Dump Submitted -MKB20_v82_MISSION-_IMPOSSIBLE_THE_FINAL_RECKONING_9EAA
Did not see it in the Forum.
Re: Dump Submitted -MKB20_v82_MISSION-_IMPOSSIBLE_THE_FINAL_RECKONING_9EAA
Well, there's this post: https://forum.makemkv.com/forum/viewtopic.php?p=185241#p185241
And this thread: https://forum.makemkv.com/forum/viewtopic.php?f=12&t=39653
And this thread: https://forum.makemkv.com/forum/viewtopic.php?f=12&t=39583
No need to make your own thread for a different variant.
That last thread will tell you that your variant is already available in the Public KeyDB.
Yes I read those and yes I seen that they have the same movie title but they do not have the same dump file. So I won't post here anymore as far as my dumps that way nobody has to worry about me making a postdcoke22 wrote: ↑Tue Oct 14, 2025 10:03 pmWell, there's this post: https://forum.makemkv.com/forum/viewtopic.php?p=185241#p185241
No need to be a sook about it. Simply put, if you had of used the search function, you would have found it. I just searched for "reckoning 9EAA" and instantly found the post from October 5th when a key record for that dump file was added to the KeyDB.csbond2 wrote: ↑Tue Oct 14, 2025 11:15 pmYes I read those and yes I seen that they have the same movie title but they do not have the same dump file. So I won't post here anymore as far as my dumps that way nobody has to worry about me making a postdcoke22 wrote: ↑Tue Oct 14, 2025 10:03 pmWell, there's this post: https://forum.makemkv.com/forum/viewtopic.php?p=185241#p185241
Not trying to be a jerk about it. There could have been a better way to explain it to me, I don't use this thread very often although I've been doing this type of stuff for the last 20 years or so I am new to the UHD format. And I've only been back on this form for about 2 months. I'm still learning all the things that have to be done with this thing so in my feelings I'm not going to post my dump files here anymore I will make the dump if I don't see it anywhere if it's already there so be it. And I will read the threads like I did tonight and find out that there is a key somewhere now that I have finally learned how to do that. So if I have been a problem I am sorry.MartyMcNuts wrote: ↑Tue Oct 14, 2025 11:24 pmNo need to be a sook about it. Simply put, if you had of used the search function, you would have found it. I just searched for "reckoning 9EAA" and instantly found the post from October 5th when a key record for that dump file was added to the KeyDB.csbond2 wrote: ↑Tue Oct 14, 2025 11:15 pmYes I read those and yes I seen that they have the same movie title but they do not have the same dump file. So I won't post here anymore as far as my dumps that way nobody has to worry about me making a postdcoke22 wrote: ↑Tue Oct 14, 2025 10:03 pmWell, there's this post: https://forum.makemkv.com/forum/viewtopic.php?p=185241#p185241
I apologize. It was not my intent you make you feel badly, only to lightheartedly point out the other threads and suggest you could've posted your variant in one of those.
In an ideal world, each movie would have a single thread, but we almost never get there.
I'm not upset. And I understand the reasoning behind it so we'll just reset to zero on it and I will do a better job now on of looking through the thread and doing a search before I post and if I can find one somewhere I will post there instead of making a separate thread. Like I explained a little higher up UHD is new to me although I've been doing DVDs and blu-rays for 20 plus years. And I was a member of this forum many years ago and only recently came back when I started doing UHD. So I'm still getting used to a lot of this stuff and a lot of the misunderstanding a lot of the time falls on me because I am dyslexic so sometimes I don't process what said or what I read the way I should. So thank you for trying to point it out to me.dcoke22 wrote: ↑Tue Oct 14, 2025 11:50 pmI apologize. It was not my intent you make you feel badly, only to lightheartedly point out the other threads and suggest you could've posted your variant in one of those.
In an ideal world, each movie would have a single thread, but we almost never get there.The upside to posting which variant you've submitted is it lets others know if and when the variant they have might already have been submitted. It is a genuine help to the community to do so.
