5:40 pm
cat_herder wrote: Sun Nov 09, 2025 1:21 am Coopervid would you mind sending me the information I need for flashing this drive as well?
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: -
PM sent.
Re: Asus BW-16D1X-U
#278 Post by Coopervid » Sun Nov 09, 2025 5:46 pm
hyperform wrote: Sun Nov 09, 2025 5:24 pm Any help would be appreciated
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
PM sent.
Flyingj99
Re: Asus BW-16D1X-U
#279 Post by Flyingj99 » Wed Nov 12, 2025 6:54 pm
I just got a BW-16D1X-U. Can someone help me out with the info required to flash this drive for 4k UHD discs. Thanks!
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ************
Firmware version: E113/ID76
Tri0ptic
Re: Asus BW-16D1X-U
#280 Post by Tri0ptic » Wed Nov 12, 2025 8:42 pm
I am looking for some help with my drive. Thanks. Please let me know if more information is needed.
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: D*
Highest AACS version: 72
Re: Asus BW-16D1X-U
#281 Post by Coopervid » Thu Nov 13, 2025 10:43 am
Flyingj99 wrote: Wed Nov 12, 2025 6:54 pm I just got a BW-16D1X-U. Can someone help me out with the info required to flash this drive for 4k UHD discs. Thanks!
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
PM sent.
Re: Asus BW-16D1X-U
#282 Post by Coopervid » Thu Nov 13, 2025 10:45 am
Tri0ptic wrote: Wed Nov 12, 2025 8:42 pm I am looking for some help with my drive. Thanks. Please let me know if more information is needed.
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: D*
PM sent.
Flyingj99
Re: Asus BW-16D1X-U
#283 Post by Flyingj99 » Thu Nov 13, 2025 2:24 pm
Good to go. Backing up my first 4k UHD movie now. Thanks!
Tri0ptic
Re: Asus BW-16D1X-U
#284 Post by Tri0ptic » Thu Nov 13, 2025 6:06 pm
Thank you for the PM. When I start BDRFlash it says “No available devices found.” MakeMKV still sees it. There is no disc inside and it is closed. This is on Windows 11.
Without a disc, MakeMKV reports this:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: D*
Any suggestions? Thank you, again.
thebryantfisher
Re: Asus BW-16D1X-U
#285 Post by thebryantfisher » Thu Nov 13, 2025 9:31 pm
Hi all
Thanks in advance for your help. Very new to all of this. I have been reading through the forums and there are many variations of similar drives and wanted to get a sense of whether this one if UHD capable.
