fox87
Post by fox87 » Thu Oct 16, 2025 3:59 pm
bdspock wrote: Sat Apr 22, 2023 6:35 pm Pretty recent (2022 October) manufacture date BH16NS55. Looks to have new/unknown firmware version "212006181342"
Flashing WH16NS60-1.02-NM00100-211810291936.bin from "all you need pack" does not seem to work.
Solved: drive was connected to SATA3G port on motherbord, reconnecting to SATA6G (different motherboard controller) allowed the flash to succeed.
# makemkvcon f -l
Found 1 drives(s)
00: dev_21:3, /dev/sr0, /dev/sr0
  HL-DT-ST_BD-RE__BH16NS55_1.05_212006181342_REDACTED
# makemkvcon f --info -d /dev/sr0
SDF.bin version: 0x0098
Drive Tool SDF present
Drive Specific SDF not present
Identification SDF present
8000:LibreDrive Information
8013:Status
8001:Drive platform
:MT1959
mtk:19:59:JB8 :HL-DT-ST:BD-RE  BH16NS55 1.05:N001601:-
Flashing fails in both "plain" and "enc" modes with:
# makemkvcon f -f /tmp/sdf.bin  -d /dev/sr0 rawflash enc -i /tmp/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Reading input file /tmp/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Current Drive ID: HL-DT-ST_BD-RE__BH16NS55_1.05_212006181342_REDACTED
yes
Write DRAM NG 05/21/04
[b]Command produced error code 0x82052104[/b]
Always the same code. In kernel logs handshake error is reported:
[ 2498.601845] ata4.00: exception Emask 0x10 SAct 0x0 SErr 0x400100 action 0x6 frozen
[ 2498.601858] ata4.00: irq_stat 0x08000000, interface fatal error
[ 2498.601862] ata4: SError: { UnrecovData Handshk}
[ 2498.601870] ata4.00: cmd a0/01:00:00:00:40/00:00:00:00:00/a0 tag 23 dma 16384 out
                        Write Buffer 3b 06 00 00 00 00 00 40 00 00res 50/00:03:00:00:00/00:00:00:00:00/a0 Emask 0x10 (ATA bus error)
[ 2498.601881] ata4.00: status: { DRDY }
[ 2498.601886] ata4: hard resetting link
[ 2498.915527] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2498.918526] ata4.00: configured for UDMA/33
[ 2498.918833] ata4: EH complete
Managed to dump firmware via:
# makemkvcon f -d /dev/sr0 dump auto -o ./
Command produced 1 file(s)
  #00: size=70Kb name=dump_user_HL-DT-ST_BD-RE__BH16NS55_1.05_212006181342_REDACTED.tar
Will try replugging to different SATA port and different cable but maybe someone else has more ideas. Can share the FW dump if its relevant.
My order of the BH16NS5 just arrived. I started makemkv and the firmware date was 20.06.2021.
I uded the SDFtool Flasher 3.6 and the dump i got was named dump_user_HL-DT-ST_BD-RE__BH16NS55_1.05_212006181342_KLZP37A3845.tar.
I realized, that the firmware there was more recent than the most recent encrypted firmware mentioned in the guide.
After i read quoted post, saying the flash was successful, i tried my luck and flashed the HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin as the guide recommends for this drive.
The flash was successful, but the drive won't read any disc, neither BD nor DVD.
Have i bricked my drive or is there anything i can do to save it?
Please help. Thanks in advance.
Regards, fox.
Post by Coopervid » Thu Oct 16, 2025 4:05 pm
Did you power off your PC and reboot it? Do so and post your Makemkv info.
fox87
Post by fox87 » Thu Oct 16, 2025 4:16 pm
Coopervid wrote: Thu Oct 16, 2025 4:05 pm Did you power off your PC and reboot it? Do so and post your Makemkv info.
OS device name: E:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: KLZP37A3845
Highest AACS version: 76
Firmware version: 1.02
Post by Coopervid » Thu Oct 16, 2025 4:18 pm
Now try a disc.....
fox87
Post by fox87 » Thu Oct 16, 2025 4:27 pm
Coopervid wrote: Thu Oct 16, 2025 4:18 pm Now try a disc.....
powering the drive it made a weird scratchy noise. then after inserting a disc it seems to be trying very hard to read it. at some point it is taking up speed, but stopping abruptly. that happens either once or twice. then it's giving up and makemkv is eventually showing "no disc". that's the same as before the power cycle.
Post by Coopervid » Thu Oct 16, 2025 4:31 pm
Your drive is on SATA inside a PC right? Try a regular BluRay disc and not an UHD since they are hard to read especially when not cleaned before reading. Report back.
fox87
Post by fox87 » Thu Oct 16, 2025 4:34 pm
Coopervid wrote: Thu Oct 16, 2025 4:31 pm Your drive is on SATA inside a PC right? Try a regular BluRay disc and not an UHD since they are hard to read especially when not cleaned before reading. Report back.
Ah, i didn't mention. it's via usb. the case is also the recommended OWC Mercury Pro.
I tried regular BD and DVD. No success.
Post by Coopervid » Thu Oct 16, 2025 4:37 pm
A full reset is only possible if you turn off power to the OWC AND remove the USB cable since USB still provides power to the drive. Try that.
fox87
Post by fox87 » Thu Oct 16, 2025 4:49 pm
Coopervid wrote: Thu Oct 16, 2025 4:37 pm A full reset is only possible if you turn off power to the OWC AND remove the USB cable since USB still provides power to the drive. Try that.
turned off case, removed usb cable, removed power cable, waited 5min.
plugged everything back. tried different bluray. same result.
the fact i didn't power down my pc while the drive was not connected doesn't make any difference, does it?
Post by Coopervid » Thu Oct 16, 2025 4:53 pm
No. These drives are merely junk. Flash LG BH16NS55 1.03 (<1.05) or so and then use the offical LG flasher to flash it to 1.05. Then return the drive.
outsideworlds
Post by outsideworlds » Thu Oct 16, 2025 5:06 pm
I have the same enclosure on a Mac as well. Big ups for the tip my friend, ordered the same drive, modded it slightly in the enclosure and just flashed. Ripping away!
csdesigns wrote: Tue Feb 11, 2025 4:15 pm
Billycar11 wrote: Mon May 27, 2019 5:20 am This Guide Is Made By: Billy/Billycar11, MartyMcNuts, Blackened2687, Coopervid, d00zah, mike admin, SamuriHL, st4evr, TeddyRaspin, Woodstock, Bluntman, Alex/jonghotti, garygomm
Even if they didn't contribute directly i have used their information
Huge props and thanks goes out to everyone involved to make this possible. Just wanted to report my recent success with the BU40N I purchased last week. Drive arrived with the following fw:
Product: BD-RE BU40N
Revision: FR07
Firmware date: 2118-01-22 15:36
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 0.FRO7J
I was able to easily update to the 1.03 fw following Billycar11's detailed guide:
Manufacturer:
HL-DT-ST
Revision: 1.03
Highest AACS version: 77
Firmware version: 1.03
FYI, I installed the drive into my trusty old Sonnet Echo 15+ Thunderbolt 2 dock connected to a Mac Pro 6,1 (running Monterey 12.7.6) and flashed from there. Some slight modifications were performed to properly fit the drive into this enclosure since the BU40N is considerably slimmer than the previous existing drive (HL-DT-ST CT30F). Basically, just some 3M double-sided tape and rubber spacer rings were required to ensure the drive is balanced, as only one screw mount point aligned from the original included cage.
Echo 15 TB2:
  Vendor Name:	Sonnet Technologies, Inc.
  Device Name:	Echo 15 TB2
  Mode:	Thunderbolt 2
  Device ID:	0xC
  Vendor ID:	0x8
  Device Revision:	0x1
  Route String:	3
  Firmware Version:	25.2
  Port (Upstream):
  Status:	Device connected
  Link Status:	0x2
  Speed:	Up to 20 Gb/s x1
  Current Link Width:	0x2
  Cable Firmware Version:	0.1.23
  Link Controller Firmware Version:	0.14.0
  Port:
  Status:	No device connected
  Link Status:	0x7
  Current Link Width:	0x1
HL-DT-ST BD-RE BU40N:
  Firmware Revision:	1.03
  Interconnect:	USB
  Burn Support:	Yes (Generic Drive Support)
  Profile Path:	None
  Cache:	4064 KB
  Reads DVD:	Yes
  CD-Write:	-R, -RW
  DVD-Write:	-R, -R DL, -RAM, -RW, +R, +R DL, +RW
  BD-Write:	-R, -RE
  Write Strategies:	CD-TAO, CD-SAO, CD-Raw, DVD-DAO
  Media:	To show the available burn speeds, insert a disc and choose File > Refresh Information
Ripped 4x UHD BDs last night, with max speeds writing to internal dual-SSD RAID0 of the dock at 6x speed.
Spycrowsoft
Post by Spycrowsoft » Thu Oct 16, 2025 5:11 pm
Since @Billycar11 offers to check...
I have a Verbatim 43888 slim drive with the following MakeMKV drive information:
OS device name: G:
Revision: 1.05
Serial number: <redacted>
Highest AACS version: 68
Disc Information
Label: DR_STRANGELOVE
Timestamp: 2020-01-17 11:00:31
Protection: AACS2.0/C v68
Data capacity: 58.69 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
So if I understood the video correctly this is the command I need:
makemkvcon64.exe f --all-yes -d <drive letter> rawflash enc -i <path to LG slim BU40N folder>\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Is that correct for this drive?
fox87
Post by fox87 » Thu Oct 16, 2025 5:19 pm
Coopervid wrote: Thu Oct 16, 2025 4:53 pm No. These drives are merely junk. Flash LG BH16NS55 1.03 (<1.05) or so and then use the offical LG flasher to flash it to 1.05. Then return the drive.
thank you for your time : )
may i write you a dm?
Post by Billycar11 » Thu Oct 16, 2025 6:09 pm
Spycrowsoft wrote: Thu Oct 16, 2025 5:11 pm Since @Billycar11 offers to check...
OS device name: G:
Revision: 1.05
Disc Information
Number of layers: 2
yeah looks fine
Post by Coopervid » Thu Oct 16, 2025 6:19 pm
fox87 wrote: Thu Oct 16, 2025 5:19 pm
Sure. Go ahead.
