Dump Submitted:MKB20_v77_The_wandering_earth_II_Disc1_CBF2(Issued in China)
Re: Dump Submitted:MKB20_v77_The_wandering_earth_II_Disc1_CBF2(Issued in China)
Post by MartyMcNuts » Sun Sep 14, 2025 1:14 am
SamuriHL wrote: Sat Sep 13, 2025 5:34 pmNo
Hasn't worked for me for a few days either in Firefox or Edge.
Post by SamuriHL » Sun Sep 14, 2025 2:17 am
It's DNS related. Try changing DNS servers. Happens all the time but the site is still up.
Post by MartyMcNuts » Sun Sep 14, 2025 2:27 am
SamuriHL wrote: Sun Sep 14, 2025 2:17 am It's DNS related. Try changing DNS servers. Happens all the time but the site is still up.
I use google DNS servers and the site seems to be quite intermittent. One day I get it to work then it won't load for a few days. Then other times like right now, the site will load (on Edge) but the downloads don't work properly. If I click on the english KeyDB.cfg, instead of keydb_eng.zip, it downloads a file called fv_download.zip. I just checked that file and it does contain the keydb.cfg file. Strange that the zip file is named differently??
Post by SamuriHL » Sun Sep 14, 2025 10:54 am
That part is likely due to his updating of PHP on the back end. Nalor posted something about it on Doom9. The host does go down for a bit randomly from time to time but I've found that certain DNS servers aren't helpful. Google is one of the ones I find to not resolve it half the time. Cloudfare is another one that doesn't always work. I have a private adgaurd server so I have multiple DNS resolution services defined.
99gagamel
Post by 99gagamel » Tue Sep 30, 2025 5:35 am
Frage woher bekomme ich den Dump? Hab hier einige 4ks die MKV nicht schafft. Aktuell Roundup 3.
Es erfolgt diese info:
MakeMKV v1.18.2 win(x64-release) gestartet
Using LibreDrive mode (v06.3 id=8AA951EFA8D1)
Disk in Ordner kopieren "D:/_Medien_IN/The Roundup No Way Out"
AACS Ausgabedatei als D:/MakeIN/MKB20_v77_The_Roundup_No_Way_Out_1ABF.tgz gesichert
Der Volumenschlüssel für die DVD/Blu-ray ist unbekannt - das Video kann nicht entschlüsselt werden
Backup fehlgeschlagen
Was kann ich tun
PS: ist das die "MKB20_v77_The_Roundup_No_Way_Out_1ABF.tgz" sogenannte dump Datei? wie kann ich die hier rein stellen? Bekomme den Hinweis "Kontingent erschöpft, dabei ist die nur 113 kb
natethelen
Post by natethelen » Tue Oct 14, 2025 9:40 pm
keydb_helper wrote: Thu Nov 14, 2024 1:29 am Finally, you'll need to copy the extracted keydb.cfg into the MakeMKV data directory. The default locations for each platform are:
Windows: C:\Users\<Your Username>\.MakeMKV\
FYI, I had to put the file in C:\Users\<Your Username>\AppData\Local\MakeMKV\ for it to work for me
keydb_helper
Post by keydb_helper » Thu Oct 16, 2025 3:07 am
natethelen wrote: Tue Oct 14, 2025 9:40 pm FYI, I had to put the file in C:\Users\<Your Username>\AppData\Local\MakeMKV\ for it to work for me
Hey natethelen, thanks for mentioning that alternative location. Just to be clear, did you happen to set that location manually? Or did you do anything unconventional when installing MakeMKV?
I should probably check whether recent updates to MakeMKV or Windows may be using that alternative folder as the default for new users.
Public KeyDB Disc Submissions
Post by SamuriHL » Thu Oct 16, 2025 3:21 am
Now you know why I read that value from the registry in my tool. I don't like guessing. Lol
Post by Coopervid » Thu Oct 16, 2025 4:10 pm
SamuriHL wrote: Sun Sep 14, 2025 10:54 am That part is likely due to his updating of PHP on the back end. Nalor posted something about it on Doom9. The host does go down for a bit randomly from time to time but I've found that certain DNS servers aren't helpful. Google is one of the ones I find to not resolve it half the time. Cloudfare is another one that doesn't always work. I have a private adgaurd server so I have multiple DNS resolution services defined.
Most likely not a DNS problem but updating of PHP. I tried a few hours ago and received a failure message. Now it worked without an issue.
Post by SamuriHL » Thu Oct 16, 2025 5:04 pm
I disagree. If it were a PHP issue it'd be consistent for everyone. I've not had any issues at all. DNS issues happen quite a bit, and the server he's running the site on is not well maintained because it's a free account.
supercav76
Post by supercav76 » Fri Nov 07, 2025 3:25 am
BaiDuYunPan wrote: Wed Nov 13, 2024 11:46 pm ...
MakeMKV v1.17.7 win(x64-release) started
Backing up disc into folder "E:/Video/backup/The wandering earth II Disc1"
Saved AACS dump file as C:\Users\BaiDuYunPan/.MakeMKV/MKB20_v77_The_wandering_earth_II_Disc1_CBF2.tgz
Backup failed
I can't seem to rip, please what is wrong, thank you very much
You need to download and configure the public key database file. The public keydb is a community driven project which MakeMKV can utilise as an alternative key source.
You can download the keydb from here: http://fvonline-db.bplaced.net/ (Direct link).
After the download has finished, you'll have a file named keydb_eng.zip. Extract/decompress this zip file and you'll get the keydb.cfg file.
If you do not unzip the downloaded zip file MakeMKV will not be able to use it. MakeMKV will not try to parse the keydb_eng.zip file. It will only read the extracted keydb.cfg
Linux: /home/<Your Username>/.MakeMKV/
macOS: /Users/<Your Username>/.MakeMKV/ (I might be wrong about this one)
To account for case-sensitive filesystems, such as most Linux options and potentially macOS, you may need to rename the keydb.cfg file to KEYDB.cfg. This shouldn't be required on Windows.
I followed the steps listed above for windows and didn't notice any change. I have many discs that will not rip. I have 7 different drives, all new and have tried the failed disc in all of them. What am I doing wrong? How can I make to program see and use the keydb.cfg file?
schmidt2401
Post by schmidt2401 » Thu Dec 11, 2025 6:47 pm
I made an account to say this -
the keybd.cfg download link, albeit slow, works.
After placing the file in the right directory (unzipped), MakeMKV now reads some of the notoriously difficult AACS v82 disks.
I am blown away by this community. Awesome!
dxrmkvun
Post by dxrmkvun » Wed Dec 17, 2025 7:03 am
In case this helps someone else here:
I kept getting a 404 error when I clicked on the db link. Then I discovered that my browser was changing it from "http://" to "https://". I manually entered the http version, and then I got the download page. Try manually entering "http://fvonline-db.bplaced.net/" in your browser to see if that forces it to the correct page.
TheOnlyDarkKnight
Post by TheOnlyDarkKnight » Fri Dec 19, 2025 3:15 pm
When trying to access the keydb file, I get this error page:
"Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Additionally, a 503 Service Unavailable error was encountered while trying to use an ErrorDocument to handle the request.
Apache Server at fvonline-db.bplaced.net Port 80:"
TORRRRR
Post by TORRRRR » Mon Dec 29, 2025 11:25 pm
I too am getting:
Service Unavailable
