Does zip hurt quality
CybrTwo
#1 Post by CybrTwo » Wed Oct 15, 2025 6:48 pm
I have a ton of video files I want to compress into zip because of how I setup mkv. Will there be any lost data at all? I plan to redo my entire catalog but this question has been in the back of my mind for a while. I access my video files directly so i dont need it to be compatible with plex or anything like that. Sorry if its been asked before but I couldn't find this question anywhere in the search bar or reddit.
Re: Does zip hurt quality
#2 Post by Woodstock » Wed Oct 15, 2025 9:16 pm
ZIP does not throw data away. It is a "lossless" compression method.
Other compression methods cannot guarantee that. And ZIP is not the most efficient compression method of ways to compress cleanly.
CybrTwo
#3 Post by CybrTwo » Wed Oct 15, 2025 9:44 pm
Thank you I will look for efficient lossless compression software. New to compressing files but I figured I should make a backup so I don't lose anything in case of disaster
