Flashing hangs/does nothing.
ld6772
Re: Flashing hangs/does nothing.
Post by ld6772 » Thu Oct 16, 2025 9:29 pm
I've successfully flashed my drive with 17.7, has anyone had any luck with 18.2; or more specifically, is it ok to upgrade again after flashing the drive?
Post by Woodstock » Thu Oct 16, 2025 10:38 pm
Question... what did you flash your drive with?
1.17.7 and 1.18.2 are versions of MakeMKV, which should NOT be flashed onto a drive.
Post by dcoke22 » Fri Oct 17, 2025 4:45 pm
ld6772 wrote: Thu Oct 16, 2025 9:29 pm I've successfully flashed my drive with 17.7, has anyone had any luck with 18.2; or more specifically, is it ok to upgrade again after flashing the drive?
The firmware that's on an optical drive isn't tied to a specific version of MakeMKV, so once a drive it flashed it should work with just about any version of MakeMKV.
bkwsoft
Post by bkwsoft » Fri Oct 17, 2025 7:37 pm
So where are we supposed to find the older versions, so we can flash our drives?
The only links I can find for the packages are the current version, 1.18.2.
Post by d00zah » Fri Oct 17, 2025 9:11 pm
bkwsoft wrote: Fri Oct 17, 2025 7:37 pm So where are we supposed to find the older versions, so we can flash our drives?
https://www.makemkv.com/download/old/
