ASUS SBW-06D2X-U
Batto
Re: ASUS SBW-06D2X-U
Post by Batto »
Hi everyone, I recently got an Asus external bd drive and this is the information I get via MakeMKV:
OS device name: M:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: RFDL088797WL
Firmware date: 2017-04-18
Highest AACS version: 76
Firmware version: ID22
Would it be possible to flash this drive?
Thank you very much in advance.
MZ
Batto wrote: Fri Oct 17, 2025 3:53 pm Hi everyone, I recently got an Asus external bd drive and this is the information I get via MakeMKV:
OS device name: M:
Manufacturer: ASUS
Revision: 1.10
MZ
PM sent.
Batto
Post by Batto »
Coopervid wrote: Fri Oct 17, 2025 4:30 pm
OS device name: M:
Manufacturer: ASUS
Revision: 1.10
MZ
PM sent.
Worked like a charm, thank you!
none1904
Post by none1904 »
Hi, very new to this but from what I've found I need to reach out first before getting started. If I could get some help I would appreciate it.
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Serial number: AEDL214798WL
none1904 wrote: Sat Oct 18, 2025 6:37 am Hi, very new to this but from what I've found I need to reach out first before getting started. If I could get some help I would appreciate it.
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Sure email me that drive info see below
none1904
Post by none1904 »
Billycar11 wrote: Sat Oct 18, 2025 2:11 pm
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Sent thanks
maescobar
Post by maescobar »
Hello, I have two of these drives and im looking to enable LibreDrive, I see that MakeMKV says possible not yet enabled, and looking at previous posts I think this might be the place to ask fore help. Heres my Device info
OS device name: /dev/sr0
Manufacturer: ASUS
Revision: 1.10
Serial number:
maescobar wrote: Tue Oct 21, 2025 3:20 am Hello, I have two of these drives and im looking to enable LibreDrive, I see that MakeMKV says possible not yet enabled, and looking at previous posts I think this might be the place to ask fore help. Heres my Device info
Manufacturer: ASUS
Revision: 1.10
Serial number:
Yes can be flashed send that info to the email below
jackhodginsk
Post by jackhodginsk »
Hoping you can help with my drive also?
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
I should flash to BDR-UD04 1.01, right?
Where do I find this Pioneer firmware? (I did not find it in the viewtopic.php?f=16&t=19634)
jackhodginsk wrote: Thu Oct 30, 2025 3:11 am Hoping you can help with my drive also?
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
PM sent.
maozhu
Post by maozhu »
Coopervid wrote: Sun Oct 05, 2025 9:53 am
maozhu wrote: Sat Oct 04, 2025 2:11 am
Coopervid wrote: Tue Jul 22, 2025 9:30 am PM sent.
I have the same one, could you also send it to me?
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
Serial number:
Firmware date: 2017-12-21
Highest AACS version: 81
Drive platform: RS8601
Firmware version: E114/ID71
PM sent.
Sorry to bother you again, but the PM shows that it was deleted by the author. Could you please send it to me again? Thank you.
Delete message
This message was deleted by its author.
by Coopervid » Sun Oct 05, 2025 6:56 pm
You have to ask Billycar11. My PM was unread for 3 weeks. All unread PMs get deleted after 2 weeks.
awconley93
Post by awconley93 »
Coopervid wrote: Fri Oct 31, 2025 4:20 pm You have to ask Billycar11. My PM was unread for 3 weeks. All unread PMs get deleted after 2 weeks.
I’m new to ripping and was looking to get the mentioned drive as it’s readily available near me. Can this drive be flashed to rip UHD?
awconley93 wrote: Sat Nov 08, 2025 8:36 pm
You need to post your Makemkv info.
pkr06
Post by pkr06 »
Hi Coopervid and everyone,
I recently got an Asus external slim bd drive SBW-06D2X-U and this is the information I get via MakeMKV:
OS device name: J:
Manufacturer: ASUS
Revision: 1.10
Serial number: UADL203251WL
I red the forum posts by many and also other topics here. Looks like i need to flash UD04 Fw. But i am not able to find it in the firmwares shared in ultimate flashing guide. (viewtopic.php?f=16&t=19634)
where can i find this firmware ? and can you tell me the steps to flash to read UHD.
Thanks in Advance.
