MakeMKV Hangs
OneFastSkater
MakeMKV Hangs
#1 Post by OneFastSkater » Fri Feb 10, 2012 6:32 pm
MakeMKV v1.7.1 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/onefastskater/MakeMKV_log.txt
Optical drive "DVD+R-DL MATSHITA DVD-R UJ-868 KB19" opened in DASPI v1.3 mode.
Optical drive "BD-RE MATSHITA BD-MLT UJ240AS 1.11" opened in DASPI v1.3 mode.
When attempting to cancel the operation (hitting the red X) it prompts me if I’m sure I want to cancel the current operation and then never cancels. I repeated the cancel operations three times with the same result – program seems hung.
Quitting MakeMKV again asks if I want to cancel the current operation, clicking yes exit the program.
I can view the disk contents in “finder”, while MakeMKV appears hung.
The contents of the MakeMKV_log.txt file is:
Debug log started at Fri Feb 10 18:13:31 2012 , written by MakeMKV v1.7.1 darwin(x86-release)
001005:0000 MakeMKV v1.7.1 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/onefastskater/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL MATSHITA DVD-R UJ-868 KB19" opened in DASPI v1.3 mode.
002014:0000 Optical drive "BD-RE MATSHITA BD-MLT UJ240AS 1.11" opened in DASPI v1.3 mode.
Re: MakeMKV Hangs
#2 Post by mike admin » Sun Feb 12, 2012 7:35 am
What kind of disc do you have in drive, blu-ray or DVD? What title?
What happens if you start MakeMKV when there is no disc in drive, and then insert the disc?
Did it hang only with this specific disc or with any disc? Or also without any disc in drive?
OneFastSkater
Re: MakeMKV Hangs
#3 Post by OneFastSkater » Thu Feb 16, 2012 12:15 pm
It is a BluRay disk. Same disk every time, "Dirty Dancing".
Tried:
. Empty Drive
. Start MakeMKV
. Insert BluRay disk
. MakeMKV still hangs reading disk information
MakeMKV v1.7.2 darwin(x86-release) started
