MakeM<KV 1.7.2 and 1.7.1 Failed BluRay Rip
TheOneAndOnly
Post by TheOneAndOnly »
The Conspirator (Robert Redford Directed-2011 release with AACS v21) BluRay gives the following error messages under Make MKV 1.7.2 (purchased) running on Dual quad core 2.8GHz Intel Xeon Mac Pro with .MacOS 10.6.8 despite disk cleaning, permission repair, and restart. I also had the same experience with v 1.7.1 Despite earlier flawless function (years) the most current 2 versions of MakeMKV will not successfully rip this BluRay ......
MakeMKV v1.7.2 darwin(x86-release) started
Optical drive "DVD+R-DL PIONEER DVD-RW DVR-112D BC14" opened in DASPI v1.3 mode.
Optical drive "HD-DVD-ROM HL-DT-ST BD-RE GGW-H20L YL04" opened in DASPI v1.3 mode.
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00031.m2ts' at offset '0'
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00031.m2ts' at offset '6144'
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00031.m2ts' at offset '12288'
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00031.m2ts' at offset '18432'
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00031.m2ts' at offset '24576'
File 00015.mpls was added as title #0
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00032.m2ts' at offset '0'
Title #00030.mpls was skipped
File 00004.mpls was added as title #1
Title #00003.mpls has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '0'
Title #00016.mpls was skipped
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00014.m2ts' at offset '0'
Title #00018.mpls was skipped
Title #00000.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.mpls has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00033.m2ts was added as title #2
Title #00021.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00015.m2ts was added as title #3
File 00014.m2ts was added as title #4
Title #00012.m2ts has length of 107 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00011.m2ts was added as title #5
Title #00032.m2ts was skipped
Title #00020.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00037.m2ts was added as title #6
Title #00025.m2ts has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00028.m2ts was added as title #7
Title #00008.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00000.m2ts was added as title #8
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00016.m2ts' at offset '0'
Title #00016.m2ts was skipped
Title #00006.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00030.m2ts was added as title #9
File 00029.m2ts was added as title #10
Title #00010.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00027.m2ts was added as title #11
File 00026.m2ts was added as title #12
File 00018.m2ts was added as title #13
File 00024.m2ts was added as title #14
File 00017.m2ts was added as title #15
File 00022.m2ts was added as title #16
Title #00007.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00002.m2ts was added as title #17
Saving 1 titles into directory /Users/knot2bfound/Movies/The_Conspirator
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '13910667264'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '13913290752'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '13913303040'
Failed to save title 1 to file /Users/knot2bfound/Movies/The_Conspirator/t01_The_Conspirator.mkv
0 titles saved, 1 failed
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '13914077184'
Failed to save title 8 to file /Users/knot2bfound/Movies/The_Conspirator/t08_The_Conspirator.mkv
BlackDragon24
Re: MakeM<KV 1.7.2 and 1.7.1 Failed BluRay Rip
Post by BlackDragon24 »
TheOneAndOnly wrote:The Conspirator (Robert Redford Directed-2011 release with AACS v21) BluRay gives the following error messages under Make MKV 1.7.2 (purchased) running on Dual quad core 2.8GHz Intel Xeon Mac Pro with .MacOS 10.6.8 despite disk cleaning, permission repair, and restart. I also had the same experience with v 1.7.1 Despite earlier flawless function (years) the most current 2 versions of MakeMKV will not successfully rip this BluRay ......
Medium error suggests a bad disk....especially if done on two different systems with the same errors.
I successfully ripped this disk about a month ago, though it was a previous version of makemkv. Have you tried using an older version of makemkv to eliminate either the disk or your drive as the source of the failure?
TheOneAndOnly
Tried it with 1.6.5 through 1.7.0. The initial error always comes up during decrypting while the disc is being opened. Still no luck. Guess I will try another disk. Drive is fine. Ripped 2012 since the first post so I'm sure the drive is fine.
setarip_old
Post by setarip_old »
@TheOneAndOnly
Hi!
Then it certainly sounds like the disc is at fault - either dirty, physically damaged, or a manufacturing problem.
By all means, return it to the place of purchase in exchange for a new replacement...
