ASUS SBW-06D2X-U
Re: ASUS SBW-06D2X-U
Hi everyone, I recently got an Asus external bd drive and this is the information I get via MakeMKV:
OS device name: M:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: RFDL088797WL
Firmware date: 2017-04-18
Highest AACS version: 76
Firmware version: ID22
Would it be possible to flash this drive?
Thank you very much in advance.
MZ
OS device name: M:
Manufacturer: ASUS
Revision: 1.10
MZ
PM sent.Batto wrote: Fri Oct 17, 2025 3:53 pm Hi everyone, I recently got an Asus external bd drive and this is the information I get via MakeMKV:
OS device name: M:
Manufacturer: ASUS
Revision: 1.10
MZ
Worked like a charm, thank you!Coopervid wrote: Fri Oct 17, 2025 4:30 pmPM sent.Batto wrote: Fri Oct 17, 2025 3:53 pm Hi everyone, I recently got an Asus external bd drive and this is the information I get via MakeMKV:
OS device name: M:
Manufacturer: ASUS
Revision: 1.10
MZ
Hi, very new to this but from what I've found I need to reach out first before getting started. If I could get some help I would appreciate it.
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Serial number: AEDL214798WL
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Sure email me that drive info see belownone1904 wrote: Sat Oct 18, 2025 6:37 am Hi, very new to this but from what I've found I need to reach out first before getting started. If I could get some help I would appreciate it.
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Sent thanksBillycar11 wrote: Sat Oct 18, 2025 2:11 pmSure email me that drive info see belownone1904 wrote: Sat Oct 18, 2025 6:37 am Hi, very new to this but from what I've found I need to reach out first before getting started. If I could get some help I would appreciate it.
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Hello, I have two of these drives and im looking to enable LibreDrive, I see that MakeMKV says possible not yet enabled, and looking at previous posts I think this might be the place to ask fore help. Heres my Device info
OS device name: /dev/sr0
Manufacturer: ASUS
Revision: 1.10
Serial number:
Manufacturer: ASUS
Revision: 1.10
Serial number:
Yes can be flashed send that info to the email belowmaescobar wrote: Tue Oct 21, 2025 3:20 am Hello, I have two of these drives and im looking to enable LibreDrive, I see that MakeMKV says possible not yet enabled, and looking at previous posts I think this might be the place to ask fore help. Heres my Device info
Manufacturer: ASUS
Revision: 1.10
Serial number:
jackhodginsk
Hoping you can help with my drive also?
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
I should flash to BDR-UD04 1.01, right?
Where do I find this Pioneer firmware? (I did not find it in the viewtopic.php?f=16&t=19634)
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
PM sent.jackhodginsk wrote: Thu Oct 30, 2025 3:11 am Hoping you can help with my drive also?
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
Sorry to bother you again, but the PM shows that it was deleted by the author. Could you please send it to me again? Thank you.Coopervid wrote: Sun Oct 05, 2025 9:53 amPM sent.maozhu wrote: Sat Oct 04, 2025 2:11 amI have the same one, could you also send it to me?
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
Serial number:
Firmware date: 2017-12-21
Highest AACS version: 81
Drive platform: RS8601
Firmware version: E114/ID71
Delete message
This message was deleted by its author.
by Coopervid » Sun Oct 05, 2025 6:56 pm
You have to ask Billycar11. My PM was unread for 3 weeks. All unread PMs get deleted after 2 weeks.
awconley93
I’m new to ripping and was looking to get the mentioned drive as it’s readily available near me. Can this drive be flashed to rip UHD?Coopervid wrote: Fri Oct 31, 2025 4:20 pm You have to ask Billycar11. My PM was unread for 3 weeks. All unread PMs get deleted after 2 weeks.
You need to post your Makemkv info.awconley93 wrote: Sat Nov 08, 2025 8:36 pmI’m new to ripping and was looking to get the mentioned drive as it’s readily available near me. Can this drive be flashed to rip UHD?Coopervid wrote: Fri Oct 31, 2025 4:20 pm You have to ask Billycar11. My PM was unread for 3 weeks. All unread PMs get deleted after 2 weeks.
Hi Coopervid and everyone,
I recently got an Asus external slim bd drive SBW-06D2X-U and this is the information I get via MakeMKV:
OS device name: J:
Manufacturer: ASUS
Revision: 1.10
Serial number: UADL203251WL
I red the forum posts by many and also other topics here. Looks like i need to flash UD04 Fw. But i am not able to find it in the firmwares shared in ultimate flashing guide. (viewtopic.php?f=16&t=19634)
where can i find this firmware ? and can you tell me the steps to flash to read UHD.
Thanks in Advance.
OS device name: J:
Manufacturer: ASUS
Revision: 1.10
Thanks in Advance.
