I am having a hell of time properly ripping the Pokemon DVDs. The problem is that a lot of cartoons I rip contain just a giant mpeg that I have to split later. I manually go through each mpeg and list the start and end chapters for each episode and save it in a text file for parsing later.
The problem with Pokemon is that MakeMKV is ripping chapters, but arbitrarily leaving some out, and seems to ALWAYS leave out the chapters for beginning/ending of each episode.
The first mpeg on the disc contains 3 episodes. VLC shows this section from the DVD and the ripped mkv as 1h5m, with the mkv showing ~4 seconds longer. And yes I triple-checked they are the same video segment.
The original DVD shows 13 chapters for this mpeg.
The ripped MKV shows 8 chapters for this mpeg.
I can't figure out at all what is going on. I have a massive library of DVDs and all my scripts are built around the chapters but MakeMKV isn't ripping this series correctly and I don't know what's wrong or how to fix it. The problem seems to go away around disc 11 (episode 95+). Does anyone have any ideas?
for the record, I know the Pokemon DVDs are garbage quality and have film misplacement issues but idc
[BUG] Missing Chapters ripping Pokemon
Re: [BUG] Missing Chapters ripping Pokemon
A question - do the episodes share a common open/close? I ask because I have a similar series, where the open/close are common for a dozen or so episodes, and are NOT included in the individual episode files in the rip. The next partial season changed open/close, then there was a third set of open/close segments.
The play sequences is Opening, episode chapter 1, episode chapter 2, Closing, episode preview.
What gets ripped (except on the episodes where the open/close changed) is episode chapter 1, episode chapter 2, episode preview.
knuxyl
Well yes, the start of one episode's chapter is the end of another episode's chapter. The second episode should start around 21:40 and there should be a chapter there but there isn't. I get makemkv sync issues around each episode break. This DVD has 3 mpegs, each with 3 episodes, and these errors are just about the same for each mpeg, give or take 5 seconds.Woodstock wrote: Wed Oct 15, 2025 1:31 pm A question - do the episodes share a common open/close?...
I just tried changing the open method to cellfull instead of auto and that didn't fix it.
These are the syncs issues I get around where the chapter should be (for example this one's chapter is 21:40)
----MSG:4008,16,4,"AV sync issue in stream 1 at 0:20:37.927 with duration of 183.533ms : audio gap - 5.735 missing frame(s)","AV sync issue in stream %1 at %2 with duration of %3 : %4","1","0:20:37.927","183.533ms","audio gap - 5.735 missing frame(s)"
----MSG:4008,16,4,"AV sync issue in stream 1 at 0:22:42.615 with duration of 160ms : 5 frame(s) dropped to reduce audio skew to +3.4ms","AV sync issue in stream %1 at %2 with duration of %3 : %4","1","0:22:42.615","160ms","5 frame(s) dropped to reduce audio skew to +3.4ms"
----MSG:4008,16,4,"AV sync issue in stream 1 at 0:42:18.964 with duration of 169.066ms : audio gap - 5.283 missing frame(s)","AV sync issue in stream %1 at %2 with duration of %3 : %4","1","0:42:18.964","169.066ms","audio gap - 5.283 missing frame(s)"
----MSG:4008,16,4,"AV sync issue in stream 1 at 0:44:23.648 with duration of 160ms : 5 frame(s) dropped to reduce audio skew to +0.066ms","AV sync issue in stream %1 at %2 with duration of %3 : %4","1","0:44:23.648","160ms","5 frame(s) dropped to reduce audio skew to +0.066ms"
