: TRANSFORMERS_RISE_OF_BEASTS
Andy55
Post by Andy55 »
Hallo kann mir da ener weiderhelfen Timestamp: 2023-08-02 13:49:49
Protection: AACS2.0/C v77
Data capacity: 84.53 GB Direct access mode is in use
Loading content hash table, verifying integrity of M2TS files.
AACS output file saved as C:/Users/Andreas 88 PC/Desktop/New Folder (3)/MKB20_v77_Transformers-_Rise_of_the_Beasts_42D3.tgz
The volume key for the DVD/Blu-ray is unknown - the video cannot be decrypted
DEBUG: Code 0 at K/7I6&O",`|u5 8d:213132721
DEBUG: Code 0 at K/7I6&O",`|u5 8d:213131341
Opening the disc failed
Laufwerksinformation
OS-Gerätename: H:
Aktuelles Profil: BD-ROM
Produzent: HL-DT-ST
Produkt: BD-RE BU40N
Revision: 1.03
Serienummer: MO9P6391454
Firmware-Datum: 2118-10-24 19:34
Markierungen der Bus-Verschlüsselung: 17
Highest AACS version: 77
Firmware version: 1.03
Re: : TRANSFORMERS_RISE_OF_BEASTS
Post by d00zah »
Andy55 wrote:
Sat Oct 18, 2025 4:50 pm
OS-Gerätename: H:
Produzent: HL-DT-ST
Revision: 1.03
Per the UHD FAQ:
MakeMKV says that "the volume key is unknown for this disc"?
MakeMKV produces an AACS .tgz dump file whenever you try to open a disc for which the key is unknown, and will report that the dump has been created. Email the dump file to svq@makemkv.com.
The alternative is explained in the 1st post of Public KeyDB Disc Submissions. It MAY get more immediate results than the 'official' process?
Andy55
Post by Andy55 »
OK I have sent an email I have to add something else. I played around a bit and used an older version, and lo and behold, the movies are now decrypted, which didn't work with the other version.
MakeMKV v1.14.5 win(x64-release) gestartet
Debug-Aufzeichnung eingeschaltet. Aufzeichnung wird gespeichert als C:\Users\Andreas 88 PC/MakeMKV_log.txt
Lade aktuelle SDF in C:/Users/Andreas 88 PC/Desktop/Neuer Ordner (3) ...
Automatisches Herunterladen von SDF ist deaktiviert oder fehlgeschlagen.
DEBUG: Code 152 at %.rR&vsq2cI<A6cT:29407040
Die neue Version 1.18.2 ist unter http://www.makemkv.com/download/ als Download verfügbar.
Direkter Zugriffsmodus wird verwendet
Using LibreDrive mode (v05 id=866A98CB9C4E)
Inhalte-Hashtabelle geladen, überprüfe Integrität der M2TS-Dateien.
Using Java runtime from C:\WINDOWS\system32\java.exe
Titel #00100.mpls hat eine Länge von 10 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
Titel #00399.mpls hat eine Länge von 30 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
Titel #00701.mpls hat eine Länge von 11 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
Titel #01073.mpls hat eine Länge von 11 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
Titel #00219.mpls hat eine Länge von 10 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
Titel #01160.mpls hat eine Länge von 7 Sekunden und wurde übersprungen,
ie Aufgabe wurde erfolgreich abgeschlossen
1 Titel werden in Verzeichnis C:/Users/Andreas 88 PC/Desktop/Neuer Ordner (4)/Transformers- Rise of the Beasts gespeichert. :D :D :D But why doesn't it work with the new version but with an older one? I just swapped the version, nothing more.
