Dump Summited for Mission Impossible the Final Reckoning
lkh126
Post by lkh126 »
Volume key error
MKB20_v82_MISSION-_IMPOSSIBLE_THE_FINAL_RECKONING_DD2A.tgz
(3.4 MiB) Downloaded 133 times
mathill6767
Re: Dump Summited for Mission Impossible the Final Reckoning
Post by mathill6767 »
Double check the tz dump to see if the Unit_Key_RO.inf file has the same SHA1 as the one in the keydb.cfg file you have. If it is then it should work. If its not in there follow the public keydb post to make sure you have the most recent version. Took me a bit to get the website to not 503 but I was able to download the file, unzip, move it to the .makemkv folder. Restarted and it worked.
Unit_Key file is in the AACS folder of the tz that was dumped
Find SHA1 look up online there are hash calcs or cmd/shell
open the keydb downloaded after extraction and see if the SHA1 is in there.
Or just move the new db to the .makemkv folder.
viewtopic.php?f=12&t=38293
