Did you power off your PC and reboot it? Do so and post your Makemkv info.
OS device name: E:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: KLZP37A3845
Highest AACS version: 76
Firmware version: 1.02
Now try a disc.....
powering the drive it made a weird scratchy noise. then after inserting a disc it seems to be trying very hard to read it. at some point it is taking up speed, but stopping abruptly. that happens either once or twice. then it's giving up and makemkv is eventually showing "no disc". that's the same as before the power cycle.
Your drive is on SATA inside a PC right? Try a regular BluRay disc and not an UHD since they are hard to read especially when not cleaned before reading. Report back.
Ah, i didn't mention. it's via usb. the case is also the recommended OWC Mercury Pro.
I tried regular BD and DVD. No success.
A full reset is only possible if you turn off power to the OWC AND remove the USB cable since USB still provides power to the drive. Try that.
turned off case, removed usb cable, removed power cable, waited 5min.
plugged everything back. tried different bluray. same result.
the fact i didn't power down my pc while the drive was not connected doesn't make any difference, does it?
No. These drives are merely junk. Flash LG BH16NS55 1.03 (<1.05) or so and then use the offical LG flasher to flash it to 1.05. Then return the drive.
outsideworlds
I have the same enclosure on a Mac as well. Big ups for the tip my friend, ordered the same drive, modded it slightly in the enclosure and just flashed. Ripping away!
csdesigns wrote: ↑Tue Feb 11, 2025 4:15 pmHuge props and thanks goes out to everyone involved to make this possible. Just wanted to report my recent success with the BU40N I purchased last week. Drive arrived with the following fw:Billycar11 wrote: ↑Mon May 27, 2019 5:20 amThis Guide Is Made By: Billy/Billycar11, MartyMcNuts, Blackened2687, Coopervid, d00zah, mike admin, SamuriHL, st4evr, TeddyRaspin, Woodstock, Bluntman, Alex/jonghotti, garygomm
Even if they didn't contribute directly i have used their informationI was able to easily update to the 1.03 fw following Billycar11's detailed guide:Code: Select all
Drive Information Manufacturer: HL-DT-ST Product: BD-RE BU40N Revision: FR07 Firmware date: 2118-01-22 15:36 Bus encryption flags: 1F LibreDrive Information Status: Possible (with patched firmware) Drive platform: MT1959 Harware support: Yes Firmware support: No Firmware type: Original (patched version available) Firmware version: 0.FRO7J DVD all regions: Possible (with patched firmware) BD raw data read: Possible (with patched firmware) BD raw metadata read: Possible (with patched firmware) Unrestricted read speed: Possible (with patched firmware)FYI, I installed the drive into my trusty old Sonnet Echo 15+ Thunderbolt 2 dock connected to a Mac Pro 6,1 (running Monterey 12.7.6) and flashed from there. Some slight modifications were performed to properly fit the drive into this enclosure since the BU40N is considerably slimmer than the previous existing drive (HL-DT-ST CT30F). Basically, just some 3M double-sided tape and rubber spacer rings were required to ensure the drive is balanced, as only one screw mount point aligned from the original included cage.Code: Select all
Drive Information Manufacturer: HL-DT-ST Product: BD-RE BU40N Revision: 1.03 Firmware date: 2118-10-24 19:34 Bus encryption flags: 17 Highest AACS version: 77 LibreDrive Information Status: Enabled Drive platform: MT1959 Firmware type: Patched (microcode access re-enabled) Firmware version: 1.03 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: YesCode: Select all
Echo 15 TB2: Vendor Name: Sonnet Technologies, Inc. Device Name: Echo 15 TB2 Mode: Thunderbolt 2 Device ID: 0xC Vendor ID: 0x8 Device Revision: 0x1 Route String: 3 Firmware Version: 25.2 Port (Upstream): Status: Device connected Link Status: 0x2 Speed: Up to 20 Gb/s x1 Current Link Width: 0x2 Cable Firmware Version: 0.1.23 Link Controller Firmware Version: 0.14.0 Port: Status: No device connected Link Status: 0x7 Speed: Up to 20 Gb/s x1 Current Link Width: 0x1 Link Controller Firmware Version: 0.14.0Ripped 4x UHD BDs last night, with max speeds writing to internal dual-SSD RAID0 of the dock at 6x speed.Code: Select all
HL-DT-ST BD-RE BU40N: Firmware Revision: 1.03 Interconnect: USB Burn Support: Yes (Generic Drive Support) Profile Path: None Cache: 4064 KB Reads DVD: Yes CD-Write: -R, -RW DVD-Write: -R, -R DL, -RAM, -RW, +R, +R DL, +RW BD-Write: -R, -RE Write Strategies: CD-TAO, CD-SAO, CD-Raw, DVD-DAO Media: To show the available burn speeds, insert a disc and choose File > Refresh Information
Spycrowsoft
Since @Billycar11 offers to check...
I have a Verbatim 43888 slim drive with the following MakeMKV drive information:
So if I understood the video correctly this is the command I need:
Is that correct for this drive?
OS device name: G:
Revision: 1.05
Serial number: <redacted>
Highest AACS version: 68
Disc Information
Label: DR_STRANGELOVE
Timestamp: 2020-01-17 11:00:31
Protection: AACS2.0/C v68
Data capacity: 58.69 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
makemkvcon64.exe f --all-yes -d <drive letter> rawflash enc -i <path to LG slim BU40N folder>\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
yeah looks fineSpycrowsoft wrote: ↑Thu Oct 16, 2025 5:11 pmSince @Billycar11 offers to check...
So if I understood the video correctly this is the command I need:Code: Select all
Drive Information OS device name: G: Current profile: BD-ROM Manufacturer: HL-DT-ST Product: BD-RE BU40N Revision: 1.05 Serial number: <redacted> Firmware date: 2124-04-23 13:47 Bus encryption flags: 17 Highest AACS version: 68 LibreDrive Information Status: Possible, not yet enabled Drive platform: MT1959 Disc Information Label: DR_STRANGELOVE Timestamp: 2020-01-17 11:00:31 Protection: AACS2.0/C v68 Data capacity: 58.69 Gb Disc type: BD-ROM UHD Number of layers: 2 Bus encryption flags: 80
Is that correct for this drive?Code: Select all
Hey, idk if this is the place to ask this, but does anyone know how to get my BU40N out of "BOOT" mode?
I successfully patched my firmware, thinking it would help me read a specific disc, which it did not, so I tried to revert it back to the official firmware provided by Hitachi/LG and ended up corrupting it. My computer still recognizes the drive in device manager and disk manger, but it says the partition is in MBR and it won't open when I press the eject button.
I have used SDF Tool Flasher, BD-RE_BU40N______1.05 (from LG), and BH14NS40_N1.00-A4_patched (from MakeMKV) and neither of them have worked. I am at a loss and ChatGPT is hallucinating and being more trouble than it is helpful.
Can anyone provide any guidance; is it salvageable or do I just need to buy a new drive?
