I have a drive that is apparently a "sample" for a UD04tbd from Pioneer and thus its firmware is lower than the regular UD04tbd which causes the drive to be "possible" in MakeMKV instead of just working.
Can anyone help me with forcing it to dump its firmware as it looks like MakeMKV isn't doing it.
@Blackened2687 I heard you could help with this perhaps?
How do I force a drive to dump its firmware?
Re: How do I force a drive to dump its firmware?
I can't help you dump it but I can make it do UHD email me for the flasher
Rare329
It is already UHD, at least the non-sample one is, it just needs to be approved which requires a firmware dumpBillycar11 wrote: Thu Oct 16, 2025 7:35 am I can't help you dump it but I can make it do UHD email me for the flasher
To be clear, the non-sample drives are the same drives with a newer update and those are already approved
Yeah I can help with that see email belowRare329 wrote: Thu Oct 16, 2025 7:47 pmIt is already UHD, at least the non-sample one is, it just needs to be approved which requires a firmware dumpBillycar11 wrote: Thu Oct 16, 2025 7:35 am I can't help you dump it but I can make it do UHD email me for the flasher
