Is it possible to extract subtitles only from 4k/standard blu ray disc?
MacGyver221
#1 Post by MacGyver221 » Tue Oct 14, 2025 6:14 pm
I am completely fine with playing my blu ray discs(including 4k) but in order to translate subtitles I need to extract them. It seems pointless to process whole 4k video so I would be interested in extracting subtitles only(my assumption is that it would take just few minutes of time and few Mb of memory). Is this possible with makeMKV? If not is there anything else I can do?
Once extracted and translated I could pass subtitles to my player through USB
Re: Is it possible to extract subtitles only from 4k/standard blu ray disc?
#2 Post by Woodstock » Tue Oct 14, 2025 6:58 pm
Not with MakeMKV. The subtitle tracks are interspersed with the video and audio tracks, so you're going to have to scan the whole disk to extract JUST the subtitle tracks anyway.
MacGyver221
#3 Post by MacGyver221 » Tue Oct 14, 2025 10:39 pm
Woodstock wrote: Tue Oct 14, 2025 6:58 pm Not with MakeMKV. The subtitle tracks are interspersed with the video and audio tracks, so you're going to have to scan the whole disk to extract JUST the subtitle tracks anyway.
So it takes roughly similar amount of time to extract subtitles alone as it would be to have full quality 4k rip?
#4 Post by Woodstock » Tue Oct 14, 2025 10:45 pm
Yes. It's just the way the pieces are integrated into the disk, with everything part of a "single file"... although sometimes it's a collection of files.
My copy of Riselmine is a real mess, which was easier to simply rip it as one very long episode, then use handbrake to break it into separate ones. Trying to extract JUST the subtitles from the disk itself would not save any time vs. ripping everything and splitting it up.
MacGyver221
#5 Post by MacGyver221 » Tue Oct 14, 2025 10:54 pm
Thanks for detailed answer! Are you aware of any alternative that might interest me for my use case?
#6 Post by Woodstock » Tue Oct 14, 2025 11:54 pm
Personally, I use mkvtoolnix for splitting files if I'm not going to encode them, but I use handbrake if I want them smaller. If disks don't have a lot of swapping around, handbrake is fine.
But, what you've described is best handled with mkvtoolnix to break out the subtitle tracks, as well as splicing in your re-done subtitles. It has tools to pull specific tracks out, and merge multiple files together. Eons ago, I would pull subtitles from DVD versions of disks, and merge them with the Bluray versions, when I didn't have players that could display PGS subtitles.
Mr. Red
#7 Post by Mr. Red » Fri Oct 17, 2025 8:50 am
If you're only interested in (translated) subtitles you could search for them (in the preferred language) on opensubtitles.org. Sometimes you have to adjust the times slightly because releases in different regions can differ at the beginning (publisher logos etc.) so the main movie starts a few seconds earlier or later.
Woodstock wrote: Tue Oct 14, 2025 11:54 pm ... Eons ago, I would pull subtitles from DVD versions of disks, and merge them with the Bluray versions, when I didn't have players that could display PGS subtitles.
Can be difficult due to the different masterings (logos etc.) and frame rates of most DVDs (29.97, 25) and Blu-rays.
At least in most cases you can't simply mux them in and be done.
HSamwel
#8 Post by HSamwel » Sat Oct 18, 2025 11:17 am
Mr. Red wrote: Fri Oct 17, 2025 8:50 am If you're only interested in (translated) subtitles you could search for them (in the preferred language) on opensubtitles.org. Sometimes you have to adjust the times slightly because releases in different regions can differ at the beginning (publisher logos etc.) so the main movie starts a few seconds earlier or later.
The worst thing about all these external subtitles is that they NEVER define framerate used or length of the movie.
If they did it would be easier calculate stretch or set delays.
Also I have had some subtitles that fit att the beginning and the end but then are off in the middle. Still needing hand editing with a text editor.
Some doesn't make sense no matter how good how good you sync the beginning and the end. Don't know if a movie has the same content or if
it had something added or removed. In sweden atleast, we have no censur/cuts to any movies anymore since several decades.
For example the Warfare movie, I mistakenly bought the nordic release 4k. This was a hatchjob done and chocking that the original movie
company let this be released without checking.
It has 4k resolution, but with SDR colors, framrate was changed to 25hz from original 23.976, and atmos removed in favor of DTS-HD MA 5.1.
I also bought the Netherlands edition, which actually includes both atmos and a surprising Auro3D native 13.1 mixing.
To the point, I tried to stretch the subtitles from the nordic release with the netherlands. Could never get them to fit. No matter how I stretched
or delayed. As if the actual movie had differences.
Ended ut downloading a SRT which fit instantly with almost no change, only a small delay due to different start (company logos) length.
Haven't checked that much, is there a good subtitle editing tool were you can sync it to the audio in a simpler way?
Maybe were you can see the video and hear the audio and be able to edit both time and text?
Mr. Red
#9 Post by Mr. Red » Sat Oct 18, 2025 10:06 pm
HSamwel wrote: Sat Oct 18, 2025 11:17 am [...] Haven't checked that much, is there a good subtitle editing tool were you can sync it to the audio in a simpler way?
https://github.com/SubtitleEdit/subtitleedit
Shows video alongside subtitle editor and allows to jump trough the video based on the subtitle times.
Has a lot of different sync options and allows to change the "framerate" of the subtitles.
