Pioneer BDR-UD03 UHD possibility
WonderMage
Re: Pioneer BDR-UD03 UHD possibility
#826 Post by WonderMage » Wed Oct 15, 2025 9:27 am
Coopervid wrote: Wed Oct 15, 2025 8:55 am
WonderMage wrote: Wed Oct 15, 2025 5:15 am Hi Coopervid, I have a Pioneer BDR-UD03 from a Verbatim 43890 and would love to flash it for UHD rips. Thank you and the crew here that helps us out. Here are the specs ...
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: ...
Firmware date: 2020-06-15
Highest AACS version: 68
Drive platform: RS8511
Firmware version: 1.14
PM sent.
Thank You very much for that. I'll flash it in the morning. Do you or anyone else know if its best to connect the power brick for wall power and both usb plugs simultaneously, for flashing the firmware? I have the two usb plugs connected to two red usb 3.1 gen 2 ports on the back of my pc currently and it's ripping normal blu rays without issue. Thanks again for the help and this website
jburzynski9009
#827 Post by jburzynski9009 » Thu Oct 16, 2025 12:26 am
Jumping into this as well, any possibility mine can be flashed for ripping 4k/UHD discs?
OS device name: K:
Revision: 1.14
Serial number: CIDLXXXXXXXX
Highest AACS version: 81
DarkMetatron
#828 Post by DarkMetatron » Thu Oct 16, 2025 8:28 pm
I would be very happy if I could get help flashing my drive too.
Laufwerksinformation
OS-Gerätename: /dev/sr0
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer: AEDL----------
Firmware-Datum: 2020-06-15
BroadwayBra
#829 Post by BroadwayBra » Thu Oct 16, 2025 9:41 pm
Hello looking to flash mine as well
Revision: 1.14
Serial number:
#830 Post by Coopervid » Fri Oct 17, 2025 9:42 am
jburzynski9009 wrote: Thu Oct 16, 2025 12:26 am Jumping into this as well, any possibility mine can be flashed for ripping 4k/UHD discs?
OS device name: K:
Revision: 1.14
PM sent.
#831 Post by Coopervid » Fri Oct 17, 2025 9:44 am
DarkMetatron wrote: Thu Oct 16, 2025 8:28 pm I would be very happy if I could get help flashing my drive too.
Produzent: PIONEER
Revision: 1.14
PM sent.
#832 Post by Coopervid » Fri Oct 17, 2025 9:46 am
BroadwayBra wrote: Thu Oct 16, 2025 9:41 pm Hello looking to flash mine as well
Revision: 1.14
Serial number:
PM sent.
jogger15
#833 Post by jogger15 » Fri Oct 17, 2025 1:17 pm
Hi Coopervid, here ist my drive information. Thank you!
Produzent: PIONEER
Revision: 1.14
Serienummer: ...
#834 Post by Coopervid » Fri Oct 17, 2025 4:28 pm
jogger15 wrote: Fri Oct 17, 2025 1:17 pm Hi Coopervid, here ist my drive information. Thank you!
Produzent: PIONEER
Revision: 1.14
Serienummer: ...
PM sent.
Chivs
#835 Post by Chivs » Fri Oct 17, 2025 6:51 pm
I also have the UD03 with firmware 1.14. Would appreciate flashing instructions.
Thanks.
#836 Post by Coopervid » Fri Oct 17, 2025 7:30 pm
Chivs wrote: Fri Oct 17, 2025 6:51 pm I also have the UD03 with firmware 1.14. Would appreciate flashing instructions.
Thanks.
Post your Makemkv info.
Chivs
#837 Post by Chivs » Fri Oct 17, 2025 8:09 pm
Coopervid wrote: Fri Oct 17, 2025 7:30 pm
Thanks.
OS device name: F:
Revision: 1.14
Serial number: BHDL497970WL
Highest AACS version: 77
#838 Post by Coopervid » Sat Oct 18, 2025 10:02 am
Chivs wrote: Fri Oct 17, 2025 8:09 pm
Thanks.
OS device name: F:
Revision: 1.14
PM is coming. Forum is terribly slow at the moment.
Chivs
#839 Post by Chivs » Sat Oct 18, 2025 1:16 pm
Coopervid wrote: Sat Oct 18, 2025 10:02 am
OS device name: F:
Revision: 1.14
Much appreciated! Thanks.
tigyi
#840 Post by tigyi » Tue Oct 21, 2025 10:06 am
If assistance is still available, I'd greatly appreciate it. Thank you!
Product: BD-RW BDR-XU03
Revision: 1.03
Serial number:
Firmware date: 2015-06-29
Bus encryption flags: 13
Highest AACS version: 76
Drive platform: RS8520
Firmware version: 1.03
