Hi!
I am new to this forum and stumbled upon this thread searching for the info if my Asus BD drive is UHD compatible. Learning from this thread it is not out of the box, I also learned, that it is possible to flash the drive. After searching the internet for firmware files and a guide/program to do it - not finding much use- or somethiong i trust, I came back here to ask for help. So can someone please point me in the right direction or give me a hint where to find the needed files, program or guide.
Below is the infromation from makemkv.
OS device name: G:
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E101
Serial number: RLDL111044WL
Firmware date: 2018-08-22
Highest AACS version: 68
Drive platform: RS8511
Firmware version: E101/ID26
OS device name: G:
Manufacturer: ASUS
Revision: E101
PM sent.RedSkjarr wrote: Fri Sep 05, 2025 7:25 pm Hi!
OS device name: G:
Manufacturer: ASUS
Revision: E101
Thank you very much! It worked perfectly!
sincereYear9
Hello everyone,
in my search to make my drive work, I stumbled upon this thread here, because I have the same model of slim Asus drive, but from the information on the other drives, I couldn't find a case that's similar enough to mine to be comfortable to flash any firmware on it. (Sidenote: I'm showing the data on the Windows version of MakeMKV v1.18.1 win(x64-release) on a laptop, but I'd like to use Linux MakeMKV v1.18.1 linux(x64-release) on my main system with more capabilities hardware-wise. So a little help in the right direction would be very much appreciated.)
Thanks for any help in advance
Information from MakeMKV on Windows:
Information from MakeMKV on Linux:
Same but (of course):
Manufacturer: ASUS
Revision: E102
Serial number:
Firmware date: 2023-04-20
Firmware version: ID26 Same but (of course):
OS device name: /dev/sr0Re: Make "ASUS SBW-06D5H-U" UHD friendly?
Hi everyone,
I’ve got the same model as well and I’m wondering if it’s possible to flash mine. Could anyone point me in the right direction or let me know where I might find the necessary files, software, or a guide?
Manufacturer: ASUS
Revision: E101
Serial number:
yes just email me that infomgxjskbcb wrote: Thu Sep 25, 2025 12:58 pm Hi everyone,
Below is the infromation from makemkv.Code: Select all
Drive Information OS device name: /dev/sr0 Manufacturer: ASUS Product: SBW-06D5H-U Revision: E101 Serial number: Firmware date: 2018-08-22 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: E101/ID26 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
but just know the flasher is windows only
Hi, I’ve already emailed you the details. Kindly have a look when you get a chance.Billycar11 wrote: Thu Sep 25, 2025 1:36 pmyes just email me that infomgxjskbcb wrote: Thu Sep 25, 2025 12:58 pm Hi everyone,
Hi, can someone pls help me flashing my drive?
sure email that info to me
Hi buddies, I wonder if you could help me with my drive, I have this model info, but dunno, if it's possible to get it working with UHD discs
OS device name: E:
Manufacturer: ASUS
Revision: E101
Serial number: UADL204429WL
Highest AACS version: 31
Sorry for the previous screenshot
OS device name: E:
Manufacturer: ASUS
Revision: E101
You need to post your own Makemkv info. Just copy and paste the text. No need to include a screenshot.
[/quote]
[/quote]
Sorry for that
this is my device info btw
[/quote]
Sorry for that
OS device name: E:
Manufacturer: ASUS
Revision: E101
[/quote]
Sorry for that
OS device name: E:
Manufacturer: ASUS
Revision: E101
PM sent.
Meisterbravo
Stumbled unto this thread.
I have the same device as op.
Any chance anyone can help me flash mine ?
OS device name: G:
Manufacturer: ASUS
Revision: E101
Serial number: SJDL148969WL
Unrestricted read speed: YesRe: Make "ASUS SBW-06D5H-U" UHD friendly?
It worked perfectly, thanks pal, time to rip my UHD library nowPM sent.
