Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIK09P8SF3609
Firmware date: 2120-05-07 09:35
Highest AACS version: 82
Firmware version: 1.02
Disc Information
Label: MI_FINAL_RECKONING
Timestamp: 2025-08-04 20:40:02
Data capacity: 87.4 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
MakeMKV v1.16.4 win(x64-release) started
The new version 1.18.2 is available for download at http://www.makemkv.com/download/
Using LibreDrive mode (v06.3 id=4C194CE2C4D1)
Saved AACS dump file as C:\Users\[-]/.MakeMKV/MKB20_v82_MISSION-_IMPOSSIBLE_THE_FINAL_RECKONING_DD2A.tgz
Can I get some help?
						MI_FINAL_RECKONING (The volume key is unknown for this disc)
Re: MI_FINAL_RECKONING (The volume key is unknown for this disc)
Per the UHD FAQ:MistyG wrote: ↑Thu Oct 16, 2025 5:00 pmDrive Information
Revision: 1.02
Disc Information
Number of layers: 3
And to assist the community, also see Public KeyDB Disc Submissions.MakeMKV says that "the volume key is unknown for this disc"?
MakeMKV produces an AACS .tgz dump file whenever you try to open a disc for which the key is unknown, and will report that the dump has been created. Email the dump file to svq@makemkv.com.
Now, it's a waiting game. For native MakeMKV functionality, what's next, etc., I recommend reading thru the 1st post of the UHD FAQ.
The alternative is explained in the 1st post of Public KeyDB Disc Submissions. It MAY get more immediate results than the 'official' process?
Thanks so much!!
